Garrison Infrared Heater Model #043-5997-6 has an E3 code flashing. What does this mean and can I do something to fix it?
3 Suggested Answers
SOURCE: garrison tower heater flashed E3
hi there, i just ran into the same problem i think i have the solution:
the E3 code is a "fall down" sensor shut off, what i think the problem is the internal sensor for when the unit falls over and shuts itself off is really sensitive. i had mine on carpet and it was acting up quite a bit till i wiggled it and put it on a more level surface.
hope this helps
Posted on Jan 08, 2011
siyabongamzi
  • 173 Answers
SOURCE: Infrared heater model CZ20110. Is flashing E3 on
Ithink you must open it and check it inside for loss wires
Posted on Sep 13, 2014
Manual for garrison oil heater model #043-5863-4
You should be able to download a manual here:
garrison oil filled heater model 043 5863 4
Also please be advised, your model may be under recall due to fire hazard:
http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2013/36781r-eng.php
Nov 16, 2016 | Heating & Cooling
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
I have a Garrison electric portable heater which shows a code FF. What does code FF mean? Thanks in advance.
You might want to check with Garrison, there was a recall on some models last year. It might be worth your time.
Jan 27, 2015 | Heating & Cooling
Garrison heater manual
Contact company, they should give you a link to download a manual or way to purchase an actual ma
Apr 23, 2014 | Heating & Cooling
I just got a life smart infrared heater took it out of the box plugged it in and turned it on and an E3 code is flashing wont turn on or any thing
What is wrong with my Comfort furnace, If it will not turn of when i push the off butting ?And even after that i unplug it and turn it back on ,it still comes on and will not go of like it use to with the temp control !!
Nov 30, 2013 | Comfort Zone CZ1500WC Infra-Red...
E3 error on LIfesmart heater
Even after replacing thermostat and motherboard offered from company, my heater would trigger e3 error code and shut off. After several (maybe 100!) different attempts to plug in and operate, here is what worked for me!
Depress the power button on the heater while plugging in to wall circuit. Continuously depress power button. It will run through a test cycle and attempt to start. Keep depressing the power button as the heater tries to start, then shuts down with e3 error. While the power button is still depressed, unplug the unit from the wall. When I plug back in the wall the E3 error is gone. Good luck
Nov 03, 2012 | Lifesmart DYNAMIC 1000 to 1100 Square Foot...
Garrison tower heater flashed E3 code?
hope this helps
Dec 25, 2010 | Vacuums
Is there a quick fix to a flashing e3 on a Danby DDW497W?
Refer the user manual for your dishwasher. Error codes are given on page 7.
e3 means the heater is not working or the thermostat (which checks the water temperature) is faulty.
Not sure there is any quick fix other than to replace. If the heater is showing some reading on an ohm meter then it is likely the thermostat is faulty. In any case it will be easier and cheaper to replace the thermostat first.
You will need to call Danby service closest to you for advise on getting the parts or servicing it.
Please rate this solution to help fixya serve you better in future.
Oct 06, 2010 | Dishwashers
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
