I need to know what signs are similar to lupus as diagnosis
  • Computers & ... Master
  • 10,137 Answers
High antibodies in the blood stream. Lupus attacks internal organs and joints so there are too many misdiagnoses.
Posted on May 10, 2017
How to get info relating to best hypoallergenic dog food?
What every pet owner should know about food allergies
Diagnosis of food allergies involves feeding a veterinary therapeutic or homemade diet for typically 8 weeks and watching to see if the signs improve. To confirm a diagnosis of food allergy, the pet must be re-challenged with the original diet that caused the clinical signs. It is critical that your veterinarian be involved in instituting a food allergy trial for determination of the diagnosis. The food offered by the vet for such trials has less of a mix of certain ingredients in order to make make the effects discernible as the trials proceed.
Aug 23, 2017 | Dogs
Sc 234 on ricoh mpc 2000
SC234 on a Ricoh MP C2000
Ther service manual states that SC234 indicates FGATE ON error: M
The PFGATE ON signal does not assert within 5 seconds after processing the image in normal job or MUSIC for start position M.
What that means.. is:
The FGATE signal did not go off within the prescribed time. (The BICU generates the FGATE signal and sends it to the LD unit when the registration sensor switches on.)
My first though would be trouble with the BICU board.. buy it may be several reasons.
It indicates there is one of these errors:
- Defective ASIC (Lupus)
You can perform tests in servicemode to confirm.
- Poor connection between controller and BICU.
Check connections, perform tests.
- Defective BICU.
..yeah.. they fail sometimes..
You should start and try to perform a scanner IPU board test in service mode.
If you follow a complete procedure, you can find out whats wrong.
Scanner Test Mode
VPU Test Mode
Output the VPU test pattern with SP4-907-001 to make sure the scanner VPU control
operates correctly. The VPU test pattern prints out after you have set the SP mode settings
and pressed the start key.
- The CCD on the SBU board may be defective if the copy is abnormal and the VPU test
pattern is normal.
- The following can be the cause if the copy is normal and the VPU test pattern is
abnormal:
- The harness may not be correctly connected between the SBU and the BICU
- The BICU (IPU) or SBU board may be defective.
BICU (IPU) Test Mode
You can check the BICU (IPU) board with the SP mode menu, SP4-904-1 or -2.
Here the machine performs a write and read check of the ASICs on the BICU board and displays
the result.
0: OK, 1: Error
(Pay attention on Bit 2: Lupus register..)
If no error is detected, the test ends. Then the completion code shows in the operation panel
display. If an error is detected, the test is interrupted. Then an error code shows.
The table
below lists the completion and error codes.
SP4-904-1 Register Access
There are 16 bits switches in this SP. Each bit indicates each CPU as followings. The error
result is displayed on the operation panel in decimal number.
0: Normal, 1: Error
Bit 0: TAURUS register
Bit 1: ORION register
Bit 2: LUPUS register
Bit 3 to 11: Not used
Bit 12: Ri20 register
Bit 13 to 15: Not used
SP4-904-2 Image Path
There are 16 bits switches in this SP. Each bit indicates each CPU path as followings. The
error result is displayed on the operation panel in decimal number.
0: Normal, 1: Error
Bit 0: Image path from SBU to TAURUS
Bit 1: Image path from TAURUS to ORION
Bit 2: Image path from ORION to TAURUS
Bit 3: Image path from TAURUS to LUPUS
Bit 4 to 11: Not used
Bit 12: Image path from LUPUS to Ri20
Bit 13: Image path from Ri20 to GAVD
Bit 14 and 15: Not used
Errors may be caused by the following problems:
1. Short circuit on the signal lines
- When the BICU board is installed, a pin or two on the ASIC is damaged.
- Some conductive matter or object is trapped among the pins. Metal "dust" from screws and what not.
- Condensation
2. Destruction of circuit elements
- Over current or a defective element breaks the circuit.
3. Abnormal power supply
•The required voltage is not supplied to the devices.
4. Overheat/overcooling
- The environment is inappropriate for the board (the scanner unit).
Not common if the machine is in a normal location.
5. Static electricity
- Static electricity of a high voltage occurs during the test.
Not common if the machine is connected to a grounded outlet (and nobody has touched the boards inside the machine).
6. Others
- The scanner and BICU are incorrectly connected.
When you have completed a check, turn the main switch off and on before you do another
check. When you have completed all necessary checks, turn the main switch off and on.
Hope this helps.
Jul 31, 2017 | Ricoh Office Equipment & Supplies
I am not getting the right answer to lupus
fixya site is not a medical forum
ask your doctor
May 09, 2017 | Cars & Trucks
Need to know how do you diagnose lupus a medical condition
There is a blood test now. Lupus is a most difficult disease to properly diagnose. Antibody levels are unusually high, but since doctors don't have much information on detecting lupus, diagnosing it is often missed.
May 09, 2017 | Health & Beauty
I cant log into my gmail
have a read
I can't access my account - Gmail Help
https://support.google.com/mail/troubleshooter/2943007?hl=en I can't access my account. If you are having problems accessing Gmail, please follow the troubleshooting steps below to resolve your issue as quickly as ...
I can't sign in to my personal Gmail Account - DoubleClick ...
https://support.google.com/dartsignin/answer/140795?hl=en I can't sign in to my personal Gmail Account. You can be signed in to only one Google Account at a time in the same browser. If you're signed in to your ...
I can't sign in with my Google Account username and ...
https://support.google.com/dartsignin/answer/114764?hl=en I can't sign in with my Google Account username and password. One of the ... You're already signed in to another Google Account on this computer. You can be ...
In order to log in to Gmail, your browser must be set... - the ...
https://support.google.com/mail/answer/12343?hl=en If you're receiving an error message that says, 'In order to log in to Gmail, your browser ... If you still can't sign in, try signing in securely by changing the URL to ...
I can't sign in on my mobile device or email client - Gmail Help
support.google.com > Gmail Help > Account > Sign in and out If you recently changed your password on your desktop Gmail, then you'll need to change your account password on your mobile device or email client (e.g. ...
Why can't I sign into GMail? - MakeUseOf
www.makeuseof.com/answers/cant-sign-gmail/ Jul 10, 2014 - The way of the landing page is such that every attempt to "Log In" leads you back to this page. How do I get (pick up) my Gmail? It just keeps ...
I can't access my gmail account from my computer...How do I fix ...
answers.microsoft.com/...cant-access-my-gmail...my.../07c8272f-034d-4... Oct 6, 2015 - evertime I try to access my gmail account it denies me. I can access everything else on my computer on the internet except for gmail account ...
I can't log in to gmail (I know my password and user name ...
https://support.mozilla.org/questions/774029 Jan 2, 2011 - I can log into gmail via Microsoft's Internet explorer so I know that my user name and password work. I have also added www.google.com to the ...
More things to try if you can't access Gmail - The Guardian
www.theguardian.com > Technology > Email Jun 12, 2008 - I assume quite a few people are having problems because Google has a troubleshooting link on the mail page that says "I cannot access my ...
Feb 07, 2016 | Computers & Internet
I dont know my password for facebook or my e mail
For Facebook, click the "Forgot your password?" link on the Facebook sign-in page.
For your email, there should be a "Need help?" or "Can't access your account?" or some similar link on its sign-in page.
Aug 05, 2014 | Computers & Internet
Reset pass word
Go to the following site. Click "my account" at top right. Enter your email and password. If you forgot your password, click "Forgot your password?" http://www.shoplupus.org/?a=Homepage
Enter your email address, and you will be given directions to change your password.
Jul 14, 2014 | Computers & Internet
I downloaded and set up yahoo messenger I signed out by accident how do I sign back in
I assume you are accessing Yahoo! Messenger from your Computer. Well, if you've signed out, simply open the Yahoo! Messenger and sign in again using your Yahoo ID and Password. You should have a Yahoo Messenger icon similar to this on your desktop...
When it is opened, you'll see the sign-in box which should look more or less similar to this:
You can also open the Yahoo! Messenger from the Taskbar, double-click the Yahoo!Messenger icon on the taskbar to open it.. (reddened icon below)
If you can't find it on the desktop or on the taskbar, click "Start" > "All Programs" > "Yahoo! Messenger" and open it, or you should see the Yahoo!Messenger icon in the Start Menu Program lists.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 06, 2011 | Computers & Internet
Monitor won't come on
Yes the diagnosis by a technician is needed because we cannot jump to conclusions before to see the part needed to change maybe is not a expensive repair. To save the kid head is simple. The tv has to turn on by itself i mean to power on the tv it doesn't need the game or DVD or anything, tv has to show alive a soon as you power on.
Apr 14, 2009 | RCA R52WM24 52" HDTV Projection Television
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
