Question about Dishwashers
I have a Euromaid EBM14S dishwasher. Water is at base of dishwasher and won't drain. Have cleaned filters and hose. How do I reset it or cancel cycle. New dishwasher.
  • 126 Answers
SOURCE: dishwasher not draining
if its new call your dealer its a warranty call
Posted on Dec 22, 2007
  • 2651 Answers
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
  • 8619 Answers
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Posted on Feb 13, 2009
  • 173 Answers
SOURCE: dishwasher does not drain in normal cycle. on
Thoroughly clean drain screen and drain. Add small amount of drain cleaner to drain, flush after five minutes. Do not add hot water with drain cleaner.
Posted on Jul 08, 2009
SOURCE: Bosch Dishwasher wont drain
Crazy! I have the EXACT same problem....sounds like it wants to drain...but won't ...Water has been stuck in the bottom for days now
Posted on Jul 18, 2009
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
Dishwasher was not draining. I cleaned out everything and now it wont start
I have the same problem with another Kitchenaid model. I've had better results at keeping the water drained by running two back to back water saver cycles than running a full pots and pans cycle.
Nov 06, 2017 | KitchenAid 24 in. KUDS01FLSS Built-In...
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Whirlpool gu1200xtls2 wont drain just stopped
your Whirlpool dishwasher stopped draining mid-cycle, check your circuit breaker or fuses. The cycle won't complete if the power is interrupted. Reset the circuit breaker if tripped, or change out any blown fuses. Fully close the dishwasher door, and restart the cycle if you opened up the door. If you have not used the dishwasher in a while, the motor may be stuck. Open up the main housing, and rotate the motor until it turns freely. You must replace the motor if it's corroded or won't move since it's unlikely that you can fix it.
The pump is located underneath the lower rack and spray arm. This component is responsible for pumping water out of the dishwasher once the cycle is complete. If the pump isn't working, verify that it is not clogged with debris. Use a toothpick or plastic utensil to remove food particles from it. Check the pump impeller. If a section of it is broken, get a new pump since the impeller is difficult to fix.
Clogs in the air gap or drainage hose prevent water from leaving the tub. Clean these components and the water inlet filters, if dirty. Examine the drainage hose, and straighten it if it's kinked. If the hose is badly crushed, you must replace it. Unscrew the drainage hose from the dishwasher to clean it, but reattach it before you restart the cycle. Run the food waste disposer if it's connected to your Whirlpool dishwasher. Remove the knockout plug from the disposer if you have just installed the disposer or dishwasher.
Drain Valve/High Drain Loop
Whirlpool dishwashers have drain valves with an internal solenoid. This valve opens and closes to drain water out of the tub. If the drain valve is stuck, lubricate the lever, and remove any debris clogging the valve. Remove any objects that are preventing the drain valve from freely opening and closing. If the valve is not working properly, you must replace it. Always install a high drain loop to prevent water from the sink entering your dishwasher. Create a loop of the drainage hose that is at least 18 inches high. Attach this hose beneath a section of cabinetry.
Sep 28, 2011 | Whirlpool Dishwashers
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Jun 09, 2011 | Kenmore Dishwashers
Water is not drained from the tub when washing of the dishes is complete
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote if you liked my answer
Feb 13, 2011 | Bosch SHX45P05UC Dishwasher
Our dishwasher is retaining water in the base and not cleaning our dishes fully what is the problem?
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps...
Aug 15, 2010 | Frigidaire Gallery FGBD2451KB Full Console...
Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Aug 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water is left in the cavity beneath the base filter
water under the filter is normal. Most diswashers do not drain completley- this acts as an air lock to prvent odours coming thru the drain hose
Jun 29, 2009 | GE Nautilus 24" Built-in Dishwasher
Won't drain
Make sure the garbage disposal is clear so the water can exit. After that, you may have something caught in the drain hose or check valve. It would require removing the bottom kick plate to gain access to check.
Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwashers Logo
94 people viewed this question
Top Dishwashers Experts
