Step by step how to set time and shut off alarm and how to keep projection light display all the time
  • 201 Answers
SOURCE: phone set up
This phone is a Merlin Magix system phone. The time is stored in the main control unit, not the telephone. You have different times on different phones??? I do not see how this is possible unless the clock is broken and not updating the phones with the correct time. If that was the case every time you unplug a phone and re-connect it the time may be reset to 12:00 on that phone. Avaya has all their manuals available on their web site. I'd suggest going to www.avaya.com and searching for "Magix time"
Posted on Aug 29, 2007
  • 61 Answers
SOURCE: Time Date
when you fist turn it on you need a name just hit any letter, then hit the A conferm all the way across the board (A for everything) turn the system off wait 10 sec. turn back on you now should be able to change whatever you like without any trouble
Posted on Jul 18, 2008
  • 10 Answers
SOURCE: I need to set timing on a c1500 1993 4.3
If it is the same as the 4.3 in my 93 s-10 blazer the firing order is 1,2,3,4,5,6 with 1 being front dead center of ditributor(closest to intake manifold) if it is located at rear of engine. As you're standing in front of vehicle facing engine front right cylinder is #1 middle is #3 rear is #5. On left side #2 is front #4 is middle and #6 is rear. On my Blazer I have to disconnect the EST wire which is located inside the vehicle just below heater housing on passenger side(at top of floor carpet) in order to set timing. It is a single wire connection. Don't know if it is same location in the 1500. There should be a lable on top of the radiator area with the degree to set timing at. It is 0* for the s-10. If you have a parts store handy and have a few dollars available pick up a Chiltons soft cover repair manual for you vehicle. I got one for mine and it has been really useful. Hope all of this is helpful. I'll check to see if you get it set. KS
Posted on Mar 19, 2009
ib_yang
  • 1098 Answers
SOURCE: my balance board keeps telling
The sensors need to be reseated.
  1. Take the batteries out.
  2. Take out the screws from each foot in every corner of the board using a Philips screwdriver. Remove the back cover.
  3. The sensors are located on each corner, it is a metal plate. Loosen the screws using TORX screwdriver.
  4. Re seat the small metal plates by putting it back. Don't screw too tight.
  5. Put the cover back and foot on. Put the batteries back in.
Posted on Jan 01, 2011
SOURCE: nexxtech 4-in-1 universal remote control 1519010
I just downloaded a zip file containing the code list here:
http://files.remotecentral.com/manuals/19-1/nexxtech_(orbyx)/date.html
Posted on Dec 25, 2011
How to reset sony tv KDS.60A2000 after replacing lamp so the warning doesn't keep coming on
With the set turned off:
RESETTING THE LAMP TIME
When replacing the lamp, use the following to reset the lamp time.
1. If the Self-Diagnostic screen is already displayed, proceed to step 4.
If not, Power off (Set to Standby mode).
2. Press DISPLAY Channel 5 Sound Volume -
POWER
3. To access the Lamp reset, press 5 until the TIME category displays.
4. Press 1 until the RSET item displays.
Mar 01, 2012 | Sony KDS-60A2000 60" HDTV
Tip
TGHK watch instructions
This is not for Tag Heuer, it's for TGHK watches.Here's the procedure: Press the MODE switch to step through the modes until you see the seconds blinking (righter after the ALARM set mode). Press the RESET switch to advance to the function you want to change (e.g. hours). Press the START switch to increment the hour to the correct time. Press the RESET switch to advance to minutes and, again, increment the setting using the START switch. (Hold the switch down to advance the numbers rapidly.) When you have stepped through all the elements and have everything as you want it, press the MODE switch once to return to normal time display. To set the ALARM: Press the MODE switch to display the alarm function. Press RESET once to see the hours blinking. Press the START/STOP switch to advance to the desired hour. Press RESET to advance to the minutes and set the minutes using the START/STOP switch. Press the RE#SET switch. The time will stop blinking. Set the alarm sound for either ALARM or CHIME using the START/STOP switch. Press MODE to return to the time display. To turn the ALARM off: Press the MODE switch to advance to the alarm mode. Next to the AL indicator there will be either a small ALM or CHI displayed. Press the START/STOP switch until they both are off. Press MODE to return to the time display.
on Mar 18, 2010 | Watches
How do i set my alarm and when do i know it is on or off....keeps coming on and i dont know how to shut off the alarm...thank you
This clock radio features a dual alarm system, with two separate alarms that can be operated independently. The alarms can be set to wake two people at different times, or to have a main alarm and a backup. One alarm features your choice of radio stations as an alarm wake sound, while the second features a buzzer wake sound. You can set the radio alarm, the buzzer alarm, or both alarms.
Setting Radio Alarm
1. Press the "Alarm Set" Button. The display will flash and the Radio Alarm Indicator will appear. If you do not begin setting the time within ten seconds of pressing the it, the display will stop flashing andd you will need to press the "alarm Set Button again. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time. Hold a button for a few seconds to advance the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator. 3. After setting the radio alarm time, you will need to select the station to wake up to. First, press the "AM/FM" Button to select a radio frequency. Next, select a station using the "Radio Preset Buttons". Rotate the Volume Thumbwheel to set a wake sound volume level. 4. After setting the radio alarm wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date is set. 5. After you have set the radio alarm wake time, wake sound, and 7-5-2 setting, press the "Alarm Set" Button twice so that the display shows the standard, non-flashing display.
Setting Buzzer Alarm
1. Press the "Alarm Set" Button twice. The display will flash and the Buzzer Alarm Indicator will appear. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time, as described above. 3. After setting the buzzer wake time, use the "Date/7-5-2" Button to select the buzzer. 4. After you have set the buzzer wake time and 7-5-2 setting, press the "Alarm Set" Button once so that the display shows the standard, non- flashing display.
Activating the Alarms
1. To activate the radio alarm, press the "Radio Alarm" Button so that the Radio Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 2. To activate the buzzer alarm, press the "Buzzer Alarm" Button so that the Buzzer Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 3. When the alarm sounds, press the " Off/Reset" Button to turn off the alarm while still maintaining the programmed 7-5-2 alarm settings. To turn off an alarm and cancel its 7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on the display. 4. To activate the snooze feature, press the "Snooze/Night-Light" Bar when the alarm sounds. The alarm will shut off for approximately nine minutes before sounding again. The feature can be repeated several times during the one-hour snooze cycle. 5. If it is not turned off, the alarm will sound for an hour before stopping. As long as an Alarm Indicator appears on the display, the alarm will sound at the set time, according to the 7-5-2 settings.
Mar 23, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
Bottom right button is light, not EI. top left is adj button left is mode top right is st/stp. I can't set time and date and can't turn off my alarm
hi..
El stands for
To set the time
  1. Press and hold [ Adj button ] till the digits on screen starts blink.
  2. Now Press [ Mode Button ] repetitively to cycle through Hour -> minute -> Seconds
  3. Press [ ST/STP button ] to adjust the value. Each press will increase the value.
  4. Press [ Adj Button ] again to save the changes
To set the alarm
  1. Press [ MODE Button] till it displays Alarm Time.
  2. Repeat steps 1 to step 4 as described in 'To set the time'
  3. Different watches have different procedures to active the alarm. Common method is pressing a button briefly.
    Since model of watch is not specified, Try pressing [Adj Button] or [ST/STP Button].
Mar 18, 2011 | Watches
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    My tv will not come on. The power light blinks 3 times, pause, three times, pause... Can you help?
    YES, IT is short protection and 98% chance one of the resistors that protect the convergence circuit is bad.
    Good news here:Set is fixable and total parts cost will be under 25 dollars (seller I know on Ebay).
    If you want to confirm this: with set unplugged, remove back cover and locate the two heat sinks with fins that have two of the STK-392-110 convergence chips---look at all the light blue resistors in front of them---I bet you find one white in the middle--gone.
    Set detects no voltage and a short and shuts down--3 blinks code.
    I have start to finish, step by step instructions for this repair that tell everything you will need and how to do the repair--the instructions are based on my own experience doing this repair in these sets hundreds of times.
    If photos and info here help and you want the step by step (I can not give my email here.....)rate this solution as very helpful as I am doing this here for free.
    SD TECH
    cd48042.jpg Chips look like this but metal in your set will be silver.
    protect resistors in front will be light blue in color and most will be marked 2.2 which means 2.2 ohms is value.
    SD TECH
    Aug 23, 2010 | Panasonic PT-53TW53 53" Rear Projection...
    How to turn off beepiing and alarm on sportline 240
    To set/Disable Hourly Chime/Alarm
    Step#1.Press "Mode" (center button) until you are at "Time Display" (the home screen)
    Step#2. Hold "Split/Reset" Button it will show the alarm time
    Step#3. Keep holding Split/reset button and press the "Mode" (center button) "Hourly Chime Is On" when dashes appear above display (in alarm mode) "Hourly Chime is Off" When no dashes appear!!!!!!!!!!
    Jan 24, 2010 | Sportline Stopwatch
    Sony kdf e50a10 Set works perfect for about 2-3 min, then shuts down, flashing green light 44 times then turns back on.Does this over and over till you turn it off. Tried resetting it several times.
    If you have not recently changed the lamp this is the problem. Purchase a lamp and install it yourself it is in the owners manual step by step.
    Aug 07, 2009 | Televison & Video
    TV turned off and now the power light blinks three times
    Very common problem. 3 blinks means the convergence circuit has failed . Heres a link to the repair kit for your model which contains both convergence IC and the feed resistors and the kit has step by step instructions with pictures so you can easially do the repair yourself.
    http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits/osCsid/e28ca8f8240833facd92d8890ef7e2b2
    Jan 19, 2009 | Panasonic PT-47WX53 47" Rear Projection...
    TV shuts down with Red Light blinking
    Thats an easy set to trouble shoot, but you would need the manual called toshiba power supply and shutdown circuit troubleshooter. It takes you step by step on the items to check so you can easilly pinpoint the problem. You can get that manual at the following link, they email it right after purchase and they also provide free one on one tech support so you can get help with it if you need. Heres the link
    May 10, 2008 | Toshiba TZ50V51 50" Rear Projection...
    Televison & Video Logo
    23 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
