Question about Cell Phones
How to clean out nozzle that has hardened soap residue in it
B&D 1600 older but only used a couple times
  • Cell Phones Master
  • 4,158 Answers
Dish washing detergent will dissolve soap
Posted on May 09, 2017
What tip do I use for soap in my greenworks 1700 psi?
Hi Linda, Tip to use is the following:
65? - soap (black) nozzle: Soap tip is used in conjunction with the cleaning fluid. This is the only nozzle that can be used with cleaning solutions.
Hope this helps
Kind regards
David
Oct 31, 2017 | Garden
No soap is coming out of the wand
Most likely it is clogged with old detergent residue. These get plugged when the old solution sets in the line and dries out and hardens. you will need to clean the lines out, you may have to disconnest them and run hot wather thru them to clean out. Always run pure water through the attatchments and clean after using cleaning solution to clean out the lines before storing.
May 11, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
The soap does not dispense entirely (the soap dispenser opens okay) The dishes have a soap film and at times food residue on them... It appears that not enough water is spraying on the dishes. Is there a...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 12, 2011 | Kenmore 24 in. 17019 Built-in Dishwasher
My kitchenaid dishwasher has stopped rinsing properly. There is a soap residue left on all my dishes. I am using good soap too.
Hello, W/D here.
Check the spray tips on the washing arms for blockage. If the arms are removable, take one off and place it over the sink. Take a paper clip, and bend it into an "L" shape. Use this to rake debris out of the slots near the end of the wash arms, and poke the debris in any of the nozzles back into their hole. Back wash the spray arm over the sink, flushing the residue out of the arms and re-install. For those arms that you can't remove, use the paper clip to rake the ends clean, and poke the debris in the nozzles back in the holes. You will have to check and remove the debris several times with these arms, over several cycles.
I see that you use good soap, and that's good, but consider using less of it. The detergent is abrasive, and can contribute to material on the dishes, most notably on the glassware. We have cut our detergent to about 25% of the recommended amount, and the dishes get cleaned just fine. Try cutting yours about 50% and then adjust up or down from there, depending on your washer's demands and the water quality in your area.
Preheat your water at the sink and run an empty load with two cups of vinegar, and just a sprinkle of detergent. This will help to clean out the sump of your machine.
Best Regards, --W/D--
Mar 07, 2011 | Dishwashers
I am getting a lot of soap residue left on my clean dinnerware and glasses, like a dry soap residue. what can I do to fix that problem?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
heatman101
Jan 12, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Printer is printer blank pages - no ink is coming out of nozzles. I have gone through cleaning processes numerous times. I already replaced with new cartridges - still not working. Is there anything...
If you can get to the nozzles, soak them in hot water (almost boiling), set on CLEAN cotton cloth, repeat several times. Nozzles should exhibit color of ink. Do this until all areas on cotton cloth are saturated or have no more ink. Maybe 3 or 4 times. replace into printer and replace ink. Epson has updated this printer and I use the 320 which is a couple years newer than yours and couple years older than current models. If you get it working, use the 'ciss' ink and DO NOT run out. The ink (obvious to you at this point) dries out and hardens inside the nozzles.
Hope this helps.
Brock
Sep 16, 2010 | Epson Stylus Photo R220 InkJet Printer
Film on dishes
the film on your elemend and dishes is more then likely soap residue.try useing less soap. if this is a new dishwasher it probably uses less water then your older one did so you will need to modify your soap usage. if you have had the dishwasher for a while then your valve is clogged or not opening all the way. check the brass elbow for mineral deposits and replace it and valve if buildup is seen
Apr 24, 2010 | Tappan 18 in. MDR251RE Built-in Dishwasher
Whe using the honda 3000 psi power washer, I've
Are you putting the soap nozzle on the end? Either that or depending on what type of nozzle you have, some times you pull out or push in the nozzle to switch it to soap.
There has to be no pressure to draw the soap, so you either have to put in the soap nozzle in, or if it has an adjustable end, set it to soap by pushing or pulling.
You cannot spray high pressure with soap unless your unit is equipped with another siphon hose for pressure soap.
May 03, 2009 | Garden
Have an eson stylus cx9400F
Every time you do a nozzle clean routine in an inkjet printer, like the Epson CX9400Fax, ink is wasted. When it is $20.00 for a quarter ounce, that is wasteful to your wallet too. The nozzle head cleaning routine flushes your ink from the cartridge through a tube to the nozzle, where it mostens the nearly microscopic holes and flushes hardened ink residue away.
The wasted ink from machines often goes through a rubber gasket or wiper, and into a large, thick felt pad, maybe an inch thick, hidden deep inside, near the bottom of the printer, where it eventually soaks in and dries. In some machines, this happens every time you start the printer, so it makes sense to keep it plugged in. Each cartridge uses some ink, even if you only use it for black and white, so you pay a lot for something you don't even use.
Unfortunately, HP and Epson abuse the trust that users put in them. Word is that HP makes more money on cartridges than it does in printers and plotters. This leads to poor printer design that makes it impossible to refill cartridges, get 3rd party cartridges, or use a printer for black and white and not waste color ink.
May 19, 2008 | Epson Stylus CX9400 Photo Printer
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
