I have a Pro-Com ventless heater and the igniter won't spark, what do I do
4 Suggested Answers
freetek
  • 5568 Answers
SOURCE: pilot flame does not reach the ignite point(VENTLESS SPACE HEATER
The pilot jet may be contaminated with with oxidized metal particles; wipe its 'nose.'
If that doesn't help, most of the regulators on gas appliances have a small screw to adjust the flame length/height.
Posted on Dec 02, 2009
  • 3315 Answers
SOURCE: the pilot light goes out...what do I need to check
Hi check the pilot is clean and check thermocouple is not brunt out
Posted on Feb 19, 2010
mxc2
  • 146 Answers
SOURCE: heater will ignight and burn for about 5min. then
Cleaning the Pilot/ODS is parts of what should be done but you should also check the thermocouple.
Here is a link to the instructions:
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
This should take care of your problem if this does not take care of the problem then you may need to replace the thermocouple.
Posted on Oct 04, 2010
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
I hava an All Pro 65,000 BTU heater. It was working fine a week ago. The igniter glows, fuel mists but doesn't light off then shuts down. Ideas?
I am sure you have confirmed that the fuel is fresh and good, no water in it, etc.--
It is kerosene, not #2 Diesel fuel, right?
And the shutting down is good, if the flame does NOT ignite--- :-)
So we have to figure out why the fuel is not getting hot enough to ignite?
Question-- is the oil spray passing close enough to the ignitor?
And this unit does NOT use SPARK to ignite?, correct? --
for most of these heaters have spark ignition.. I am learning all the time, too!
How about checking the fuel pressure. and the air -- is it correct?
Check with your manual how to check and adjust.
After testing these tings, let us know what you learned
Mack B
Jan 15, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Pilot flame does not reach the ignite point(VENTLESS SPACE HEATER
Dec 02, 2009 | All-Pro SPC-20 Heater
All Pro K75 will not ignite. Spark igniter does
most kerosene heaters are basically the same - reddy heat, dynaglow, desatech are all the same. there's a small air compressor built into the axially mounted fan that points forward. the air pressure needed for fuel is 3-5 psi not less, not more! the air feeds through a side inlet to the fuel nozzle where it creates a vacuum venturi to **** fuel from the tank and propels it through a fan nozzle. the aerrated fuel hits the hot surface or spark and ignites. as long as there is heat and air the heater should function.
Oct 22, 2009 | All-Pro Forced Air Kerosene Space Heater...
Pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
100,000 btu all-pro kerosene heater
i have a 100 000btu/hr the ign. plug is bad wher in ga i can find one arer macon ga
Jan 22, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
All Pro Heater
most parts for kero heaters are interchangable. go to desatech dot com for parts. check for a reset button for your heater. if no reset, does the fan run? your unit can use one of two ignition parts. a spark generator with a spark plug or a hot surface igniter. the unit uses a cad cell flame detector. you might need to replace this.
Nov 18, 2007 | All-Pro Kerosene Garage Shop Heaters - All...
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
