Question about The Office Equipment & Supplies
Ineo 164 black copy exposure lamp is ok how can solve the problems
  • 62 Answers
SOURCE: adjustment program
Try cleaning the Auto Exposure sensor, or disabling the AE feature in standard settings. Some copiers have exposure calibration in standard settings too. Increasing the lamp intensity may cause further premature wear down the process line. (What machine have you got?)
Posted on Aug 30, 2007
Guru Guy
  • 95 Answers
SOURCE: all back copies and no light from the exposure lamp
Yes, it sounds as if the lamp has blown. These are halogen lamps on the older models and run over $100 to $150 or more depending on the make. Usually if you take the platten glass off, you can slide the scanner over and see where the screws that mount the lamp end contact down are. BE SURE TO UNPLUG THE MACHINE BEFORE ATTEMPTING TO DO ANYTHING, ESPECIALLY IN THE SECTION, OR ANYTIME YOU TAKE ANY COVER OR PANEL OFF!!!!!!!!! The halogen lamps use 120v ac and will bite! They are very delicate lamps, and you cannot touch them, or the oil in your skin will cause it to blow expensive mistake. make sure the contacts are in place well before you finish. And make sure to check your existing lamp on a meter for continuity... to mke sure it is blown and not just a bad lamp board. Yes, it's all very tricky and kinda dangerous, that's why we charge "so much" in the service industry.
Good luck, and you may find it cheaper to just replace the machine with a lesser make from a local dealer or office supply company.
Posted on Nov 19, 2007
  • 990 Answers
SOURCE: random C21 in Toshiba 2060
Dear sir; the toshiba copier they store the desciption in the memory therefor you just press "8" and "clear/stop" key simultaneously, It might be resetable, just turn machine off and back on. if you need more help please let me know,
Posted on Dec 17, 2008
  • 1110 Answers
SOURCE: Why are my copies coming out solid black, even
A couple of possibilities. Basically if your exposure lamp is coming on, the light is not getting all the way to the drum that is in the toner cartridge. It could be you have a mirror out of place. When the exposure lamp comes on, the light is reflected off the original and then off a series of mirrors until it gets to the drum. If one of the mirrirs has been knocked out of place, like due to a recent cleaning then that would cause black copies. The more common cause would be the drum protection "gate" that is on top of the toner cartridge is closed and thus blocking any light from getting to the drum. You can slide out the toner cartridge and look on top. There is a gate or panel that flips open to be able to see the drum. This gate must be opened when installing the toner. Also it is possible to have a bad cartridge but that rarely causes completely black copies.
Good Luck and Thank You for using Fixya.
Posted on Dec 06, 2010
  • 142 Answers
SOURCE: Copies are coming out black,
Here the things are serious! Every part of this machine is very expensive, so please call your tech support for help.
Posted on Mar 01, 2011
How to fix job concelled on ineo develop 164
What is wrong with the job? or just resend the job
Jun 07, 2014 | Konica Minolta Di1610 Copier
How to check exposure lamp of konica minolta bizhub 164
raise the docfeeder then press start does the bright light come on
Jan 23, 2014 | Konica Minolta EP2050 Exposure Lamp Fuse
Paper is black.
Hello sir ; When you make a copy, lift up the glass cover , watch the exposure lamp is on or the light is wick, if answer is yes, replace exposure lamp, if not ,could be the HV power supply board got problem.
Oct 09, 2009 | Toshiba Office Equipment & Supplies
Out going fax is coming black
FIRST test copying. if the copy come out completely black, then the exposure or scanner lamp or contact image sensor is dead,not lighting on. Now if the copy has black only black lines on it,then you can clean the place where the document passes thru where the light of the exposure lamp projects unto the text of the document being scan,which is the small glass on the left side of the platen glass when you open the auto document feeder.NOTE: Lay your document on top of the platen glass & make copy if the copy come out clean as you needed it,then the lamp is O.K. Then the small glass just need to be clean. If the copy is completely "BLACK", then the lamp is dead, or the circuit that control it. In thus case then you need a technician to do it
Jul 14, 2009 | Panasonic KX-MB781 All-In-One Laser...
Black picture the lamp does't lit. no error message.
Hi sir;Try to make a copy with open cover ( check the exposure lamp is on), if exposure lamp not on andyou already replace a new one then check the thermos fuse at the end of the lamp, replace that one.
May 29, 2009 | Canon Office Equipment & Supplies
Copies coming out almost blacked out
Hello sir; Try to make a copy with cover open, then you can see the lamp is on or not, if not then check the thermos fuse at the ned of exposure lamp or exposure lamp, otherwise you ha go to check the drum blade isn't under good condition if everythingare good final you have to replace developer.
May 29, 2009 | Toshiba e-Studio 350 Copier
All the copies are coming out solid black
Dear sir ; Check the exposure lamp or thermo fuse for exposure lamp. Stii have problem ? let me know.
Jan 14, 2009 | Copystar Royal - COPIER STAND Copier
7130 black and white copier
ok so many things can couse this problem.
if it is total dark black and the scan light is there try to trace
1.too old the exposure lamp so that it brights low
2 the mirror on the scanning assembly may be one is missplaced eccidental or brocken.
3. the blockage of light by black pastics cover infront the lens
4. the heavy tonesof tonner powder is contacting the inner most mirror in optics section
5. the died preexposure lamp or its suply voltage is missing
6. the dc control board is mulfunction
7.the reflector mirror just at the scan lamp
8.excessive toner suply bias voltage biasing the toner catridge unit
9 too old the exposure lamp
tyr look on these and if it solve the problem pls vote me and if still the problem exsist let check another things i wish you success.
Oct 02, 2008 | Canon NP 7130 Black and White Copier
27 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
