Question about Necchi Sewing Machines
I have a necchi pl1020. I need the needle set screw and I can't find one. Any ideas?
    Top Expert:
  • Necchi Master
  • 48,235 Answers
Talk with any sewing machine repair shop as the screw will be generic
Posted on May 09, 2017
Necchi needle bar screw
it would have been helpful if you had provided the model number of the Neechi sewing machine.
But if you go to this website you should be able to locate the correct part for needle bar clamp and screw.
Necchi Sewing Machine Parts
Aug 05, 2014 | Necchi Sewing Machines
Necchi 3205 FA: Seized
It may not have seized there may be a very small piece of thread jammed in the raceway area, you need to take the bobbin case and the raceway out to check
Sep 25, 2013 | Necchi 3102 Mechanical Sewing Machine
Can't get the tension or the stitches to regulate
try a tension setting of 3 or 4
my mechanical necchi is set on 4, but the tension should be adjusted according to the fabric & thread & needle
here's a tip for needle & thread compatibility
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 26, 2010 | Necchi 6030 Mechanical Sewing Machine
Needle not going up and down on necchi 544
There should be a button in the balance wheel on the left side of the machine. Not sure on your model, but most of the Necchi's pull out and push in. That disenguages the needle arm to wind a bobbin. Some of them screw in or out, but generally pull out. You might try pulling it out and then pushing it back in, until it clicks. Then it should work fine.
May 13, 2009 | Necchi 3537 Mechanical Sewing Machine
I need to find needles for my necchi model 3101FA in Wisconsin
Your machine uses standard needles. 15x1 system 705 sizes 9-18 which you can buy where ever needles are sold. If the needles appear to be too short, then you have a timing problem
Mar 20, 2009 | Necchi 3101 Mechanical Sewing Machine
Have a Necchi 3205FA and trying to figure out how to set it up for serging. DVD wasn't much help.
There is a serger attachment available for that model. When you attach it to the machine you must start the fabric from the top of the foot. The foot won't cut the fabric if you feed it under the foot. You will want to use the Wide zigzag, overlock, or hemstitch stitches. Set stitch length knob on #4 for overlock stitch #1-0 for hemstitch or zigzag. Set the stitch width to the maximum. Make sure the hook arm is inserted over the needle screw so that when the needle goes us and down the attachment will work. Start on the edge of your fabric by making a small cut about 1-2 cm deep and about the same distance from the edge as the cutting blade. This will make it much easier to feed the fabric over and then under the foot. Remember to start the fabric on top of the foot and then feed it under the foot before it reaches where the needle would penetrate.
Nov 28, 2008 | Necchi 3101 Mechanical Sewing Machine
Sewing Machines Logo
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
