Question about Garden
Push mower starts and runs fine but when I stop to empty bag refuses to restart
  • 313 Answers
SOURCE: Mower won't start
13 to 15 amps electric or battery operated mower may runs slow when cutting thick grass. also recommended not to cut grass when it's wet & need very sharp blade to do the lawn. may overloading it, cutting grass too thick also draws too much power. check house breaker first.
Posted on Jun 11, 2008
wadembly
  • 513 Answers
SOURCE: bog when trying to mow
you are cutting to much grass & it isn't kicking it out fast enough out of deck which will bog it down it might help if you clean out the bottom of the deck & also dont cut really low if grass is really tall also cutting wet grass will aslo cause the bogging if i can further help e-mail me wade at wadembly@aol.com
Posted on Jun 28, 2009
  • 127 Answers
SOURCE: Mower deck will not engage.
you have sheared off the keyway either on the mandrel or pully on the engine
Posted on Jun 30, 2009
  • 8 Answers
SOURCE: I have to prime the toro mower every time I empty
  1. what is the model, manufacturer and year of mower?
  2. has any maintenance been performed on this mower?
  3. if no, try replacing the spark plug and air filter (it's possible the spark plug could be fouled and/or the air filter is clogged) be sure to follow the manufacturers recommendations for oil, gas, filters and plugs.
routine maintenance involves:
  1. sharpen/replace blade
  2. oil change
  3. replace air filter
  4. replace spark plug
  5. new gas
Posted on Sep 03, 2009
  • 640 Answers
SOURCE: first start is excellent when cold, will not restart again warm
It sounds as if your engine may be getting too hot. I suggest that you check under the covers and make sure that all the debris is cleaned out. These are air cooled engines and as such need to be kept relatively clear of debris, especially anywhere there are cooling fins.
Posted on Aug 12, 2010
Worx mower. I was mowing fine..stopped to change bag.. Wouldn't restart when pushed the key button. handle engaged and it would power move forward. Engine would not start.battery fully charged
sounds like, a valve clearance adjustment problem. starts when cold, looses some power when hot, if turned off or stops, won't restart until cold.
Aug 04, 2015 | Garden
I have a 725 & an 825 series engines on two lawn mowers. They are almost impossible to restart after they have been run & you stop for fuel or to empty the bag. Can you suggest a solution ?
Run a compression test to find out the condition of the piston rings and valves. Low compression on a hot engine indicates either worn piston rings or not enough clod clearance on the valves.
Jun 20, 2015 | Garden
Toro personal pace 20372, starts fine, runs well for 30 or 40 minutes then dies. Starts up again when cooled down just a bit.
Need fuel that is not more than a couple months old
Need a good or clean spark plug
Have no idea how old it is, or how many years
you have used it
Sometimes you have to remove the head & clean the
carbon off the piston & head
That is a tune-up on small equipment
Make sure the air filter is clean
They usually start with the air filter off,but you don't
want to do that all the time
Jul 21, 2014 | Toro 20372 Recycler Personal Pace...
Husqvarna self propelled lawn mower
Fuel problem. Disconnect fuel line from carb. No fuel, go up the line. Filter, open line, plugged fuel cap vent.
Jun 26, 2013 | Garden
My mower starts fine cold, just a few pulls to get it going, but then when i stop it to empty the bag, it has to sit for like 30 minutes before it will start again. It doesnt seem to be getting overly...
You should check for spark when this happens next time.
Usually this kind of no start problem is related to a heat damaged ignition coil.
If you check for spark and have none you will need to replace the coil.
The good news is they arent too expensive and you can replace it yourself with only simple hand tools and playing card *(yes, a card from a poker deck!).
If you end up replacing the coil you might find that an animal made a nest under your recoil housing too! This is probably what lead to the overheating and failure of the coil. I see it all the time.
Good luck and be careful!
Jun 18, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Stopped to empty bag now won'tstart.
CK TO SE IF YOUR BAG IS ON ALL THE WAY SOUNS LIKE THE SAFTEY SWICH IS NOT PUSHED DOWN ALL THE WAY
Sep 27, 2009 | Garden
Toro Lawn mower, 22" push mower
It sounds like the small orifice in the fuel bowl is clogged. This could be from dirt or varnish that collect in the gasoline over the winter if you don't empty the tank and run the mover dry before storing. If you are not mechnically inclinded, take it to a dealer and they will clean out the fuel bowl. Easy 5 minuite job.
Apr 27, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
