Where can find batteries for mp3 players? - Audio Players & Recorders
How long does it take to charge,and how long doe it hold a charge?
MP3 Player Battery Guide ยป Anything But iPod
anythingbutipod.com/2010/01/mp3-player-battery-guide/
Jan 11, 2010 - Any modern MP3 player with a rechargeable battery will have a lithium... If you want to geek out with battery information, take a look at the info ... Battery life meaning how long the player will last on a charge varies .... This means that the player will be a lot bigger than it should simply to hold the batteries.
Amazon.com: Customer Discussions: How long does your kindle
Dec 01, 2015 | Audio Players & Recorders
Can't turn on my mp3 player. I have tried to hold the volume buttom but it does not turn on at all.
what type of mp3 player ?
Charge your MP3 player.
The battery might just be dead, in which case letting it charge for a few hours corrects the problem.
Plug the USB data cable into the USB port on the MP3 player and insert the other end into one of the USB ports on your computer.
In a moment, the computer states that it has detected the removable device.
Sometimes the MP3 player needs to update itself, and it can only do so while connected to a computer.
When the MP3 player detects the computer, it attempts to connect to the Internet and retrieve any system updates available for the device.
Replace the battery.
The battery is usually the first part of the MP3 player to go (especially after excessive use). Although you can manually change the battery on most MP3 players, you need to send your
Apple products (iPod, iPod Nano, iPod Touch, iPhone) into the company so they can change the battery for you.
Purchase a new MP3 player.
If your MP3 player has received any sort ofwater damage, it is not going to turn on at all and there is nothing you can do to fix the issue.
hope this helps
Sep 27, 2012 | Audio Players & Recorders
I plugged my sansa e280 into a ipod speaker system and now battery is not working. Did I burn it out or hurt the player? It got real hot and I couldn't turn the player off after I unplugged it from the...
You could have fried it if it overheated. If you have a friend with this same mp3 player, try to swap batteries and see if the battery is the problem or if it is the mp3 player itself.
May 09, 2009 | SanDisk Sansa E280 MP3 Player
Hasbro Made for Me Digital MP3 player
There are 4 batteries in the MP3 Player. 3 operate the larger part of the unit. One runs the Music storage device. Changing out that battery should do the trick!
Jan 06, 2009 | Hasbro Playskool Made For Me MP3 Player
Battery
The most likely culprit is not shutting off the MP3 player before you replace your battery. Whenever you cut the power source without giving the MP3 player a chance to save its settings, it re-syncs the music. Shut off the MP3 player completely before taking the battery out and it should not have to re-sync next time you start it up.
Jun 10, 2008 | iLO (2 GB) MP3 Player
Charging the battery on a sansa mp3 player
Do you have the USB cord and a laptop? you plug those into each other to charge it or you get the DC adapter.
Apr 30, 2008 | GPX MW3837 MP3 Player
This MP3 player does not have a rechargeable battery. It uses 1 AAA battery which will last for days
Apr 30, 2008 | SanDisk Sansa m240 MP3 Player
RCA MP3 M51 series
This mp3 doesn't charge your battery.
Try using a standard alkaline battery to power it
Jan 24, 2008 | RCA Lyra RD1072 MP3 Player
I have a coby MP3 player (MPC-848 256 MB MP3 player)
try to insert it to your usb port, if your computer detect your player maybe there is a problem in your battery or in your battery terminal.
Jul 27, 2007 | Coby MPC-848 MP3 Player
27 people viewed this question
 Grubhead
Grubhead
