Question about The Computers & Internet
1990 Olds 88 Royale. Can a problem with the load levelling compressor cause poor starting condition.?
First attempt to start usually works but if not driven for some time/distance it will refuse to restart. A replacement computer has helped the initial start but not the restart.
  • The Master
  • 10,291 Answers
No. The load leveling compressor is a suspension system component and has no connection with the engine. You may have sensor problems.
Posted on May 10, 2017
Can't find low pressure recharge port for 93 olds 88 royale
as another here said ..... locate your evaporator inlet outlet lines usually coming out of the fire wall. then follow the line that runs to the compressor. that is your low side line and the service port should be on that line
May 09, 2015 | Oldsmobile 88 Cars & Trucks
Where is the starter relay located on a 1992 olds 88 royale
It's piggybacked on to the starter.
1992 olds 88 royale starter solenoid Google Search
Also, check the neutral safety switch - Put your foot on the brake and put the car in neutral. Then try to start it. If it starts the neutral safety switch is bad. It could be the ignition switch. It could be to starter solenoid. Does it have an inertia switch? They rarely go bad but I have seen it.
Feb 20, 2015 | Cars & Trucks
1990 olds 88 royale
There are usually 2 fuses on a radio but one holds the memory and the other turns on the lights and amplifier. You likely blew the ic or transistor that does the amplifying.
Nov 15, 2013 | Cars & Trucks
1994 olds 88 royale A/c wont start or charge 134a
AC clutch has to be energized for the compressor to turn and cool. Check out the thermostat as well as the low pressure cut off switch, relays for proper operation.
If you connect the 12 volts to the hot side of the clutch it should engage - if so that indicates that the issue is caused by some electrical item in line with the circuit that powers the clutch.
Apr 24, 2017 | Cars & Trucks
Need the belt routining diagram for 1983 olds delta 88 royale, 5.0 liter engine
Air pump/Smog pump and Compressor go on first, on the shaft. Power steering goes on next Altenator is the last one. After market pulleys and the above mentioned parts may change this order.. 1983 olds delta 88 royale
Aug 19, 2011 | 1983 Oldsmobile Delta 88
1992 olds royale, suddenly shuts down while
car starts and idles good.it cuts off while driving,and starts right back up????????
May 27, 2010 | 1992 Oldsmobile 88
My 98 olds 88 has been stalling lately. usually
typically this condition is caused by the cam sensor or the cam magnet. really needs further diag
Oct 11, 2009 | 1998 Oldsmobile 88
Which years/models trannys interchange 1990 olds delta 88 royale
any gm olds , buick caddy, pont, 4speed auto up to 1991 u just got make sure theyre not computer controlled some 91 are n some aint stay away from 84 to 88 they had failures it doesnt really matter about engine size as along its same transmission
Mar 14, 2009 | 1990 Oldsmobile Eighty Eight
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
