Question about Golf
I have 1994 ezgo gas golf cart over heats solenoid
  • 1,162 Answers
Is this an electric one? If so there is not much you can do but replace it. The internals are know for corrosion an after time build up a green color inside that hinders flow of electricity.
Posted on Jul 24, 2017
SOURCE: I ned a service manual for a 1995 ezgo dcs golf
Our EZ GO golf cart will start and run except you have to hold the choke about half way out for
it to continue to run. What is wrong?
Posted on Apr 20, 2009
  • 10865 Answers
SOURCE: need battery wiring diagram for 1987 ezgo golf cart
Tell me what cart you have and i can help. Not all carts get wired up the same way as this link demonstrates. In the pix pay close attention to how battery one gets hooked up as this sets the pattern
Posted on Aug 19, 2009
  • 166 Answers
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
Posted on Mar 07, 2010
  • 34 Answers
SOURCE: I need a wiring diagram for a 1986 ezgo golf cart,
use this link
Posted on Apr 21, 2010
  • 34 Answers
SOURCE: EZGO golf cart won't go forward
Your batteries have died. The reason it will barely move in reverse is that current is being supplied to the motor is a direction that it spends very little time using. There is a slight change in the armature over time, and reverse tends to work better over time. Check the voltage when under load. (run jumper wires from the + and - of the battery bank. If it is a 36 volt cart and the voltage drops to below 36 volts, you do not have enoug current to run the cart. Plug in the charger and watch the ampmeter. If it goes up to about 20 amps, then it is charging. It should take a good charge after 10 hours. If the cart charges and only runs a short distance, the batteries need replacing.
Posted on Apr 24, 2010
Ezgo golf cart bucked then died. new batteries and solenoid. What happened?
Does solenoid still click? If it does then I would check the motor wires to see if they are still connected. If ok then I would check the forward/reverse switch assuming you have a Lever type mounted on the body of the cart.
Aug 31, 2017 | Golf
Looking for wiring diagram for 1999 TXT EZGO golf cart controller?
There are a ton of them available, apparently:
Aug 02, 2017 | Golf
Ezgo 36 volt buggy i have 2 one in good running order other one not going now solenoid not clicking have swwapped solenoid and controller to good running cart and it works problem cart still problem
Hope it's fixed by now. If the solenoid is not clicking then one of your switches is bad or wiring. Check the key switch, forward/ reverse micro switch, and the switch in the floorboard that is connected to the gas pedal.
Apr 19, 2017 | Golf
I recently came across an ezgo golf cart I noticed I m leaking gas out of the petcock valve and was wondering if I can bypass it?
Hi, Sally I would "NOT" recommend bypassing the valve just replace it for more information about your question and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
Product Manuals
GO Golf Cart Parts
Cartaholics Golf Cart Forum EZGO Golf Cart Repair
Apr 09, 2016 | GAS Motorcycles
Ezgo golf cart solenoid will not work. 36v on battery side 28v on controller side. If the resistor is faulty will this cause the solenoid not to work?? when I push the pedal?
Solenoid valve is the use of electrical energy flowing through the coil generates electromagnetic suction spool (or self-gravity to overcome the spring) attracted Sectional normally open and normally closed two categories typically used to cut off the flow of oil, water, gas and other substances. With pressure, temperature sensors and other electrical equipment to achieve automatic control. Car Diagnostic Tool
Jan 02, 2016 | EZGO 1995-99 DCX600 Controller 600 Amp...
Solenoid clicks. Why doesn't it go?
Need to know what kind of cart you have. Ezgo, Club Car?
36 volt, 48 volt ? for ezgo look at manuf. code, for club car serial number has the year. Then maybe we can figure out something.
Sep 09, 2015 | Golf
Ez golf cart when I go up steep hill the cart loose power and smoke White smoke
Basic EZGO Golf Cart Problems And How To Fix - > Golf Cart Repair
Apr 30, 2010 - Electric E-Z-Go Golf Carts are becoming more popular every day ..... I have a ezgo carryall gas golfcart. it has began to pour smoke from rear.
Aug 02, 2015 | Cars & Trucks
How to troubleshooting sylnoid on 36 volt ezgo golf cart ?
goto buggies gone there are several forms that share this information on how to check a solenoid. You can also call golf cart kings in Austin Texas. They will tell you exactly how to check the solenoid. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Aug 31, 2014 | Golf
36 volt ezgo
First of all, lift rear axle off the ground and place blocks or jack stands underneath. Check to see if you have 36 volts On your batteries. Now you want to run a jumper across the big cables on the solenoid. Press the accelerator and the motor should engage. Clicking is a pretty sure sign that the solenoid is bad. Please let me know if this is useful. I can further elaborate more troubleshooting if this doesn't solve your problem.
Aug 06, 2014 | Performance Plus Carts EZGO Golf Cart 36...
Golf Logo
251 people viewed this question
Top Golf Experts
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
