Question about Hardware & Accessories
How do I repair a valve on the 3280-4 melnor waterer
Melnor sprikler not ocillating
Do you have hard water? They operate via a water pressure powered mechanism, either the mechanism is stuck and needs a push, there is insufficient water pressure, or it is clogged with sediment.
Jul 10, 2016 | Melnor Oscillating Sprinkler
The brand new timer just installed is leaking profusly from the connector to the faucet...?
turn water off at the main then put Teflon tape on threads then re attach..................problem should be solved
Apr 18, 2016 | Melnor 3280 Digital Aqua Timer Watering...
How to fix a melnor 4 zone digital timer with stuck valves?
bleed the air out of each valve then re tighten bleed screw. if still stuck open then buy new diaphrams
Dec 13, 2015 | Melnor 3280 Digital Aqua Timer Watering...
LEAKING AT INPUT
Get some teflon tape and wrap threads then re attach hose
Jun 23, 2015 | Melnor 3280 Digital Aqua Timer Watering...
I have a Melnor 3015 aqua timer (2007 model) that leaks. I am fairly certain it is the connection between the solenoid and the valve but I cannot figure out how to open the thing without breaking the
It's made that way. The case is not meant to be opened, it's a sonic weld (melts the plastic together). It's meant to be a disposable device; it breaks throw it away and buy a new one. Also known as planned obsolesce.
Jan 24, 2015 | Melnor 3015 6 Zone AquaTimer
My melnor 3100 electronic water timer wont shut off
My acqua 3100 is locked with the valves, what should I do to fix?
May 24, 2014 | Melnor 3100 Two Zone AquaTimer
Need to known how to set the timer do not have a manual we have the VIGORO deluxe water timer, they are about two years old.
I do not know how to set the timer, but can offer possible source for manual.
VIGORO timers can be same as Melnor:
Match up image with your timer and then download manual.
Water timers last 1 or 2 seasons. There is no repair for broken water timers.
http://www.melnor.com/instructions.php
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | Hardware & Accessories
Hardware & Accessories Logo
195 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
