SOURCE: Cannot find VESA holes...Samsung Syncmaster 970p
I have looked at the specification for this, and although it does show as being VESA compatible (This is a display standard) There is no mention of any "wall mounting" capabilities at all, which would lead me to believe that this is not designed to be put on a mount. also the "Magic Rotation" Technology which is part of this device may rely on it using the proprietory stand, it may well be possible to remove the stand however, but it would require some significant dissasembly as the power connector is on the signal box, and this would need to be seperated from the stand itself. The mounting bolts look to be hidden behind the round pivot cover on the back, and it may be possible to see if mounting is possible simply by removing this, however I would seek information from the manufacturer about this as removing any of the covers would most likely invalidate your warranty, it is possible that this was missold to you and you should be able to take it back as not being fit for purpose.
SOURCE: Need Samsung Syncmaster 450b monitor driver
Download from here:
http://www.samsung.com/us/function/search/resultList.do?otherWords=Syncmaster+450b+driver%7C&searchWord=450b+driver&sort=0
SOURCE: samsung monitor and mac os
Please do not adjust RGB unless you know what you are doing.
For critical color work, you will need to use a photospectrometer and calibration software to analyze what your monitor is spitting out.
There are a million obvious reasons you should not trust your eye making arbitrary RGB adjustments off the hip.
SOURCE: How to open the back cover of Samsung SyncMaster 794mg CRT .
"Don't kill yourself just to save some bucks"
Here are the instructions:
http://www.josepino.com/?open-samsung-back-cover
Testimonial: "very thanks...."
