Question about Sony Televison & Video
Sony tv volume is at loudest and won't turn down. The remote is down to the lowest volume and the tv is still at it's loudest.
  • 1153 Answers
SOURCE: Sony TV power and volume not working
Since remote does not work, try taking out batt and turning on by set. See if still turns up. It could be that the up button is jammed inside set. Does everything else works? See if you can go to menu and turn speakers off, this will allow you to work on set and not worry about noise.
Posted on Sep 04, 2007
  • 286 Answers
SOURCE: ViewSonic N2750w 27 in Volume turns down by itself
Could be a problem with the down volume button on the tv. the board it's on ir its harness. Check them all. Make sure the volume buttons plastic actuator moves freely and is not stuck.
If these parts are all good, you have a problem on the main board. You may have to trace the control lines as far as you can and check any capacitors along the way. If you have an oscilliscope you can test the lines to see if the up volume is working correctly. If there is noise on it, you might find a bad capacitor if you can trace it back far enough. Schematic helps here.
Of course, make sure nothing is shining on the sensor window on the TV. You might want to scope that line as well (IR sensor line).
If none of that helps, get hold of Viewsonic and find your closest service provider. You can order a main board from them.
Of course, you could try just using the audio out jacks to an amplifier or a surround sound amplifer. Then you would use the remotecontrol for the surround sound system to control your volume.
Bet you were going to buy one anyway right?
Posted on Feb 14, 2008
cezirkle
  • 27 Answers
SOURCE: sony tv codes
Greetings...
What is the number for the TW remote you are using? 8400, U62R, 2000? Which TW cable service in NY... NYC, NY & NJ, Albany, etc...?
Ed
Posted on Apr 03, 2008
SOURCE: SHARP AQUOS 32 INCH FLAT SCREEN
I had this problem as well guys. Just found a fix thought i'd share.
I simply went into menu>setup>reset . This will perform a factory reset, and you shouldn't have that K or the volume problem anymore.
I tried all the fixes involving volume- input- nothing worked. I tried volume- ch- but that K never changed colours.
It all came down to a simple menu option reset.
Posted on Aug 21, 2009
SOURCE: very little volume, not very loud at highest
On the TV-use your finger to adjust the volume level, about midway, then use the remote to shut off the tv, then turn on tv with remote. Volume level should be better! If still not loud enough...using your finger on the tv...turn up volume & repeat remote steps.
Posted on Jan 24, 2010
Volume automatically goes to the loudest
There should be a setting that allows you to set the "Power On" volume level. Check the menu Under Volume settings.
What is the make and model of the Television set?
Nov 22, 2012 | RCA Televison & Video
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
Mar 11, 2012 | RCA TruFlat 27F520T 27" TV
My tv wont come back on fpa lock on
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy.
Deva
Apr 21, 2011 | RCA 20F420T 20" TV
Very little volume, not very loud at highest
Jan 19, 2010 | Universal Remote Control DIRECTV Universal...
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
Sony 20" TV controls problem
try to disconnect your power inlet cable 110v within 5mn to make a big reset and restart your tv and reconfigure all
Mar 31, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony 27" wont turn off!!!!
It looks like one of the buttons on the front panel is stuck, base on the info you have provided; the volumen down button is stuck. The remote or any other buttons will not be operative until the fault has been remove.
I would suggest to try to press the Vol. down a few times just to see of it unlocks, if that does not work, the front panel assembly will have to be remove and try again if it works with the remote or manually.
The last thing to do if none of the above works, it will be to put a new switch.
Good Luck.
Feb 20, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Volume
just check the volume up and down conector i think there is a shorting in that
Nov 16, 2007 | Sony Ericsson Walkman W810i Cellular Phone
35 in. GE tube TV volume issue
The front panel control assembly, or the circuit area for this panel most likely has a fault condition.
I have also seen some of the button switches fail on the control panel.
Jerry G.
Nov 14, 2007 | GE 35GT740 35" TV
Sony trinitron messed up
pressed a bunch of butons on the tv and the remote means first of all it is due to that buttons as they might be loose fron inside or broken contact. if remote & tv buttons ok check for sound section in tv. if you are not tech person get tech help it is a simple job.
Sep 28, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
57 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
