Question about Ariens Garden
Belt broke on my ariens ezr1540 I want to know how to put back on with two fans and two pulleys and tensioner in back of mower. Thank you for any help. Ron
  • 4 Answers
SOURCE: replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Posted on Nov 01, 2008
  • 341 Answers
SOURCE: drive belt tensioner pulley
the tensioner pulley is a small plastic or metal wheel about 3 inches big ...center of engine....
Posted on Dec 11, 2008
luv2tango
  • 36 Answers
SOURCE: how do i release the tension pulley
Usually the carrier pully "tension pully" has a square hole in the front of it. It usuallu takes a 1/2 inch breaker bar but occassionally they will use 3/8 breaker bar. Find the hole, insert breaker bar, or a ratchet (you may need a pipe on the ratchet) and put pressure on it. Generally counterclockwise is the direction you need to go. That will release the tension on the belt while you are maintaining pressure on the breaker bar while it is inserted in the pulley. Remember how the belt is routed.
Posted on Dec 27, 2008
  • 114 Answers
SOURCE: 1994 chevy cavalier fan belt came off how to put back
Depending on how much of the bolt broke , you may be able to get it out wit a pair of vise grips or an extractor bolt. If it broke flush to the engine block you'll have to drill it out and try to exctract the rest. I would highly recomend leaving this part for a mechanic with experience to do because if you don't do it right it will cause more damage than you want to deal with. at this point I would say to have it towed to a shop and let them extract the broken bolt. this is not something you want to try yourself if you haven't done it before. Best of luck
Posted on Dec 30, 2008
  • 398 Answers
SOURCE: audi serpentine belt problem
are you sure you put it on the right way go to autozone.com and get a belt diagram. did you put the belt on upsidedown?
Posted on Mar 07, 2009
How to I tell if the tension is correct on a Arien zero turn belt?
Most modern lawn mowers including ZTRs all using an automatic belt tension system; ie spring load idler pulleys. The only time you need to check the belt is when your are having problem and most time the belt will need replacing due wear or physical damage.
Nov 29, 2014 | Garden
How do i replace belt on ariens
The best method is remember pulleys with flat sides run on the outside of the belt and "V" shaped pulleys run inside the belt. The owner's manual should show belt routing or go to www.ariens.com and download a parts list. This should help you determine the belt path.
Oct 19, 2014 | Ariens 42" Riding Lawn Mower Blade ...
How to relace drive belt on ariens tractor a20va46?
There are multiple belts on the Ariens A20VA46 lawn tractor. Which belt are you asking about?
Service and Owner's manuals can be downloaded from the following link: Find Manuals by entering your tractor's model and serial numbers.
The deck drive belt is easy to change by releasing spring pressure on the idler pulley (usually under a plastic cover). See the user's or service manual for directions from the above link.
The two transmission belts are somewhat more difficult, but are usually long-lasting. The newer type of continuously variable transmissions used on these tractors have a friction belt like a snowmobile but under much less load. As a result, they are long-lasting. The engine to transmission belt is a conventional V-belt and may require occasional replacement. Usually, there's a similar tensioner pulley you would release in order to replace this belt.
Jul 14, 2014 | Ariens 34 In. Zoom Series Riding Mower
I have a Sears Garden Tractor with a 48" mower deck. By working in long, thick grass I broke the mower belt -- not the one that transmits power from the engine, but the belt that sits in a pulley on...
I believe that tensioner pully has to be loosend up and moved.
Here are the instructions for this.
  • Place the deck in the lowest position using the hydraulic piston (if applicable) or the manual cutting-height adjuster.
  • 2
    Remove the deck-to-PTO belt from the PTO by releasing tension on the idler-arm pulley. This is a spring-loaded handle that turns in only one direction by hand and relieves the tension on the belt. Slip the deck-to-PTO belt off the PTO pulley after the tension is relieved.
  • 3
    Remove the deck from underneath the mower or tractor.
  • 4
    Locate any belt stops and loosen them with the ratchet wrench and proper socket. Belt stops are located on the deck and are the small metal brackets that guide and secure the belt to the pulleys so it will not jump off when under heavy use, or stretch from normal wear.
  • 5
    Remove any pulley covers by removing the retaining screws using the ratchet wrench and a socket.
  • 6
    Loosen the idler-pulley retaining bolt (located on the underside of the mower deck) to replace the deck-to-PTO belt. Removing the bolt is not necessary. Loosen the pulley enough to wiggle the belt free from the pulley and remove and replace the belt.
  • 7
    Remove any arbor covers (if applicable) that conceal the arbor pulleys by removing the retaining screws with the ratchet wrench and a socket to replace the mower arbor belt.
  • 8
    Locate the tensioner pulley on the mower arbor belt to replace it. Loosen the tensioner pulley bolt enough to slide it and release tension from the belt. Remove the belt from the arbor pulleys and replace it.
  • 9
    Slide the tensioner pulley back leaving about 1/2-inch of play in the belt and tighten the bolt. Reverse the procedure to put the rest of the mower deck back together and reinstall on the mower or tractor.
  • May 10, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
    Cahnging drive belt on mower
    dont understand your question ... get the belt ... it was designed to fit ... there are probably at least three pulleys. put the belt around the motor pulley and the trans pulley then figure out how the clutch or tensioner pulley interact with it.
    May 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
    Ariens 1440h cutting problem
    moz-screenshot.jpgGo to this site: http://www.ariens.com/corporate/pages/partsradar.aspx (copy and paste in your address bar)
    follow the instructions given and you can download a VERY GOOD picture of where it goes
    Sep 29, 2009 | Garden
    Belt systme view - how all belts are hooked up
    you have 2 pulleys going to the blades, 1 pulley coming from the pto, and a belt tensioner. the belt goes on the outside of the pto, outside left side blade, inside belt tensioner, out side right side blade.
    Aug 16, 2009 | Ariens 34 In. Zoom Series Riding Mower
    G-110 deck belt keeps jumping off pulleys
    check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
    Aug 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
    Ariens sierra 1440G belt configuration
    Hi, you may have more than one problem. There should be one belt from the mower deck going to the electric clutch pulley which is on the engine shaft. On the shaft there are two pulleys, one belt comes from the mower deck, and the other comes from the transaxle pulley. check to see if your belts are in the right areas.
    If this doesn’t work for you, please write back. Thanks,
    Nov 27, 2008 | Ariens 34 In. Zoom Series Riding Mower
    Garden Logo
    Top Ariens Garden Experts
    Roland W VanLue
    Roland W VanLue
    Phil Walker
    Phil Walker
    Matt Olenzek
    Matt Olenzek
    Are you an Ariens Garden Expert? Answer questions, earn points and help others
