Question about The Computers & Internet
I have a Quietpact 75d Model 3 004270-2 it is only putting out 100 volts what could the problem be?
    Top Expert:
  • The Master
  • 48,226 Answers
Petrol driven ==not enough rpms
Posted on May 09, 2017
Testimonial: "It has a fixed governor at 1920 rpm constant. Diesel driven"
  • Bill Boyd May 09, 2017
    the governor speed can be adjusted
    talk with an accredited diesel repair shop as to how it is done or consult your workshop manual
My LG 42LH5000 TV is not turning on. A few days ago suddenly switched off and now it doesn't turn on. The red LED is always on. If I unplug it turns off and when I plug again the LED is red again.
I had the same problem with Samsung. A web search located the issue being the capacitor. Take out the back and look for the capacitor near where the power line enter the TV. It was a 100 uF at 4050 volts capacitor. checked the DC voltage to be 381 volts. Got two old capacitor from an old TV - one was 150 uF at 400 volts and one was 220 uf at 400 volts. It turned out that it needs two in parallel (making 370 uf at 400 volts. Took out the under rated 100 uf and replaced it with these two. Checked the voltage to be 390 volts. That did the job. Samsung must have tried to save money by putting in a 100 uf at 450 volts. .
Oct 30, 2017 | LG Televison & Video
How to change the fuel filter on guardian quietpact rv generator
Dec 05, 2015 | Generac Electrical Supplies
Download kenwood software KPG75
Dec 23, 2013 | Kenwood Cd Kpg-75d Radio Programming...
It back fires
If it backfires, check for manifold leaks, fuel mixture is too lean, timing is off, make sure it isn't spitting liquid into the cylinders and the LP is the right pressure, and the vapour coil is working
Oct 05, 2013 | Generac Guardian RV Generac RV Generator -...
Instruction manual for bush wv12-75dw
Can't find user manual for bush dishwasher Bush Dishwasher WV12-75D
Jan 15, 2013 | Dishwashers
Will a Norelco shaver model 715RL and model 5861XL run (or charge) on 220 volt current in Israel?
model 5861XL is capable of use with 100-240V. Model 715RL may only be capable of use with 100-120V
Jan 28, 2011 | Norelco Health & Beauty
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
16" gas craftsman chainsaw needs tune up
being a 2 stoke there isn't much to tune up. the MOST IMPORTANT THING TO REMEMBER IN A 2 STROKE IS GAS AND OIL MIXTURE,too much oil will foul plug no big deal. replace plug. too little oil in gas will wash the crome lining in the cylinder off and you won't have the compression need to burn the gas any more. once you get that straight crank the saw and run it wide open, it should be quick to react to the trigger, that is no stumbling until it finally turns up. if it don't have a small screw driver handy and turn down the screw for the run mixture until it runs as fast as it can. also let idle. it should run on idle as long as you don't turn switch off. if it loads up and quits turn in idle screw until it does idle right . that's about it. also always make sure chain on bar isn't sagging too much when not running. a loose chanin will cause uneven wear on bar and make a crooked cut.keep chain sharp. they dull quick.NEVER leave gas in tank for long periods of time. after each use drain tank and start until motor runs itself dry.
Jan 02, 2009 | Guardian Rv Preventative Maintenance Kit...
Computers & Internet Logo
29 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
