Question about Tablets & eReaders
Getting my Kindle to rejoinze wi-fi - Tablets & eReaders
  • 3278 Answers
SOURCE: how does one turn on
Hello.
Sorry, but the Kindle 2 lacks a backlight function according to all reviews found on the subject.
Hope this helps.
Posted on Dec 21, 2010
  • 457 Answers
SOURCE: I'm trying to connect my Kindle 3 to my wireless
Four reasons come to mind that may prevent you from connecting:
  1. Wi-Fi Passwords are case sensitive. Please check again if you entered the password with proper casing and you did not put any extra white space in front or behind. I know, this sounds annoying, but it is really the most common cause for connection problems.
  2. Give your network a unique SSID. This is the network name that shows up in the list of detected networks. Default names like LINKSYS can be troublesome if a neighbor one block down the street happens to have a router from the same company.
  3. Some routers have a MAC address filter as a security measure, limiting service to devices specifically whitelisted. If your router is set up for this, add your Kindle's MAC address to the list of permitted devices. See your router's configuration under Wireless > Wireless MAC Filter. You can check the MAC of your Kindle from its settings page (press HOME, MENU, select SETTINGS, see paragraph headlined "Device Info".
  4. There are twelve different standards for Wi-Fi transmission collected under the hood IEEE 802.11. The four most dominant transmission modes are called a, b, g and n. They differ in radio frequency, modulation method and data rate. Kindle supports the two standards IEEE 802.11 b and g only, which is not really a problem because all wireless routers I ever encountered support one or both of these, too. However, the Linksys N-series can be set up to use 802.11n exclusively, not allowing for b or g connections. In the router menu Wireless > Basic Wireless Settings (Manual Setup), make sure the network mode is configured as "Mixed".
Please add a comment to this solution if one of these items resolved your problem. If you suffered from a different issue I did not think of, it would be nice to drop me a line, too. Other people will benefit from any experience you made.
Posted on Jan 15, 2011
  • 51 Answers
SOURCE: My kindle wi-fi is not working. I went to turn it
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Posted on Mar 01, 2011
  • 51 Answers
SOURCE: kindle is jammed on wi
Firstly, make sure that your kindle is fully charged. Then hold the power switch for 7 seconds. After the light blinks three times, release it. If this does not unfreeze your kindle, hold the power switch for 15 seconds. This should restart your kindle. If neither of these solutions work try contacting amazon kindle support, as they can remotely connec tto your kindle and see what is wrong.
Cheers
Sine Wave
Posted on Mar 02, 2011
  • 51 Answers
SOURCE: Kindle 3 wi-fi - no response when switched on -
If the 15 second reset does not work, I would suggest contacting amazon. They can connect to your device and see if there is something wrong with your actual kindle. If there is something wrong they are usually pretty good about replacing broken kindled :)
I can't access the kindle store
Are you out of your usual wi-fi area? You may need to go back and check wi-fi settings and set up again.
From Home or any Settings screen, view the wireless indicators at the upper right corner of your Kindle. While reading, tap the top of the screen to view the wireless indicators.
Wireless Indicator Description Your Kindle is connected to 3G. This may also say EDGE or GPRS.
Note: For 3G enabled devices only Your Kindle is connected to a Wi-Fi network and has a strong signal. The Wi-Fi symbol appears when in range of a trusted Wi-Fi network.
Dec 10, 2016 | Amazon Tablets & eReaders
I'm having trouble connecting my new Kindle to my wi-fi
trouble connecting my new Kindle to my wi-fi Mary, Check the attached links,instruction and guides to get kindle connected, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Can Connect Kindle 5th Generation to Wi Fi
Fix Kindle HD WIFI problem EASY
kindle won connect with wi fi
12 major Kindle Fire problems and how to fix them
Aug 03, 2016 | Amazon Kindle Paperwhite
How do I change the password on the kindle for the wireless network?
To add a new Wi-Fi Network:
If you don't see the network you want to connect to in the list of detected networks, you can add it by choosing "Enter other Wi-Fi network" at the bottom of the list of detected networks.
  1. Make sure you are within range of the network you want to add, and that you know the network name and password (if required).
  2. Press the Home button, then press the Menu button.
  3. Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  4. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks.
  5. Use the 5-way controller to navigate down to "Enter other Wi-Fi network" and press to select.
  6. Enter the name of the Wi-Fi network that you want to add.
  7. Enter the password (if required). Press the Symbol key to enter numbers or characters not present on the Kindle keyboard. You can continue to use the keyboard while the Symbol menu is displayed.
  8. Choose "submit." Kindle connects to the new Wi-Fi network.
If your Kindle fails to connect to the new Wi-Fi network, it will display an "unable to connect" message. You can try manually entering all the network information for the Wi-Fi network by choosing "set up network" when you see the "unable to connect" message. If you don't know the network information, try connecting to a different network, or contact the network's administrator.
To forget a Wi-Fi network:
You can tell Kindle to forget the Wi-Fi network you're connected to so that your Kindle doesn't connect to it automatically in the future.
  1. While connected to the network that you want to forget, press the Home button, then press the Menu button.
  2. Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  3. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks. You may have to wait a moment as your Kindle detects networks in range. The Wi-Fi network you are currently connected to displays the word "forget" next to it in the list of available networks.
  4. Choose "forget" to disconnect from the network.
To connect to a Wi-Fi network:
  1. Press the Home button, then press the Menu button.
  3. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks. You may have to wait a moment as your Kindle detects networks in range. Kindle automatically scans for available Wi-Fi networks at periodic intervals. To rescan for available networks at any time, select "rescan."
  4. Select "connect" to connect to a network. If you see a lock symbol next to "connect," the network requires a password to connect.
  5. If necessary, enter the Wi-Fi network password, and choose "submit." Press the Symbol key to enter numbers or characters not present on the Kindle keyboard.
Once you are connected to a Wi-Fi network, Kindle automatically connects to it again whenever that network is in range. If more than one previously used network is in range, your Kindle automatically connects to the network that was most recently used.
Tip: Once your Kindle connects to a Wi-Fi network, that network displays "forget" next to it in the list of available networks. Selecting "forget" disconnects your Kindle from that Wi-Fi network and also prevents Kindle from automatically connecting to it in the future.
Mar 07, 2016 | Tablets & eReaders
How do I convert a wireless wi fi kindle to my pc. I do not have access to wi fi.
Not sure what you are asking. If you have internet service, you could purchase and install a cheap wi-fi router after the modem. This will provide you with local wi-fi service, which you can use with your Kindle. Just follow the instructions for the router to properly set up and secure.
Mar 03, 2015 | Tablets & eReaders
How do I connect to the kindle store my kindle will not connect so I may download kindle books?
To connect to the Kindle Store your device must have either a wi-fi connection to the Internet or a 3G Whispersynch connection via a telecom. Some Kindles come with the 3G and some don't. The ones that don't require a Wi-Fi connection.
So, if you have Wi-Fi access the turn off Airplane mode in Settings and enter the Wi-Fi password to your router. If you are using public Wi-Fi such as at McDonalds you might have to
use the experimental browser in setting to be able to click the *accept terms* button or you will not have access even if connected.
Feb 26, 2015 | Amazon Kindle Paperwhite
How to tune in kindle to wi fi?
From the Home screen, press the Menu button.
Select Settings, and then select view next to Wi-Fi Settings.
In the list of detected networks, choose a network to connect to it.
If your Wi-Fi network and router support WPS (Wi-Fi Protected Setup), your Kindle will detect it.
If you don't see your network in the list, you need to add the network manually.
If the network is protected by a password or WPS (Wi-Fi Protected Setup), enter the password and then select Submit.If you don't know the Wi-Fi network password, contact the person who set up the Wi-Fi network.After you connect to a Wi-Fi network, your Kindle automatically connects to it again whenever that network is in range. If more than one network is in range, your Kindle automatically connects to the last network used.
Aug 16, 2014 | Amazon Kindle Fire HD
Cant acess my wi fi on my kindle fire as it needs my parental password which i cant rember
Not positive but think you will have to unregister the Kindle and then re-register it. You will lose everything.
Mar 09, 2014 | Amazon Kindle Fire HD
I can not or do not have a password for the sky wifi how do i get it
If the sky wi-fi is your own wi-fi service then the password is normally on a typed label stuck to the wi-fi router itself along with the SSID of the wi-fi network which should be the same as you have selected on the Kindle in confirmation you are connecting to the correct network.
If the sky wi-fi is not your own wi-fi then you will either need to contact the owner or administrator of that network or select a different wi-fi network to connect to as described in the Kindle Support web pages for your device.
Dec 27, 2011 | Amazon Kindle Wireless Reading Device
Tablets & eReaders Logo
53 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
