Question about The Computers & Internet
Where is the adjuster button is located at - The Computers & Internet
  • The Master
  • 1,830 Answers
There is an Alt button on the left hand side of keyboard next to the space key.
Posted on May 09, 2017
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
How do I adjust my headlamps
link to headlight adjusting should be similar to yours, press the helpful button
Adjust the headlight on Kia Optima Magentis Ajustar los faros en Kia...
Jan 17, 2016 | 2007 Kia Sorento LX
How do you adjust brightness on a Gateway ZX4971. There are no buttons on the monitor.
My Gateway monitor instructions refer to buttons located on the right side. The procedure calls for pressing the Auto button first to set the display image for the current screen resolution then pressing the Menu button to open the on-screen display (OSD) menu. You can move through the OSD menu to select parameters such as Picture (brightness).
Dec 18, 2014 | Gateway Computers & Internet
How do I turn off the alarm on my timex expedition model wr 50m (analog)? Also, I have searched and searched the web and am unable to locate a manual to download to assist me with other features on this...
I hope you find this tip helpful! Turning off alarm on wr 50m sports watch (4 buttons)
Look at your watch to see if the alarm (shaped like a bell) and hour chime (shaped like a pacman) are displayed.
If Both are displayed:
  1. Hold down the Adjust button and press the start/stop button twice
If the Hour Chime is only displayed:
  1. Hold down the adjust button and press the start/stop button three times
Apr 12, 2011 | Watches
How to set
Hello
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner
Mar 15, 2011 | Seth Thomas Radio-Controlled Howard Wall...
Where is the kick cble located on a 1990 chevy blazer,my blazer wont shift to 2ng gear
It is located on linkage on throttle body.ene cable is throttle cable,one is cruise if equipped, and the other one will run to the transmission. It has a button you mash to adjust.It isn't obvious but you can get a screw driver and mash release/button and adjust. called detent cable.
Feb 15, 2011 | Chevrolet Blazer Cars & Trucks
How do I set the time on a sports air warch
Q. How to set my watch A. The A and M button are located on the back of the watch LCD screen. When looking at the watch right side up the A button is the one on top and the M button is located below the A button.
1. Press A button twice, the month figure appears, press M to adjust the month.
2. Press A button once, the date figure appears, press M to adjust the date.
3. Press A button once, the hour figure appears, press M to adjust the hour.
4. Press A button once, the minute figure appears, press M to adjust the minutes.
5. Press A button twice to finalize the settings!
sports air watch
Dec 13, 2010 | Watches
Need instructions for t436b night light
Here is a link to the manual.
http://www.timexaudio.com/pdf/T436_IB_(new)_v3b40949_96.pdf
From the manual here is how to set the time.
2. Press and hold the Time Set Button until the time display blinks.
3. Press the << or >> Button to adjust to the correct time. Press and hold the button for faster forward or backward
adjustment.
4. Remember to set the correct AM or PM. The PM Indicator is located on the upper right side of the display;
there is no AM indicator
5. Press the Time Set Button again. The year display will blink.
6. Press the << or >> Button to adjust to the correct year. Press and hold the button for faster forward or backward
adjustment.
7. Press the Time Set Button again. The date display will blink.
8. Press the << or >> Button to adjust to the correct date. Press and hold the button for faster forward or backward
adjustment
9. Press the Time Set Button again or wait for about 10 seconds to exit the time setting process. Two beeps
will confirm time setting mode is complete.
Sep 08, 2009 | Timex T311T Clock Radio
Picture blury
Its behind the speaker grille up front , remove the grille and then a small access panel and you will see the focus control with 1 button for each CRT 3 buttons in all.
Jun 16, 2008 | Samsung PCL545R 54" Rear Projection...
Set the clock
You are in luck. I had to replace the batteries in my DWS-150 & couldn't find the instruction manual to reset the time. Fortunately, I remembered a while back I had the same situation & thought I might have downloaded the manual - while it was still available. Ifound I have it saved as a pdf file on my pc. Here are some excerpts: About the Atomic Clock The National Institute of Standard and Technology (NIST) in Fort Collins,
Colorado broadcasts the time signal (WWVB at 60kHz AM radio signal) with
an accuracy of 1 second per every 3,000 years. The signal will cover a
distance up to 2,000 miles from the source. Like a typical AM radio, your
Atomic Clock will not able to receive the WWVB signal in places
surrounded by heavy concrete or metal panels. The reception of the time
signal can be affected by mobile phones, TV, electrical appliances or other
electronic interference. To get the best performance of the Atomic clock,
please install the home receiver near a window and away from large metallic
objects. If the unit is not working properly, change the unit position. There
may be some interference at this location.
7
DWS-150-IB SP\ENG 10/12/04 11:30 AM Page 7
SETTING TIME
RADIO-CONTROLLED CLOCK
The home receiver will start synchronizing the clock after the 1st channel of
the RF thermometer is registered.
1. At normal mode, hold the “ - ” button located on the back of the home
receiver for 3 seconds to force synchronization.
2. The antenna icon will appear during the synchronization process (on the
right side of the time display).
3. If the icon disappears afterwards, radio time signal is not available at that
moment. Try setting the home receiver in other locations. Remember to
place the unit away from sources of interference such as mobile phones,
appliances, TV etc.
4. Antenna icon will appear on screen if the radio time reception is
successful. The radio-controlled clock will have a daily synchronization at 1:00 am everyday. If previous attempts of reception were
unsuccessful, the home receiver will attempt synchronization
each hour until successful.
5. Each reception cycle is minimum 2 minutes and maximum 10 minutes.
TIME ZONE SELECTION
Press “ - ” button on back of home receiver to select from the following time
zones in the U.S. (zone is displayed in the upper right hand corner of time
display).
P - Pacific Standard Time M - Mountain Standard Time
C - Central Standard Time E - Eastern Standard Time
MANUAL SETTING FOR CLOCK & CALENDAR
1. Hold “SET ” button for 3 seconds to enter clock set.
2. First, select 12 hour or 24 hour setting using the “ + , - ” buttons located
on the back of the home receiver. Press “ SET ” button to confirm.
3. Select Hour - Use the “ + , - ” buttons located on the back of the home
receiver to adjust hour setting. Press “ SET ” button to confirm.
4. Select Minute - Use the “ + , - ” buttons located on the back of the
home receiver to adjust minute setting. Press “ SET ” button to confirm.
5. DST On/Off (Daylight Savings Time) - Use the “ + , - ” buttons to turn
DST on or off. Press “ SET ” button to confirm.
Now you will select the calendar settings-
6. Select Year - Use the “ + , - ” buttons located on the back of the home
receiver to adjust year setting. Press “ SET ” button to confirm.
7. Select Month - Use the “ + , - ” buttons located on the back of the
home receiver to adjust month setting. Press “ SET ” button to confirm.
8. Select Day - Use the “ + , - ” buttons located on the back of the home
receiver to adjust day setting. Press “ SET ” button to confirm.
9. Select Fahrenheit/Centigrade Temperature Readings - Use the
+ , - “ buttons located on the back of the home receiver to toggle
between Fahrenheit or Centigrade readings. Press “ SET ” button
to confirm.
Mar 17, 2008 | Refrigerators
Computers & Internet Logo
23 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
