Thank you for posting your question here on Fixya.com.
Please explain what you mean by "checked the brakers, ran an extension cord to check the outlet, checked to see the motor will run manually and it will". I assume you mean the breaker in not tripped. What I am unsure of is how you would use an extension cord to check an outlet and what you mean by the motor runs manually.
If you have a power-flo matrix and it is plugged into a 115 volt outlet and by manually you mean you can spin the pump by hand and it turns freely and you have tried to plug something like a radio into the outlet to ensure it works then the problem is the motor or its on/off switch.
If a radio or some other item plugged into the same outlet also doesn't work you'll need to look at the electrical system.
Please add a comment to address what your situation is if this doesn't help.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
