Question about Garden
My TB575 EC weed eater will idle but when I pull the throttle, the engine dies. I have changed the spark plug, gas and oil. Not sure what to do.
    Top Expert:
  • Garden Master
  • 47,745 Answers
Overhaul the carby
blocked jet or diaphragm problems
Posted on May 09, 2017
My TB575EC weed eater will not start. It seems oil is some how getting into the air filter
The rings on the piston are passing too much oil/gas mixture due to the lost compression. Or, you have incorrectly mixed the oil and gas, if it uses a mixed fuel.
Sep 02, 2016 | Troy-Bilt 29cc 4-Cycle Straight-Shaft Gas...
My murray m2510 gas weed eater runs at idle but when i go past fast idle it wants to die. i put a new spark plug in it, it didn't change. what could be the problem? it started doing it last fall.
Sounds like fuel problem. You may want to check the vent on the fuel tank. It can get clogged and won't provide enough fuel to run at higher rpms. I'm not familiar with that engine, but its a problem I've had in the past with weed eaters and chainsaws.
Apr 07, 2016 | Fast Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Troybuilt tb80ec wont start
    If you didn't over winter the engine properly it could be several things. Start with replacing the fuel filter. If it still won't start... time to put in a carburator kit. Next time make sure you run your weed eater dry and spray some wd-40 or the like into the spark plug hole.
    Jun 02, 2014 | Troy-Bilt 27cc 2-Cycle Straight-Shaft Gas...
    Weed eater head spins on its own, no power.
    check the compression on your weedeater low compression will cause this
    Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
    My weed eater (toro), won't let me pull the cord at all. This weed eater doesn't take oil I don't think.
    All internal combustion engines use oil of some description. I take it this is a 2 cycle engine and you have not added oil to the gas. If this is the case the engine is locked up, and must be replaced. Sorry.
    Mar 25, 2012 | Toro& Electric String Trimmer
    Weed Eater Problems
    If it runs with the choke closed then it's not getting enough gas. Check the gas filter on the end of the gas line in the gas tank. Remove the gas cap and using a piece of wire with a hook on the end, reach in the tank and pull the gas line out through the opening. Check the filter on the end of it. You could also have a burst-ed diaphragm in the carburetor. This sucks the gas from the tank to the carb. If that's the case a new weed eater may be in order unless you can find someone with the parts to repair it. Also check the gas lines for leaks or breaks, 2 of them.
    May 17, 2010 | Troy Garden
    Having a problem starting my Shindaiwa T22 Weed Eater.
    take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
    May 02, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
    Cant get weed eater to start
    look at these items for your weed eater. Make sure that your fuel mixture is correct and clean. Also make sure there are no air bubbles trapped in the fuel line. Agitate the fuel tank to make sure there is no blockage caused by dirt and debris. If you have a fuel filter make sure it is clean and does not need replacing.
    Next check the air filter to make sure it is clean.
    Next check that the spark plug, is it whitish grey and matt in colour and not back, oily or pure white. If so then change the plug and set the correct spark gap for the particular type of plug you are using. If the plug is black and sooty or pure white matt then the fuel mix is incorrect and you will need to adjust this. Black indicates too much oil in the 2 stroke and burning low and the white indicates over temperature and probably not enough oil in the fuel mix or using to high an octane rating. If it is oily then there is far too much oil in the fuel mix and if you are using a 4 stroke or a 2 stroke with additional lubrication then there is oil leaking into the combustion area most likely caused by a worn or cracked piston ring. After that check that the carb, is it operating correctly and opens fully when starting and closes as the engine warms upon idle. Also make sure that it idles evenly. Also if it stops when you throttle it then look at the spark cap to make sure it is not loose or damaged and produces enough voltage to fire up the plug correctly otherwise you may have a generator issue or a carb problem or air filter problem or something restring air flow. Also check the engine casing over for any cracks or damage.
    Check this link out at Troy-Bilt for your weed eater. Just select the download owners manual below your picture. You will need to provide them with your model and serial. Just copy and paste into your browser.
    http://www.troybilt.com/webapp/wcs/stores/servlet/product_10001_14102_10150_55008_-1
    Hope this helps, let me know if I can help you with anything else.
    JimmyC
    Oct 06, 2009 | Troy Bilt Tb70ss Gas Trimmer
    Garden Logo
    37 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
