How can you remove paper stuck under heat shoe on a pinnacle 27 laminator?
2 Suggested Answers
clintonmulti
  • 238 Answers
SOURCE: GBC Pinnacle 27. Right side top heat shoe does not get as hot as left side. Lamination is milky colored on right side
Could be one of the elimebts have burnt out as there are more than one into the tip just take to local shoe repiar as taking it to golf shop will be expensive
Posted on Sep 03, 2016
Sep 03, 2016 | Cars & Trucks
Our machine is starting to squeal when working what do we do
There isn't anything you can do, those machines are screamers. sometimes they start screaching right away, sometimes it takes a few rolls of film run through before they start, but they ALWAYS start to scream, sooner or later. it becomes loud enough that some people refuse to use it because they think its coming apart. not my favorite.
Sep 18, 2014 | Gbc Pinnacle 27 Ezload Roll Laminator, 27...
Pinnacle er-1
left hand side cover is probably off and excess light is getting onto the motor speed sensor. put the side cover back on and try it, most likely that will fix it. could also be the set screw on the right side is loose, error 1 means you have a speed problem. check gears and chain. only other part that has caused this in the past is the keypanel.
Sep 15, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
Why won't someone answer the ??s about the GBC Pinnacle 27 power light in the back works, but no power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......
Westco Laminating Service 405-324-6092
Aug 09, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
Gbc pinnacle 27 ezload power light turns on but the front panel does not
you have one of the TCO's that is blown out, To test them you need to take the right side cover off, and test continuity from one side of the tco to the other, start with the tco wire that is connected to the tray switch, the other end of the tco wire is connected to the wire block on the right side of the laminator. just follow the wires back to the heat shoe and check for continuity. A TCO is no more than a temperature fuse. you can actually make a test "jumper wire" and jump across both connectors and it should power right on. You need to be careful and follow the wires back correctly so you don't fry the laminator the rest of the way.
Mar 31, 2014 | Office Equipment & Supplies
GBC Pinnacle27 Laminator has no control board power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......Westco Laminating Service 405-324-6092.
Jan 08, 2014 | GENERAL BINDING CORPORATION Laminating...
The heat button won't turn on
either the top or lower heater shoe TCO is blown out. take the right side cover off, trace the wires back to the heat shoe and check for continuity, (unplug machine first) find out which TCO is blown order another one, replace it and your off to the races. I've fixed many of them.
Mar 11, 2013 | Gbc 1701720: Pinnacle 27 EZload Laminator
GBC Pinnacle 27 won't come on
each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime.
Feb 20, 2013 | Gbc ® Pinnacle 27 Two-Heat Roll Laminator,...
Paper rolled on heater roller. How do I remove?
I fix roll laminators for a living. Its best with GBC machines to remove wraps where the film is stuck to the roller hot. trying to remove ilm adhered to the roller cold can not jusst remove the film but the rubber roller surface. Do note GBC heat rollers espically the red ones are over 500 bucks each:( Its easy to damage those rollers making the machine junk....
This question is old but I answered it for the benefit f others coming here bob haller service and sales 412 366 4906 pittsburgh pa. I answer all phone questions for FREE, and in the pittsburgh area offer free no cost no obligation estimates
Oct 04, 2011 | Gbc HeatSeal Ultima 65 Laminating System
Can you tell me how to thread a Graphic III laminator?
5-2 THREADING the LAMINATOR
1. Remove the supply roll mandrels and the feed tray. The supply roll mandrels are now ready to accept
loading of the film rolls, wound with the polyester (shiny) side out. When viewed from the front of the
machine, the core grippers on both the top and bottom supply roll mandrels should point toward the
heat shoes (and toward each other). The tension control knobs should be positioned on the right. Notice the
knobs are labeled "Top Right" and "Bottom Right". If you have rolls of film on which the material is wound
in the opposite direction (adhesive or dull side out) exchange the top and bottom supply roll mandrels so
the core gripper positions are reversed.
2. Slide a roll of film onto the top supply roll mandrel, turning the roll slightly to slide the gripper inside the
core. Center the roll. Make sure the dull side of the film is facing up and the shiny side is facing the
heat shoes during the threading. Scored marks on the supply roll mandrels provide a guide for proper
alignment of the two rolls of film to each other.
NOTE: The pointed metal pieces protruding from the body of the supply roll mandrels grip the cardboard core of the film supply roll to prevent slippage. When placing a roll of film on the mandrel, twist the film supply roll to
accommodate easier film loading.
3. With the roll aligned with the scored line on the right side of the mandrel, place it in the top bracket.
Place the left side of the shaft in its slot first then place the right side of the shaft in its slot, turning it as
needed. FOLLOW THE RECOMMENDED LOADING PROCEDURES CAREFULLY WHEN THREADING
FILM IN THE LAMINATOR. ACCURATE ALIGNMENT OF ROLLS WILL MINIMIZE WASTE AND HELP KEEP
THE LAMINATOR CLEAN.
4. While the machine is still cold, review the threading diagram. With the bottom roll of film centered on
the mandrel and the shiny side facing down, run the film under the bottom idler bar and pull towards
you.
5. Load and thread the top roll of film in the same manner as the bottom roll. Refer to the threading diagram. The
film should run under the silver stabilizer bar and over the front of the top heat shoe. Remember, the shiny
side of the film must always go against the shoe. The dull (adhesive) side must face away from the shoe.
Make sure the two rolls are aligned with each other before going to the next step.
6. Turn machine on and heat to the desired temperature.
7. With both rolls threaded and installed in their respective brackets, unwind enough film from the top roll
to reach the bottom of the bottom heat shoe. Next, unwind enough film from the bottom roll to reach the
top of the top heat shoe.
8. Now drape the film from the bottom roll against the film from the top roll on the top shoe. If the laminator is
hot, the exposed adhesive on the top web will hold the bottom web and make it easy to stick the two rolls
together. If you are threading the machine while it is cold, use tape to stick the bottom web against the top
web.
9. Tip the safety shield down into the laminating position. With the film draped over the two heat shoes, push
one edge of the threading card between the heat shoes so that the film is firmly positioned against the
laminating rollers. If a threading card is not available, any piece of card stock or poster board will work.
10. Make sure there is still enough slack in the web. Turn the drive switch to FORWARD, permitting the film and
feed board to pass through both sets of rubber rollers. Carefully monitor initial threading to be sure the web
reaches and passes through the pull (back) rollers. When the threading card has cleared the back of the
machine, move the drive switch to the center position (off). Whenever you want to remove the film and/or
laminated material from the back of the machine, use the zippy cutting tool provided with the laminator.
11. Slide the feed tray into position.
12. If the machine has the slitter option, make sure the slitters are disengaged (blades in the raise
position) and moved all the way to either side of the machine.
CAUTION: The laminator is designed to be run with the operator directly facing the
control panel and feed tray, not at an angle or from the side of the machine. For
operator safety, the safety shield must be in position over the upper heat shoe
when the machine is ON, or when the drive switch is in the forward position.
Dec 21, 2010 | Office Equipment & Supplies
55 people viewed this question
k24674
