Question about Makita Drills
Hi. I have a makita 08070 hammer. when I will start this the power light is work but machine not work
    New Friend:
  • 26 Answers
Australia Drill Battery offers a complete and comprehensive product line of high quality MAKITA power tool batteries. Our MAKITA drill batteries are designed to be fully compatible with the original cordless tools.
Posted on Jul 21, 2017
  • 2176 Answers
SOURCE: Hammer switch jammed on Makita HP1621K/2 Percussion Drill 2
I looked at website and it appears that you might be correct. there are 4 parts to this assembly and one of the problems might be the cam holder position #17. I would suggest that you go to their site and take a look at how the parts are supposed to be. I used the model number in the large header so this might not be the exact one that you have. Let me know and I will try and help further.
Posted on Feb 06, 2009
SOURCE: Why doesn't my HP 1501 Makita hammer drill work
The problem was the cord at the base of the drill. The wires were broken, cause by constant bending. After souldering the wires, the drill works perfectly.
Posted on Jul 29, 2009
SOURCE: Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
Posted on Oct 11, 2009
  • 885 Answers
SOURCE: wiring diagrams for makita hammer drills
Go to, put your model number in the search box and the parts breakdown and owner's manual can be viewed or downloaded.
Posted on Jan 16, 2012
  • 304 Answers
The big control levers off, but the small one only comes off once you have removed the screw and have it in the down position.
Posted on Nov 14, 2012
I have a PH65A Makita hammer demolition and it start working for about 10 seconds breaking and after that the hammering power slow and losses it's power hit even that motor keeps working, why?
first ordernumber 931848 lubrication necessary it has its working hours on it.
parts to change in priority
1 x 944-927 , 949457Z , 956-960 , 944-936 , 956-965 ,
999032 , 956-996 , 944-928
the important thing is that the machine is airtight at the front so as not to burn the O-rings through the air and incoming dirt friction look the orings good and if the lock bolt on the front feel not smooth replace that also and every oil seal you can find its different what should neccesary but that the tool runs with thick and dirt beaten oil . solvent clean the hard metal parts and replace if there are grooves on or cracks
Hitachi PH 65A Demo Hammer Parts
Feb 28, 2016 | Makita Hammering
What type of oil shall be used in makita hm1304 demolition hammer?
You require Hammer Grease, All good tool shops should have grease to suit. see link below:-
Hammer Grease 90582 for Makita Power Tool eReplacement Parts
Feb 11, 2016 | Makita Hammering
Makita instructions
Get the battery tested. The light draws a very small amount of power and will work if the battery is just about dead, but to operate the drill, you need a strong battery.
Jul 27, 2014 | Makita 18v Lxt Li-ion 1/2-in Hammer Drill...
I have a makita hm 1810 hammer green light stays on hit switch light goes off
As stated in the manual:
The green power-ON indicator lamp lights up when the tool is plugged to the mains. If the indicator lamp is lit but the tool does not start even if the tool is switched ON, the carbon brushes may be worn out, or the motor or the switch may be defective. If the indicator lamp does not light up, the mains cord or the indicator lamp may be defective.
Aug 25, 2012 | Makita HM1810 Electric Demolition Hammers
It wont hammer when I put a small or large amount of pressure on the hammer. It hammer only a short while when I start the mammer (about 1 second) and the same when I release the button.
Lack of hammering action usually indicates a lack of lubrication or worn piston orings. This hammer as well as many other makita hammers work with a piston moving forward and back within a cylinder. This piston moves a second piston within the cylinder with a pocket of air (pressure and vacuum). If there is a lack of lubrication or orings are worn, you will not get a good hammering action /force out of the second piston. Time for good cleaning and apply factory lube. Parts are at Good luck
Apr 12, 2011 | Makita HK1810 Power Scraper, Small,...
My makita hmo860c breaker drill has stopped working power light is on ?
I purchase a rotory hammer on ebay and it was listed as a makita, i was trying to get a spare part for it from makita. I gave them the information that is printed on a lable on the side of the drill, 66015c, 850W 110V,26mm and to my suprise they told me that it was not one of their drills, I have a few of these drills still being sold on ebay as makita. is there anyway that anyone can help me with this query.
Aug 30, 2009 | Makita Hammering
Makita 8406C Gearbox oil
It uses grease to lube the gearbox. makita supply their own grease so you should be able to get a small tube from your local dealer. You don't have to use Makita grease though, just general grease should be fine. Not too thick and heavy, or too oily and light. I know that sounds a bit vague. Do you have other machines that you have grease for? SDS hammer drills, saws, any small power tool like that will use a similar type of grease.
Nov 01, 2008 | Drills
Drills Logo
324 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
