I am getting a new sky Q hub tomorrow but I think the problem will be the same given the length of my bungalow
I am having sky broadband tomorrow how do I get email address changed from my old provider
Unless you use a 3rd party email address like gmail or hotmail then when you stop paying the old provider any email addresses that they supplied will simply cease to exist and will not be accessible. So you need to set up a sky address (or gmail) and tell everyone what the new address is. You can still use the old address as a login id, for example with shops, utilities or ebay, but you will need to log in to each account and change the email address to the new one if you ever want to receive emails from them or to recover the account when you forget your password.
Jul 23, 2017 | Sky Computers & Internet
I need a Manual for National Geographic NG114AZ as well as replace the adjuster for the erecting eyepiece. where do I get these>
I think you are asking for a replacement focuser. You can probably find one here: http://www.ebay.com/itm/4-5-or-6-Telescope-Reflector-Tube-1-25-Newtonian-Focuser-Metal-Plastic-NEW-/360936594869?hash=item54097f5db5
A manual is another question. These scopes are imported and no manuals are available. However the manual only has assembly instructions it does not tell you how to use the telescope to find objects in the night sky.
Find a local Astronomy Club and the members will help you set it up-- very easy once you see it done 1 time.
Clear skies.
Jul 08, 2015 | National Geographic Optics
What is my e.mail
Hi there
When you signed up to Sky they should have given you an email address. Alternatively they may have just given you a Username or Sky ID, in which case your email address will be this Username or Sky ID followed by "@sky.com"
Hope this is helpful, if so would you please register that with Fixya
Cheers
Mar 02, 2015 | Dynex 4-Port Ethernet Broadband Router...
I recently bought a new notebook how do I link it to my hub
turn on Wifi on both hub and sky
you should configure/check the router first.
Aug 09, 2014 | HP Chromebook 11
Sky on demand
on the keyboard on screen click on the arrow up this changes the keyboard layout to lower case. or change the password in the hub settings. sky hub 192........ sky hub log in. using pc etc password and log in admin/ sky and change the hub code. and apply but anything else using it will need to be charged as well. as using the wifi to access the hub will log you out and you will need to put the password you made to log back in.
Jan 09, 2018 | Cars & Trucks
'06 F-150 2wd front rotor needs replaced, brake pad worn off got into rotor; otherside not damaged 7-lug rotor is integral hub/rotor. Can pick-up rotor and hub nut tomorrow 4/3/11. Info I grabbed...
Hi, if you have the right socket in a half inch drive with a breaker bar, you can get it off. Cheat if you have to. The new hub will probably not have bearings, so you will reuse yours with a little new grease. I don't think there is any kind of dust seal. There should be a large washer on the outside just under the axle nut. The final torque isn't critical. You can use your weight multiplied by the length of the breaker bar to estimate. I recommend you replace the pads on the other side too, since they come in sets anyway. Please let me know if you have more questions, and thanks for using FixYa.
Apr 03, 2011 | 2006 Ford F-150
How do I replace just the outer tie rod(passenger side) of a 2000 plymouth neon? I have the tie rod, what equipment will I need?
you can do the whole job with a large crescent wrench, hammer, and pliers. Loosen the lock nut but only loosen, remove the cotter pin (if present) and joint nut. Hit joint with hammer to separate from steering knuckle. unscrew tie rod end. Compare length to new end. You will want to keep the length from the nut to the center of the hub arm attach the same or you will need an alignment. Screw the new end on and adjust to the original length. Slip back into hub, replace and tighten net, repace cotter pin. Tighten lock nut and get an alignment if you aren't sure about length. OK? Any questions, let me know.
Oct 08, 2010 | 2000 Plymouth Neon
Sky tv(free) thru BT home hub wat cables do you need
There are some sat that r working with what is called slingers or iks and hub but to get those channels you still have to pay for the iks and slingers. I would check the sat forums.
Jun 13, 2009 | Computers & Internet
How do i configure my Belkin router to work with Sky broadband?
I'm not into hacking what I cannot find on ISP's sites
From what I can gather from the Sky Broadband site reading the manual installation procedures -- the process is pretty much automatic when it comes to installing their equipment leaving no clues as to how they configure it. What is the model if the Belkin router? Options probably exist to attach your device to theirs either as a router (establishing a second network behind theirs) or an access point joining as a member of their network - meaning there would would be two wireless networks in either case in the house (as there are no indications I have found on the site that the provided the sky router can be configured in any way such as turning off wireless). At least according to the documentation the sky router's wireless is running WPA-PSK security / encryption which is good -- and the documentation for attaching non-sky wireless adapters appears to be documented here.
Sky Setup
Dec 15, 2007 | Computers & Internet
Sky branded Netgear DG834GT router
OK - it can be very simple to do, but took me two hours to work out ;-)
Google for all the info you can.
Download the recovery utility from Netgear.
Download the latest OS from Netgear.
Flash the router with the OS.
Enter the router config panel.
Change the Sky login and password to the ones given you by your ISP.
That should be that.
Keep trying: I did, I'm no expert, and I got there.
Do everything you can to a*sf*ck Murdoch and his company.
Apr 02, 2007 | NetGear DG834G Router
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
