Question about KitchenAid Refrigerators
We had a power flicker and now the interior lights on our kitchenaid frig model KSF26C4XYY02 no longer cone on. How do I reset them?
3 Suggested Answers
  • 17 Answers
SOURCE: model rs2534ww side-by-side Samsung frig.
Regarding Samsung refrigerator model rs2534ww/xaa repair: Basic trouble-shooting from Fixya was helpful, but solution required service call from repairman. (Very few repairmen work on Samsung at this time.) We thought problem was the digital controller, but turned-out was ice maker (!). Repairman explained Samsung has wierd control design that is based upon ice maker sensor. Sensor alone cannot be replaced, required entire icer, which he had in the truck. Icer cost $105 retail ($86 online), but controller would have been $161 retail (couldn't find controller online). Hint: if control panel is "dead" except for (only) the upper (horizontal) LED segment of the right-most refrigerator temperature digit, the problem might be your ice-maker. If you find the ice maker online and can install it yourself, you can save at least $130.
Posted on Dec 04, 2009
  • 43501 Answers
SOURCE: Kitchenaid frig model kbfa25erwh. Frig
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Posted on Sep 08, 2010
Kitchenaid superba frig.past 2 days high pitched over temp light alarm goes off every few hrs in between reset we cleaned coils temp in freezer seems fine but frig is not please help
May be frozen up or plugged up. Remove all food. Unplug it and open the doors. Leave for 24 hrs. Clean up any water. Clean out the tray underneath. Usually access from the front if you can pop off the trim panel under the doors. Pull it out. Remove the back. Inspect for large amount of debris. Check any cooling fins etc. use a vacuum with a hose to clean it all out. Plug it back in and try it.
Sep 15, 2015 | KitchenAid Superba KSRG25FK Side by Side...
Kitchenaid KSCS251 from 2004 suddenly stopped cooling/freezing all interior lights work.
If the previous posts do not solve the problem, these fridges frequently have failures in the control board. The control board is no-longer-available from Kitchenaid however is can be rebuilt at The rebuild comes with a 2 year warranty. The turn around time is a few days. The control board may be one of (depending on your full model number): 2252159, 2215946, 2221501, 2221522, 2252071, 2252095, 2252097, 2254739, 1548001, 2223443, 2252111, 2303934, 2307005, 2307028, 8201521, 2304135, W10121049, W10219462, W10219463, W10185291
Aug 07, 2015 | KitchenAid Refrigerators
Ksb 560 mco 5 speed blender lights flicker a as soon as switched
My Blender Model number KSB560MCO does not run. When try to blend all of red lights come one and they blink and move around. Any suggestions what could be wrong? Appreciate any help.
Jul 30, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Exterior and Interior lights flickering
check the ground and power cables most likely broken or loose . now pay me
Nov 20, 2009 | 2003 Dodge Caravan
Water dispenser doesn't work
I have the same problem with a 2002 model. Icemaker working but no ice or water comes out the door dispenser. Also the light in the door is not working (i.e. no electricity getting to the door.)
Just had a service call. They told me that the whole door needs to be replaced because the wires that power the door are broken from normal opening and closing of the door. $1500 repair!!!!!!!
(KitchenAid did a POOR design with this frig. Open your freezer door and look toward the floor. On the left side, you will see a rope-like thing coming from the freezer to the door. Everytime this door gets open and closed, it crimps the wires... and thus, eventually they break.) The newer models have concealed wiring.
Two of my neighbors had the same problem with this frig a few years ago and KitchenAid replaced the door at no charge. I just spoke with KitchenAid. At first they told me that I was out of warranty. When I told them this is an obvious design flaw, they told me they would give me the new door since I have 3 other registered KitchenAid products. I have to pay for the repair service, which will be about $200 plus the $75 service call I had today. Better than buying a new frig.. but still frustrating because of the design flaw.
Aug 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
Our Kitchenaid frig model KSRS25FG is making a clicking sound every few minutes, sort of like a relay switching, at the bottom right behind the grill. The interior fan is running and seems to alternate...
Yes sounds like the compressor starting device failure.
You have not given the full model number. Anyway if the compressor is AC powered 120 V. Not DC powered. Then relay kit part number for Whirlpool KitchenAid this model series will be Whirlpool OEM part # 8201786
Pull the power out until replacing the parts or getting checked. Don't let the compressor burn out.
Local technician may charge you between $ 100/= ~ $ 200/= including parts and labor to change the starting device. Not a bad idea to call a local service guy in your area.
I am in Toronto GTA area and my rate will be in the range of $ 160/= to $ 180/=. But I will most likely use a hard start relay kit. Not the Whirlpool OEM part. Now don't say that I am a rip off guy. That is my rate while another guy may charge only $ 100/=. But I am honest. Not the cheapest
Oct 24, 2017 | KitchenAid KSRS25FG
Amana frig model #TCI18A3L is not running
If the lights are of too, you tripped the breaker in your house. Check and see if you have a ground fault plug near by also. Do you have refrigerator lights?
May 16, 2009 | Refrigerators
As I mentioned previously, I had previously tried a new bulb behind the control panel and it didn't work. I tried again, but first I unplugged the refrigerator, and then installed the new bulb. And when I plugged the refrigerator back in, the light worked!
I am not sure why unplugging the refrigerator before installing the new bulb worked, but it did.
Sep 11, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
