Question about Garden
Mower kills in reverse when blade engaged - Garden
    Top Expert:
  • Garden Master
  • 12,744 Answers
Didnt specify unit --its a safety --you should have a bypas button or switch to go in reverse with blades engaged
Posted on May 09, 2017
Is there a safety mechanism / cable on Husqvarna LGT2554 that will not allow blades to engage if it runs out of gas while mowing
None. The only safety switch that prevent blades from engaging is the reverse switch but that will just kill the engine.
It is more likely that the deck drive belt has came off only of the pulleys.
Oct 19, 2014 | Garden
Mower cranks but when you engage blades the mower
Safety switch malfunction or something on the deck is locked up. The seat must be depressed & the mower in neutral or forward. No weight on the seat or placing it in reverse will kill the engine on most of them.
Sep 23, 2014 | Garden
My Zmax 25hp mower blades won't turn on??? Any ideas
Check battery connection and all wiring going to blade engagement switch. if there is a reverse kill switch make sure it is off.
Apr 19, 2014 | Garden
My craftsman 20 hp automatic lawn mower kills when i try to back up
It may have a safety lock on it causing you to not use the blades in reverse. My 07 craftsman has that safety feature.
Apr 13, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Apr 17, 2012 | Craftsman Garden
When in reverse the mower shuts off.
This is a safety feature on your mower
When you put the machine in reverse there
is a ground circuit that contacts the shifter and
kills the engine
Look down by the shifter you can see a bright strip of metal that will contact when the machine is shifted in to reverse
Apr 04, 2010 | Mtd LAWN MOWER PART # 17871D FENDER-REAR...
PTO red light switch is on when PTO isn't, so engine won't start
Mitch...the reverse safety switch, I beieve, is designed to kill both the motor and the blades if you don't use the override button prior to trying to mow in reverse. Since I don't know the make or model of your tractor, your not wise to reverse mow unless the override switch is engaged....hope this helps..
Jun 06, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Blades will not operate
Hi..my name is Keith..i dont know how new your mower is..but on the fairly new to new ones..there is a safety switch on the reverse that will shut the engine off if your try to mow in reverse...and thats the one that sounds like its at fault..i hope this has helped
Apr 11, 2009 | Garden
I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Mar 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
