Question about Sewing Machines
How to thread my 9410 machine - Sewing Machines
  • Sewing Machines Master
  • 10,267 Answers
Search for:
Make Model manual
Posted on May 10, 2017
I need to know the name of a part
If you will go to the Singer Sewing Machine site and type in "replacement parts chart" in the search box, you can download the parts list for your machine. Takes a little perseverance, but you can locate your part and its parts number there. Here's the direct link. http://parts.singerco.com/CPpartCharts/9_99999/9410.pdf
Oct 02, 2014 | Singer Sewing Machines
My 9410 wraps the spoon thread around the bobbin. the thread on the bobbin seems to be hard to pull off once the bobbin cover is closed
Got the correct bobbin for the machine? Is it in right way around? Once you've raised the bobbin thread out the needle hole, it should pull smoothly and relatively easily. Might also being snagged on a rough spot on the needle plate (=throat plate) or presser foot. Or has someone been playing with the bobbin tension? That's normally not something the user adjusts for normal sewing. Your machine takes class 66 plastic bobbins: http://www.dritz.com/askus/knownotions/index.php They're the ones with the sides that are slightly curved in at the edges, like two dinner plates facing each other, while the 15s have perfectly straight sides.
Apr 28, 2014 | Singer Sewing Machines
The bobbin housing in singer model 9410 keeps moving out of position
After you put the bobbin case in, release it, and then pull on it to make sure it is in correctly.
The gathering is called a "bird's nest", and is caused by the machine not being threaded correctly.
Rethread the machine top and bobbin.
Then, sew a test stitch on a scrap of like material.
Apr 08, 2013 | Singer Sewing Machines
Free singer sewing machine manuals downloads model 9410
my singer model 9410 will not go forward but will go in reverse
Aug 18, 2010 | Singer Sewing Machines
Singer 9410 bobbin problems
It should not affect the winding, the reason the needle is still going up and down is because the oil has gone dry on the shaft and unless you can get to the shaft where the balance wheel is then it would be wise to take the machine in for a service, loose stitching on the bottom is a tension problem, make sure the top tension is set about 4 or 5
Oct 26, 2009 | Singer Sewing Machines
I have a Singer 9410 sewing mach. w/ tension & peddle problems
Be sure you are using a Class 66 bobbin for this Singer machine. Using another style bobbin can cause tension problems and thread looping/bunching.
Apr 23, 2009 | Singer 7442 Mechanical Sewing Machine
Singer 9410 Bobbin
Update:  Today I took my machine in to get serviced - they replaced the metal bobbin I was using with a plastic one, that was a little less rattley inside the bobbin case, replaced the needle with a new, universal one, and changed out the thread with something a little higher quality.  They also adjusted the spring holding the bobbin case slightly, and now it seems to work fine.  I'm not sure how long it will last, but for now I'm good.
Oct 02, 2008 | Sewing Machines
Singer 9410 Bobbin
I had the same problem and after looking on here and finding no answer I went back to my machine and found out what the problem was...ok, where the bobbin case sets in,the metal plate beside it needs to be fitted right close to the bobbin case, so loosen the screws(just two of them) that are in the plate(DO NOT REMOVE JUST LOOSEN) and slide the metal plate over some just enough to fit snug...NOT TOO TIGHT... if its seems to sew too tight loosen it a bit It worked for me, GOOD LUCK
Nov 11, 2007 | Yamata FY700 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
