Question about Car Audio & Video
I'm working on a martin audio amplifier ma1.6s model number there is a igbt with the number g4pc50s .is there any other equivalent I can use
Can i turn on phillips hts3455 subwoofer and its amplifier without main unit? Main unit total lost
You would have to find an equivalent main unit or make up an adapter with equivalent function control such as power on-off, volume, etc.
Mar 06, 2017 | Audio Players & Recorders
I just bousght a martin ash home thearer ..how can i conect the bass??
I bought one last night i think its a fake.... doesn't even have instructions. If u figure this out let me know. But i just look up the site called the white van scam... i bought it from some guys in a white truck. And it sounds just like wat they sold me with the same canvas
Apr 18, 2012 | Audio Players & Recorders
Ic problem no sund
equivalant number of amplifier ic number kkz12
May 07, 2011 | Kenwood KDC-MP208 Car CD/ MP3 Player
System cutting out, then cuts back in
Cheak your earth cable and positive at all joins and fuse spots earth should be nice and tight good luck
Oct 18, 2009 | Ranger MARTIN PS-55 KARAOKE MIXER...
Horizontal Output transistor
IGBTs do not work well at high frequencies. They are not very linear, either. Even if it works, you'll likely wind up with a compressed and distorted picture.
Just put in an equivalent output transistor and call it a day.
Peace.
Marco
Feb 04, 2009 | Samsung HCL4715W 47" Rear Projection...
Ive bought a Peavey 1500 pa amplifier and would like to know are the a b knobs on the front treble and bass.If they are how would I take the outputs at the back of the amp to my Soundcraft mixer.
The Peavey A/B controls are output gain controls. Your mixers stereo output goes into the amps inputs, channels A & B. The Peavey is the output stage to your speaker system. If you you connect the outputs from a power amp to the inputs of a mixer you will blow the mixers input stage, amongst many other things and possibly damage the amplifier too. The bias (Bass, Mid, Treble controls) are on the mixer, not the amplifier. Unless you are using a mixer amp, which you are not. A PA system DOES NOT work in the same way as an intergrated hi fi amp.
Nov 07, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
I need he;p!!
Width (mm) - approx.
403.0
Height (mm) - approx.
55.0
Depth (mm) - approx.
277.0
Regards,
Martin
Aug 25, 2008 | Sony XM-SD22X Car Audio Amplifier
Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Dan
May 14, 2008 | Panasonic sa-ht930 Home Theater Audio...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
