Question about Garden
Need handle for hedge trimmer - Garden
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Posted on May 24, 2009
rogrrabbit
  • 986 Answers
SOURCE: Expand-It Hedge Trimmer Parts
Belive it or not there is a nice selection at Homedepot.com
Posted on Jun 17, 2009
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Posted on Feb 18, 2010
agent91
  • 2100 Answers
SOURCE: Defective hedge trimmer with a lifetime warranty. How do I file
Contact Us, Warranty and FAQs
We want to hear from you! We are always looking for the best way to stay in touch with you. If you cannot find what you're looking for, feel free to call us toll free at the number below. Our customer service specialists are available Monday – Friday 8 a.m. to 5 p.m. CST, excluding national holidays.
1.866.348.5661 WARRANTY CLAIMSTo request a warranty replacement, please either:
  • Email warranty@fiskars.com with a SINGLE photo, showing your whole product in the picture. Please make sure we have your full name, mailing address (no PO Boxes) and telephone number.
  • Mail your defective/broken item OR a photo of your defective/broken item back to us:
    For Garden Products:
    Fiskars Brands, Inc.
    Atttn: WARRANTY DEPT
    780 Carolina Street
    Sauk City, WI 53583
    USA
    Hope this helps.
Posted on May 06, 2010
Electric hedge trimmer want run why?
electric hedge trimmers have 2 switches to press before it runs
one is the trigger that you pull and the other is in the handle that you hold in your left hand
both have to be on before it starts
it is a safety feature to stop operators cutting off their fingers
Jun 09, 2016 | Little Wonder 2230S 30 Single Side Hedge...
How long should a fully charge battery last on WG250E Hedge Trimmer
This is the info i found on WG250 battery . It says up to 50 min below in the features. Hope it helps
Battery
The WORX WG250 hedge trimmer incorporates an 18-volt 1.7 Ah Ni-Cd battery pack. You can use this battery pack with other WORX Ni-CD PowerShare tools. The included charger takes about an hour to restore a dead battery to full charge.
Cordless Hedge Trimmer 18v Worx WG250E jQuery(document).ready(function($) { $("a[rel=product-image-gallery]").fancybox( { 'transitionIn' : 'elastic', 'transitionOut' : 'elastic', 'titlePosition' : 'over', 'titleFormat' : function(title, currentArray, currentIndex, currentOpts) { return 'Image ' + (currentIndex + 1) + ' / ' + currentArray.length + ' ' + title + ''; } }); });
Features
  • Wall mount bracket
  • 3 position adjustable front handle
  • overmould soft grip for user comfort
  • Quick release handle
  • Double insulated
  • Volts: 18
  • Blade length: 510mm
  • Cutting capacity: 14mm
  • Blade action: Dual
  • Run time: Up to 50mins per charge
  • Charge time: Up to 1 hour
  • Machine weight: 3.1Kg
  • Comes with one battery and a charger
Sep 13, 2011 | Worx Wg250 20inch 18volt Cordless Hedge...
I have an 18" Craftsman Bushwacker hedge trimmer
The wire into the handle may have been pulled and come loose. You will have to take the handle apart to check. They are simple.
Sep 28, 2017 | Craftsman Garden
I have a 14 in. electric chain saw I bought last year and need to download a manual
A hedge trimmer is a type of agricultural or garden tool. And as the name suggests, it is used to trim hedges. There are mainly two types of hedge trimmers - manual and electrical. Amongst these there are some below mentioned variations.
Stand Alone: A stand alone hedge trimmer could be either power driven or manual. The power driven stand alone hedge trimmer uses gasoline or electricity to operate. However, the manual or hedge trimmer driven by human force is best when you consider environmental factors. They are cheaper and easy to operate. Generally gas powered hedge trimmers or electrically powered hedge trimmers are equipped with safety devices. The mechanism is such that they operate only when the operator has both his hands on the handles.
Tractor Mounted: This type of a hedge trimmer is more suitable for pruning of plants and crops. Tractor mounted hedge trimmers either have a movable arm or they do not have a movable arm. The ones without movable arms depend only on rotating blades on a couple of central pivots placed on the tractor's side. Now, these hedge trimmers are best for growing grapes, more specifically for making wine. Small tractors driving between the grape vines are mounted with these type of hedge trimmers, without a movable arm.
Well, this was about hedge trimmers in general. Now lets get down to business. Here's a low down on a few best hedge trimmers. The following is an overview of electrical hedge trimmers comparison.
Hedge Trimmer Reviews
Stihl Hedge Trimmer HS81T: Well, this one is surely up for grabs. Stihl HS81T is a great option for keeping your hedges in a perfect shape. Stihl HS81T is lightweight with balanced design and low vibration levels. It has 24 inch or 30 inch double sided blade length. It's also equipped with rear swivel handle for enhanced comfort at different speeds. The engine power is 0.7 kW and this hedge trimmer weighs between 5.2 kg and 5.4 kg, depending on the blade size. It is good especially for shaping and sculpting your hedge. It does not start on the first pull sometimes, still Stihl is a good option for hedge trimming.
Black & Decker NHT518: Now you would perhaps love this, if you do not want the whole baggage of fuel and electric wires and so on. It is cordless and runs on a battery and 22 inch blades that give a smooth and level cut. It does a neat job of branches less than 1/2 inch thick and you get optional extra battery packs. However, it gets a thumbs down from users with regards to poor battery life. On the other hand the users like the cordless design. Again, they say that it is not as powerful as corded trimmers. Nevertheless, it is lightweight and makes minimum noise. So you can go for it.
Echo HC-150 Petrol Commercial Grade Hedge Trimmer: Well, hopefully most of the users would echo my statement that, Echo is a very efficient hedge trimmer. This is a high performing, commercial grade hedge trimmer powered by petrol. It is a smooth and **** free hedge trimmer and is great for pruning and trimming. Durability is apparently the forte of this Echo hedge trimmer. Superb double reciprocating blades cut on their return and forward strokes, which give a smooth, uniform finish to your hedges. Not a bad choice either!
Makita UH6350 Electric Hedge Trimmer: This is a well designed tool with a great cutting action, according to a magazine on mechanical products. It is light weight and can deal very well with branches upto ½ inch of diameter. Although one of the disadvantage is that you have to bear with a cord and has a single blade operation. A fairly good option if you are thinking of buying a hedge trimmer.
Well, there you go, this was a small list of best hedge trimmers. I hope the hedge trimmers comparison was useful for you.
Take your pick according to your requirements and any hedge trimmer is good so far as it helps you keep your plants in good shape! What say!
for mannual download go to
http://www.stihl.de/safety_manuals/en/heckenschere_englisch.pdf
Jun 15, 2011 | Homelite Garden
I've got a craftsman 22 in. hedge trimmer (electric) and I'm looking an attachment to enable me to trim my hedges, which are approx. 8' tall, without climbing up on a ladder to trim the tops of the hedges....
Un less your trimmer is a split sharft model ie you can take of the blade by undoing a handle then the answer is no you will have to buy a diff trimmer
Jun 28, 2010 | Craftsman 22 in Hedge Trimmer
I have a ryobi hedge trimmer p2601 and the plastic handle broke. Is there a way to get a stronger handle or just a replacement?
May 29, 2010 | Ryobi 18V Hedge Trimmer
Need an online parts catalog to replace handle
This is actually a 2.6A Hedgehog 22" B&D: I found an excellent website at toolpartsdirect.com with an exploded diagram and easy ordering of the parts required.
Jun 04, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Trimer buing Question
Double position trimmers For extended reach while on the ground, a double position trimmer avoids you having to climb up high by allowing you to adjust the handle into a right angle to the blades for a level cut across the top of the hedge. Clippings collector As you trim your hedge, collect those stray cuttings in a clippings collector for a neater finish. Automatic cut out An important safety feature, this automatically switches off the hedge trimmer once the trigger is released. Hand guard For reassuring safety, a hand guard will protect you from the moving blades and from falling cuttings as you work.
Aug 27, 2008 | Corona Hedge Shear 10 1/2" Blade Aluminum...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
