Question about Building Materials
How to remove an at least 20yr old cylinder / barrel lock from a screen/security door for which we ave no keys? Thanks.
  • 10,291 Answers
If it's a deadbolt style of lock, simply remove the 2 screws from the inside lever and the whole lock will come apart.
Posted on May 10, 2017
How do i drill the ignition lock cylinder out of my 1991 nisan pathfinder without distorting the column
you can di it by simply drilling down the key slot
However if you get it wrong then the hole for the barrel will be damaged and you will have to replace the whole assembly
Big job
get a locksmith to do the job and have him to reset the barrel to existing door locks so that you still only need one ley
Apr 22, 2015 | 1991 Nissan Pathfinder
Vr commodore new key won't sync
First it sounds like the locks need to be lubed! But it really sound like you need to get in the door panels and look for damage and lube the linkage.
Apr 04, 2014 | Vehicle Parts & Accessories
I replaced my ignition lock cylinder. Tried starting 3x got locked out, didn't realize i needed chip key. I left THE IGNITION KEY ON FOR ABOUT AN HOUR, and it cleared the p0513 code, which i believe took...
Remove the ring antenna around the barrel,put the old good chip key in the ring (...) start with the other key the car.The immo will read the regular key but the new barrel will work with the new key.Need reprograming the keys or switch the boards/chips in the key.
Oct 22, 2013 | 2002 Dodge Neon
Vats module location 96 buick park ave
Part of the BCM. On mine I got a new lock cylinder and put old chip key in it. Then found the wire to the old one at lower part of steering column and plugged it in . Started car with extra key I had thus by passing the removal of the old lock cylinder. Hid new cylinder with key in it under dash and secured. no more chip keys needed.
Sep 16, 2011 | 1996 Buick Park Avenue
Hey i have a 1991 buick park ave i lost my keys i went to the dealer to get one made they said its to old no codes are comen up what do i do please help
You will have to replace the ignition lock cylinder and it will come with a new ignition key. As for the doors/trunk you will most likely have to hire a locksmith to make you a new one. Or you can replace all of the door lock cylinders as well. See links below.
Ignition Lock Cylinder
Door Lock Cylinder
Trunk Lock Cylinder
Jan 13, 2011 | 1991 Buick Park Avenue
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
Dec 31, 2010 | 2002 Jaguar X-Type
I have an Isuzu Rodeo and the key is stuck in the ignition any idea how to get it out? Year 2000
replace the whole ignition barrel with new key and get key programmed by dealer
can remove barrel and key by removing steering column covers turn ignition to on position and with small shank screw driver push in hole in outer top rear section of barrel assembly then pull out ignition lock barrel with key in it. fit new lock barrel and key, program new key into system and can get door lock barrels coded to suit new key or get code for old key and cut new key so it fits mechanical locks on the rest of the vehicle (just wont turn in ignition) 2 keys for vehicle.
Jun 13, 2010 | 2000 Isuzu Rodeo
1991 buick park ave. security system set off,
Did you try the drivers door lock cylinder?
Jul 19, 2009 | 1991 Buick Park Avenue
Lost car keys
remove one of the lock barrels and take to dealer and get key cut to barrel
Jan 13, 2009 | 1995 Chevrolet Suburban
Building Materials Logo
41 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
