Question about Kodak Office Equipment & Supplies
The slide carousel not loading properly on Kodak 750 profector
  • 412 Answers
SOURCE: I bought a used kodak
The KODAK Carousel 650 was manufactured approximately between 1964 and 1971.
Try removing the tray and pressing the cycle button(s) on the side of the projector. Watch the levers in the cut-out on the top of the projector. The lever closest to the rear of the projector should move back & forth (as you actuate the cycle buttons). The lever toward the front of the projector should extend and push forward (front of the projector) when you push the "forward" button, & extend and push toward the rear in reverse. If you are not seeing these levers move as described, then the chances of your projector needing a repair are likely. The good news: parts are still available. The bad news: You will have to find a factory-trained repair dealer to make the repairs for you.
Posted on Nov 04, 2010
  • 412 Answers
SOURCE: We have a Kodak Carousel 650A projector. (140
The purpose of the "SELECT BAR" on a Carousel 650H is to eject the slide. If you press & hold the select bar it allows you to rotate the tray to the slide you want (or Zero & remove the tray). If you can not advance or reverse the slide tray using either the remote buttons or the buttons on the side of the projector, then chances are you have a broken part in the slide change mechanism. The possibilities are numerous, and really requires a trained tech to analyze your specific failure. Sorry the news isn't better (or simpler!).
Posted on Nov 12, 2010
  • 412 Answers
SOURCE: I'm having a problem loading a tray onto my kodak
First, with the tray off the projector, cycle the projector several times in forward and then in reverse. Next, check to make sure the locking ring on the top on the slide tray is LOCKED ON TIGHT. Then turn the tray upside down. On a 140 Slide tray there is an index notch. On the metal plate there is a index hole. Gently release the metal spring of the tray latch and rotate the metal plate until the notch and hole line up. Now the tray should drop on the projector and index properly.
Posted on Dec 03, 2010
  • 412 Answers
SOURCE: my slide projector carousel does not advance
Does the projector run in reverse?? If so, then what you are facing is a timing adjustment.
If it does not cycle in either direction, then there is a high probability that the solenoid "link" is broken. The "link" connects the cycle solenoid plunger to the slide change mechanism.
The good news: There are still parts available (www.micro-tools.com). The less-than-good-news: both fixes are difficult and best handled by a factory-trained repair dealer.
Posted on Dec 30, 2010
  • 412 Answers
SOURCE: properly loading the slide tray
If the first slide is visable and consecutive slides are not, the "dark shutter" (a feature that prevents the eye-popping bright white screen when no slide is present) needs adjustment. A fairly easy adjustment for a factory-trained service dealer with the service manual and the correct tools.
Posted on Jan 04, 2011
Kodak carousel 750H slide projector power cord missing
Detatchable power cords for KODAK Carousel Slide Projectors can be purchased from: www.micro-tools.com
or: www.vinevalleyimaging.com
Good Luck!! jim
Sep 13, 2013 | Kodak Carousel 4600 Slide Projector
How do I properly install the carousel? It's not advancing I think it's not on properly.
It is a while since I have handled one, but as I remember, you have to line up the number 1 slide position with the slot in the projector and then it clips into place with a little pressure.
May 17, 2011 | Kodak Carousel 4600 Slide Projector
I have an old Kodak Caromate 3300 slide projector. Can I get a manual for this? I cant get it working properly, ie carousel will not move forward and slide cannot be viewed.
Is it a Kodak AudioViewer or a Caramate 3300?? hard to tell from the problem description.
If it is a Kodak branded unit, I know Kodak doesn't have the manuals any more, so my advice is to contact a factory-trained service dealer to see if they still have a service manual!
If it is Caramate branded, I'm really not sure where to send you. There were subtle design differences between the 2 brands!!
Good Luck !!
Feb 04, 2011 | Kodak AV210P 80 Slides Rotary Carousel...
I have a Kodak Carousel 750 H and need a cord. Where can I find one?
You can contact Micro-Tools (www.micro-tools.com). They have the cords (and many other projector parts) in stock.
Oct 27, 2010 | Kodak Office Equipment & Supplies
What is the correct carousel for a kodak 760 H projector?
A KODAK Carousel 760H is designed to be used with either KODAK 140 or KODAK 80 Slide Trays. The KODAK 80 Slide Tray has wider slide compartments, which tend to be more forgiving for older, slightly warped slides.
Oct 02, 2010 | Kodak Office Equipment & Supplies
I'm having a problem loading a tray onto my kodak carousel 4400 slide projector any solutions?
Jan 14, 2010 | Kodak Carousel 4400 Slide Projector
My slide projector carousel does not advance
Nov 20, 2009 | Kodak Office Equipment & Supplies
Trying to find a carousel that will fit Navitar model CP-300AF
I am pretty sure that the projectors modified, marketed & sold by Navitar were Kodak projector bodies & slide transports. Assuming this is the case, a Kodak 80 Tray should work just fine!
Aug 03, 2009 | Navitar 750-AF 35mm 80 Slides Rotary...
Properly loading the slide tray
Jan 11, 2009 | Kodak Carousel 4600 Slide Projector
29 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
