When i turn tv off , the next morning will not turn back on , unless you unplug the power. then it will turn back on. this SONY BRAVIA TV is less than 2 years old.
techman
  • 3130 Answers
SOURCE: tv will not power up
no reset button ,sorry. The problem you describe is pretty common with this model as its a fault in the horizontal drive circuit or in the main power supply and without the proper service manual as well as the prober tools and equipment this set its not gonna get fixed. there are no panels or user changable boards as it is a solid state set. ptscorp.com could repair this board or exchange it with a referbished board but it would still requir some adjustment that a user may not be able to handle. time to call the pro.. Sorry couldnet help ya more.. Good Luck.
Posted on May 24, 2006
SOURCE: Hitachi HD 1080 has blue power light on but no picture
Press the reset button...it's on the bottom to the right (underneath the TV). Same thing happened to me.
Posted on Feb 24, 2008
  • 4234 Answers
SOURCE: Moved Sony Bravia TV, now will not turn on at all
The warranty on this set should be for 1 year. Return it for warranty service. Unless the set was dropped, moving it should not have effected anything. DO NOT open the set sas that would void the warranty.
Dan
Posted on Jun 11, 2008
dsacco86
  • 1077 Answers
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
SOURCE: Picture problem
raystratton
I was wondering if you were able to solve this issue. i am having the same exact issue with my tv. and i did not get an extended warranty thinking that nothing would go wrong with a sony tv. i learny my lesson the hard way. Can you please tell me what the tech told you or what you did to fix this problem. All your help will be greatly appreciated. Thanks once again!!!
Posted on Jul 23, 2009
Bravia TV has pink screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 01, 2015 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
I have a Sony Bravia, Model: KDL40BX450. It's red 'stand-by' light has suddenly gone off and I cannot turn on the TV. What's going on?
I have a sony Bravia 40" LED TV. KDL40BX450.When I turn my set on it has no sound. And the standby light blinks three times and pauses. I have unplugged it. and even reset it to the factory settings. And as long as the set is on the sound works.but once I turn it off. and turn it back on later.it does the same thing again.no sound. what could be wrong .And is there anything I can do to maybe fix it.
Dec 12, 2012 | Sony BRAVIA KDL40BX450 40 Inch 1080p LCD...
I successfully installed firmware update, and the controls worked, but the next morning, the controls didn't work at all, and the tv is dead.
Tv still have power LED light indication,tv still have power wright?Yes.Tries tv unplug,replug it back like an hour later.For the tv resetting itself back to factory setting.See if ur tv take in and reboot up with the new upgraded firmware.
Feb 26, 2011 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My Sony Bravia will play for less than a minute and then reverts to standy. Any suggestions?
Please unplug tv from wall socket for minute or so,, replug back in and turn it On.
If tv still goes to standby itself than its standby light would blink to show an error in somewhere inside tv circuits.
Let me know how many times standby red light blinking? There would be 3 seconds long pause in blinking so count pause to pause to determine problem section.
Thanks.
Jun 13, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
52'' Sony Bravia will not turn on
Its fixable problem like power supply board replacement will solve the problem.
Unplug tv from wall socket for couple of minutes, replug back in and turn it On.
If problem still exist then most likely power supply got fired and will be replaced, local tv repair shop will help you to replace power supply board.
Thanks.
May 02, 2010 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
Sony Bravia KDL-46V3000 turns off with blinking front light.
Sounds like the power supply may be failing. Count the beeps next time, that will give you the error code.
Jun 18, 2017 | Sony BRAVIA KDL-46V3000 Television
My sony bravia tv will not turn on, the light on the bottom comes on but the screen is completely blank. i was watching it two hours earlier and i turned it off myself. than it didnt work when i tried...
Do you have...a dvd player a ps3 a box?
Becouse if you have, you need to change the input and maybe you forget to put it right back.
Imagine you have a ps3, you have to change the input from tv to HDMI right..well if stop play or watcha movie and torn off the LCD...when you came again the next day the LCD starts as HDMI and not as TV.
You need to change the input...
Hope it helps, if the problem persists it´s a malfuncion...
bye
Cyber
Mar 27, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia periodically has loss of sound. Sound
then contact TECH support again . you have a warranty do you not ?
Nov 28, 2017 | Sony BRAVIA KDL52XBR2 Television
Sony KDL40S2010 Bravia LCD TV... turns off / on on it's own
If TV does not remain in standby and turns on itself then power switch on top of it could be defective and power supply board is also suspected. Take off its back cover and unplug top switch connector just to confirm is that cause of On-Off its own. If problem still exist then power supply board has problem and will be replaced. Let me know the results to move forward.
Jun 13, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Dan
Jun 11, 2008 | Sony BRAVIA KDL52XBR2 Television
Televison & Video Logo
Top Televison & Video Experts
