Question about Canon Office Equipment & Supplies
My Canon PC 745 copier indicates a paper jam and there isn't one.
Have checked back, front, inside with flashlight - no paper jam. What's next?
  • 7 Answers
SOURCE: Canon PC 745 Copier
not 8 it is an error code
please write other words
Posted on May 13, 2008
solofixya
  • 34 Answers
SOURCE: Canon PC 1060 has a paper jam that we can't get to
It sounds like the paper jam is in the fixing assembly, and you can not access it unless you take it to a service center for canon products.
Posted on Nov 10, 2008
  • 92 Answers
SOURCE: Canon PC 745 error ''8'' plus zigzag. What does it mean?
try to see if there is any paper in the way out of maxine (fixing unit ) or on the right side of the machine you have paper jam thats the signal zigzag
Posted on Dec 30, 2008
canontech
  • 1219 Answers
SOURCE: paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Posted on Jan 12, 2010
  • 1570 Answers
SOURCE: My canon pixma MP470 printer
Hi
Please inspect again for paper jam located inro the paper tray, in the ink cartridge compartment and rear door of the printer (back door of the printer). If you find the paper jammed, it solves you problem and try to print again.
If not, just open the cartridge door, turn off the printer and move the cartridge using your hand the ink cartridge to the left going to the right and then right to left for 2 times. Then try to print again, also jammed message errror is related to stuck up cartridge.
Posted on Feb 26, 2011
Paper jam indication but inside no paper
Double check for a small piece, and clean and hit reset, and or unplug unit and see if it clears and starts back normal
Jan 12, 2015 | Canon Ir 2022 Copier [new]
Tip
Canon ImageClass MF3240 paper jam fix
The Canon ImageClass MF3240 continues to show "paper jam" error even if someone followed all the possible fix to remove the jam. After clearing the paper in all access doors (both front and back), the printer still gives the paper jam error. Also, if you have tried restarting the printer several times to no avail and the red light keeps blinking, here is the fix to what is most probably been causing the paper jam problem of Canon ImageClass MF3240.
1. Turn off the printer and pull out all plugs and power cord that is attached to your printer.
2. Remove the paper tray at the bottom and let the printer lie at its back so that you can see underneath.
3. Get a flashlight and look closely for the sensor located underneath the printer. The sensor is located in a small square hole, just above the small black plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller. Move the lever so that you can freely look closer on the hole.
4. Notice because there could be a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
5. Get a small tweezer to remove that paper out.
6. Next, let the printer stand normally and return the tray back.
7. Re-plug all cables and start your printer. That's it!
on Jan 07, 2010 | Office Equipment & Supplies
My PC 745 comes up with an error code of a paper jam but I cannot find any jammed paper. Any suggestions.
completely remove the paper cassette and look for A SMALL PIECE OF PAPER stuck inside the machine in the paper path. Also use a flashlight to check for tiny bits of paper in the exit section of the machine where the fuser (hot) rollers are.
Dec 16, 2010 | Canon PC-940 Black and White Copier
I HAVE A CANON PC 745 COPY MACHINE AND IT WONT PRINT IT MAKES A FUNNY SOUND AND THERE IS NO PAPER JAM AS THE LIGHT INDICATES WHERE CAN I TAKE IT IN FOR REPAIR
i would try this first clean the pick wheels with contact cleaner to insure they are gripping the paper if this dont do it. uninstall the unit and reinstall
Oct 01, 2010 | Office Equipment & Supplies
Rec. Paper Jam slide platen left
There may still be a small sliver of paper somewhere along the paper path. It only takes one small piece to interfere with the mechanism that detects jams and causes the copier to stop working. Since the copier gives you an indication of where the jam is occurring, I would focus my attention in that area, removing trays, using a small flashlight to get a really good look inside.
Jan 07, 2010 | Canon SmartBase PC1270D All-In-One Laser...
Canon PC-745 stopped working.. paper jam light
Sooner whole in трее there is what that subject , can broken part or scrap of the paper. Open and see attentively, in that place, where paper sticks. I for its work so much took out stranger a subject(
Sep 05, 2009 | Canon Office Equipment & Supplies
Canon pixma mp810 keeps jamming ....the paper won't feed through the back or the front
Go to this link. In the search window in the center of the screen, type "paper jam" and click on the search button. Then select "paper is jammed inside the printer" and "removing paper jams". You will see an illustrated guide to checking all areas where paper may be jammed inside your printer.
Aug 21, 2009 | Canon Office Equipment & Supplies
Lines repeating on copied paper from Canon PC 745 copier.
You probably have a piece of paper wrapped on your pressure cleaning roller inside the fuser. The patterm on the paper is the same and the spacing is equal and it is in the direction or feed.
Apr 11, 2009 | Office Equipment & Supplies
Misfeed Indicator light is on - there are no jamed copies present. Other solutions recommended. Thank you
Make sure that there isn't any little piece of paper caught near a sensor. Often when a jam is removed, the operator rips the paper, leaving some if it there inside. If it's near a sensor, you'll get a constant jam indication. Use a flashlight to check for it.
Feb 21, 2009 | Sharp AL-1642CS Copier
Dec 27, 2008 | Office Equipment & Supplies
43 people viewed this question
old marine
old marine
