How do I move my input for the TV up and down. Mine is on TV and I need to put it on HDMI
  • Brett Duxbury
    Brett Duxbury May 09, 2017
    Hi Debra Mocere, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    make and model number ?
    Do you see a button called input source on your remote control ?
5 Suggested Answers
  • 267 Answers
SOURCE: Sony 46" LCD tv hdmi input replacement kdl-46v2500
replace that board
Posted on Mar 06, 2009
I solved the same problem by disabling SIMPLINK from OPTIONS menu. I own the LG TV myself. The LG TV comes SIMPLINK "ON" as default setting from the factory. Go to MEMU -> OPTIONS -> Turn SIMPLINK to "OFF". This should work....
Posted on Sep 23, 2009
  • 295 Answers
SOURCE: My Logitech Harmony does not move my Toshiba TV between inputs
It all depends on the Logitech remote's Harmony features. Can it you place your original Toshiba remote IR sensor up to the IR sensor on your Logitech and learn from the Toshiba remote?
Posted on Nov 19, 2009
  • 75017 Answers
SOURCE: I have a Bose home theater system and a Sharp Aquos tv. I'm trying to hook up the Bose dvd directly to the tv. Problem - tv only has HDMI input capability and Bose does not. I purchased a HDMI convert
You haven't given any description about the converter you bought. Please send me the model number and brand name of the converter did you bought. OK.
Posted on Nov 20, 2011
Roku stick dosent do anything. ...? Plugged into hdmi slot on tv and also plugged in power cord to roku and nothing pops up on my tv...? Iv tryed to reset but dose nothing. ... help???
Did you change the TV input setting on your TV to the correct HDMI input? Most Televisions will take a few seconds to scan the input before displaying any image. Most newer televisions have multiple HDMI inputs, and you might need to select each one, wait several seconds to see if there's a signal, and then move on to the next input, until you find which HDMI input has the Roku start screen signal.
Dec 09, 2014 | Televison & Video
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
Not detecting devices
test this steps and fix it. God bless you
    • 1
      Check the back of your Sharp TV for the HDMI input. These will be long, thin rectangular jacks labeled "HDMI." Most Sharp TVs will include another label on those jacks with an input number ("Input 5," "Input 6" or the like). Remember that number. It will have a bearing when you turn on the TV.
    • 2
      Connect one end of an HDMI cable to the input jack on the Sharp TV and the other end to a compatible component such as an HD DVR from your cable/satellite company or a Blu-Ray disc player. The TV won't broadcast in HD if you can't connect these devices with an HDMI cable (though it will still broadcast in standard definition using RCA cables or S-video cables).
    • Sponsored Links
    • 3
      Turn on the TV and the requisite component (Blu-Ray, DVR).
    • 4
      Press the "Input" button on your remote. A list of signal sources will appear on your screen ("Input 1," Input 2," etc.). Use the cursor to maneuver down to the input number corresponding to the HDMI outlet you just hooked up and press the "Input" button again.
    • 5
      Press the "Menu" button and maneuver the cursor to select "Option." Go to "HDMI Setup" and press "Enter." Move the cursor up or down to the desired item and hit "Enter" again. Then move the cursor from side-to-side to select the proper setting. Hit "Enable" to allow the Sharp TV to automatically recognize the HDMI signal and "Digital" to get the proper audio signal from the HDMI cable. Then hit "Enter" again.
    • 6
      Exit the menu and watch TV as normal.
Read more:
Jul 25, 2013 | Seagate 1TB GoFlex Cinema Multimedia Drive...
When i connect my onkyo ht-5300 system to my 60"sharp aquos tv with hdmi cables i get no video or sound
You need press the input button on your TV's remote.Then you need to select the input setting for HDMI.On mine,there is also an HDMI 2 input so depending on how your's is wired,it could be either one but that should get you what you want to achieve.Good luck,Greg
May 02, 2011 | Onkyo HT-S580 System
I have a Hitachi p50v701 50" plama tv. Recently
I know it Sounds silly I also have a Hitachi TV and got issues with HDMI, I unplugged from wall for 15mins and turn it back, then I tried my PS3 and worked.
If not there is a firmware update on the website however it needs to be uploaded by a "technician" via USB drive mine has a USB port but there is no update for mine.
Let me know if it works
Mar 16, 2011 | Hitachi P50V701 TV
I just bought a Denon AVR 1611. All inputs are HDMI (Cable TV, Blu-Ray) and the monitor output to the TV is HDMI. ainly I listen to the audio out of my TV and occassional on my surround sound. I would...
avatar7.jpgcurt, I bought this Denon AVR 1611 and I have HD cable. If you have cable you can set it up two ways. First way (the way I have it) is to get a switch box with 2 HDMI
out (mine has 4 inputs and 2 outputs) and maybe 2-4 inputs. Put the cable from the wall in one of the switch box inputs. Now hears the cool thing. Put 1 of the outputs from the switch box to the Sat/Cable input on the 1611 then put the another output to your tvs HDMI input. This allows you to switch from the tv only output or the 1611 surround output without touching the switch box. The other way is to buy a converter from HDMI to VGA. The only thing here is that you would have to setup your sound through Aux in the front of the
Mar 06, 2011 | Audio Players & Recorders
Flat screen to dvd connection help!
It depends on the TV.
On my Phillips TV this is switchable via the TV setup menu, and you get no sound with HDMI unless you change that setting.
The reason it's switchable is that the HDMI input is usually common with one of the component-video inputs (AV3 on mine). (cost saving move)
Thus if the menu is set to hdmi, then the audio goes thru hdmi. If it's set to 'component' then it goes thru the RCA patch cable.
Oct 07, 2009 | Televison & Video
No signal
mine did the same was on rgb...didn't have ability to plug in computer to tv as suggested previously and I kept trying to hit input button on side of tv after turning tv on..didn't work but when I pushed input button before turning on tv when i turned on tv input screen was up and was able to move input to hdmi...everything works now.
Jan 04, 2009 | Vizio L32 32 in. LCD HDTV
HDMI input
The green screen is caused by light hitting the back of the tv. Either move the tv to a location where direct sunlight will not hit it or put up strong curtains. As for fixing the problem, do a search for JVC green screen reset on AVS Forum, its easy to do just dont have the info with me now. Keep in mind if direct sunlight hits the back of the tv it will do it again. I have put up some good curtians and ensure not to open them when watching the tv. Hope this helps. I am Hayward, have a nice day.
Aug 21, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
