Question about Garmin StreetPilot i3 GPS Receiver
Battery New unit; battery charger is not charging?
Try getting a universal plug in for your house and plug it in and charge it up just be sure that the transfomer is a step down to 12 volts dc . also the data (usb) up date plug i hear can be used on your pc at home to charge you battery. this is what i tried and both worked. also dont let the unit stay in the car with sub zero temps, that seems to hurt the battery.
good luck
Posted on Jan 25, 2009
As already suggested, there is no internal charger with the i3, the reason you have the choice between nihm and alkaline batteries is so the unit can give an accurate batterie life
Posted on Dec 19, 2007
There is no battery charger with i3
Posted on Dec 10, 2007
There is no rechargeable internal battery, AA only.
Posted on Dec 09, 2007
Xantrex XPower PowerPack 300 will not charge even after replacing both battery and adapter. What else can I try?
Either charger has an issue or new battery is boogus. Check charger output for specs. Subject battery to a few discharge/charge cycles. If charger is definitely good and battery will not charge fully after a few cycles then you have confirmed that new battery is bogus.
Sep 06, 2017 | AMP Computers & Internet
Will not run on battery. charged battery but will not hold charge.
Hi Martha, had a bit of a look around and noticed a few mentions of charging problems including the following - 'One of these units was apparently dead on arrival and on further investigation, it worked off mains but not from battery. The battery comes out from a flap underneath the unit, and on testing with a multimeter, it was under voltage, so must have been old stock. Despite 2 days of charging, no life, so I ordered a replacement battery (RITAR RT1250 or equivalent 12v battery) and it works fine. I also have a proper battery charger rather than use this unit's own charger, which charges the battery rapidly, but I think at the cost of battery lifespan. Given that I use this unit infrequently, this is fine, otherwise use the internal charger as normal. With the new battery, I've never managed to run out of battery.. it will keep going all day on a single charge.
The manual does state that if you don't charge the unit at least every 6 months, it may not charge.'
I know it's not exactly a resolution but hope it helps!
Jun 16, 2015 | ION Audio Tailgater Portable Pa System For...
My RCA tablet won't turn on and will not charge, what can I do?
If battery is depleted, then no, it will not turn on.
If battery charger is dead, phone won't charge or turn on.
If battery charger cable is broken, tablet won't charge or turn on.
You need to ensure you have a good working charger, and a good cable. Only a known good charger and a known good cable can charge the unit. Borrow or invest in a new charger and cable (they're cheap on eBay).
Only once you know the charger and cable are good can you determine that they are not the problem.
Depending on how old the unit is, it's possible the battery can no longer hold a charge and needs to be replaced. You won't know that though until you first determine the charger and cable you're using are working properly and providing a good charge.
May 07, 2015 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
Blue light on, battery won't charge, unit new 12/14/09
rechargeable batteries are definitely a better bet. I have used many Wii battery packs and chargers, none seem to last very long.
Jun 05, 2010 | Nyko Wii Fit Battery Pak for Nintendo Wii
Fairly new unit will not charge
there two things that would not make your new unit charge, its either the charging port is bad and needs replacement, or the charger in which you are using to charge the unit is faulty.
So test the charger with another unit to know if the charger is the one that is faulty or the charging port.
You still have the option of using a desktop charger to charge the battery.
Take care.
Apr 15, 2010 | Nokia 2760 Cellular Phone
New charger
it may not be the charger on most occations have the battery checked out at your nearest cellphone tech. to find out if you need a replacment battery
Jun 15, 2009 | Duracell AAA NiMH Battery Charger with 4...
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
Wii charger not charging
problem is either one battery is discharged and the other is full or corrosion on battery terminal tops or batteries are defective. the red lights flash when the unit sences that the batteries have a problem with the induction charge. simple test is to using a meter measure the batteries or discharge the unit with a wire and a 2.2 volt bulb (flashlight bulb) once discharged, unplug the charger unit for over 10 secs to reset it. then plug it in and try the batteries in the packs again. if still inop then they are done for.
Aug 15, 2008 | Nintendo Wii Console
Nuvi 200 GPS
We did not have a charger to plug in the GPS to charge, so my husband plugged it into a battery charger. I guess the battery charger was low, so it drained the unit rather than charging it. It was so low it would not come on again. I have an electric charger that adapts the car charger into AC current, so I tried that and the unit came on. Problem solved and the GPS is working again. Thanks for responding.
Jun 20, 2008 | Garmin nuvi 200W GPS
Dead battery won't recharge
if it still new and you've still got the warranty then you should ask for replacement of the whole unit.
seems that the problem of your phone is the unit itself, the charging circuit migth have disorders/malfuntioning.
ever tried checking for the specifications and directions for charging the unit.
i greatly suggest that if you got the warranty still, have it replaced.
good day!!!
Feb 28, 2008 | Motorola Mobility RAZR V3
Garmin StreetPilot i3 GPS Receiver Logo
73 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
