Question about Elna Sewing Machines
I have an Elna 7000 which turns on properly but the foot pedal does not 'connect'. does not work. Can you advise please
rickzilla
  • 706 Answers
SOURCE: My foot pedal is really hot
Based on your description and since your sewing machine is older, the motor inside your machine is probably drawing more current to maintain the same output power and all that current is passing thru the foot operated switch.. What that means is that your motor windings may be breaking down from age and use or the contacts within the footswitch may be getting carbon on them from passing more current than the original design called for and becoming resistive ( which equates to it getting hot). I suggest you discontinue using it until you have it maintenanced to make sure you aren't risking a shock or fire hazard. Sight unseen, it's difficult to draw any other conclusion.
Regards,
Rick
Posted on Dec 02, 2008
SOURCE: elna 7000 computerized sewing machine
just wonted to see how much these elna 7000 are running now i have one but i just wonted to see what its worth now
Posted on Apr 13, 2009
Tally Girl
  • 1133 Answers
SOURCE: Can a genic foot pedal be used on an Elna Super?
Take a look at the side plate on your Elna and look for a two digit code, this is the model number.
I'm assuming that you are in the USA on 110 Voltage. If so visit this website,
http://www.sewingpartsonline.com/elna-sewing-machine-parts-model-list.aspx and choose your model. They sell replacement foot pedals, just check the profile of the plug that goes into your machine.
The other option is contact the Elna guru, www.whitesewingcenter.com, he stocks a wide range of swiss Elna parts and may have the original foot control second hand.
If you are on 240 voltage then you'll need to source it from a country that has the same voltage like UK, Australia or NZ.
Lastly, you may wish to join the Yahoo group called "ELna Heirlooms" this user group of Elna owners is really helpful and shares lots of their love and knowledge for these beautifully made Swiss machines. Many of them have even earlier models than yours such as the Green Grasshopper, the first Elna machine.
Posted on Dec 19, 2011
Tally Girl
  • 1133 Answers
SOURCE: WHERE CAN I GET AMANUAL FOR ELNA AIR ELECTRONIC TYPE 57.ALSO THE AIR FOOT PUMP DOES NOT WORK PROPERLY. ANY IDEAS
Have you checked the air line for any nicks/damage? these are pneumatic so firstly check the line and foot belows are intact, if you hold the plug end against your cheek and give the bellows a squeeze you should get a good blast of air. Sometimes the airline gets squished on the ground by a rolling chair wheel and this may damage it. There are parts available, and as its all just rubber line, there's no electricity involved in the foot control. For parts, try www.sewingpartsonline.com, or www.whitesewingcenter.com is the Elna guru in USA. If you aren't in USA, you may need to search locally for an Elna dealer, many parts for the Swiss machines are still available, just have to track down someone who will get them for you rather than try to sell you a new machine (for my money the TX is a sweetie).
If you have tried the airline and think its sound, then I'd suggest you jump over and join up the yahoo newsgroup called Elna Heirlooms, then search their threads, their members have covered the repairs to the inners of these before. Very helpful place to visit.
Posted on May 27, 2012
leighandjill
SOURCE: Run away foot pedal.
I had this problem with my Janome and also after I was given a new foot pedal as well, even though no fault could be found with it. I then suspected power surges as my computer went haywire at the same time on one occasion. I have never yet had the problem since I started to use surge sockets. I have only ever had the problem with my computerised machine, not my other although the foot pedals are the same.
Posted on Oct 07, 2012
How to adjust needle from left to right using zipper foot on ELNA 7000 sewing machiene
The instruction manual should have that information. If you don't have one, you can get it here:
Elna Sewing Machine Instruction and Service Manuals
Machines either have a needle that will move right or left or the zipper presser foot will adjust right or left.
Feb 26, 2018 | Elna Sewing Machines
My air elecntronic SU, which is thirty years old, doesn't always stop sewing when I take my foot off the air pedal. The machine keeps running until I tap a number of times on the pedal or turn the machine...
This will be the bellows inside the side panel of the machine where your foot pedal air line feeds into rather than the foot pedal. Really short of cutting or sitting on the air line with your chair, not much goes wrong there. It,should be repairable if you can locate a Swiss Elna trained/experienced techician.
Jul 01, 2014 | Elna Sewing Machines
Rotary hook machines
Yes it is a rotary machine. The foot you bought may not be the correct one for your machine. Mostly all machines are now horizontal rotary hook machines, but they don't necessarily fit ALL of those machines, it may be for a certain brand of machine.
Best bet is to bring your machine when you buy a foot so you can try it out.
Apr 07, 2014 | Elna Sewing Machines
Elna 9000 foot pedal
it sounds like you may have a connection problem with the plug on the sewing machine and the foot pedal, it would be a good idea to have them checked.
Mar 17, 2014 | Sewing Machines
Tech says it needs a controller for an elna 7000. is that part still available? he means speed control
I am sure it is. He/she should have elaborated on the replacement cost.
Are you referring to a foot pedal or does this model have the start/stop button and slow/fast selection?
A foot pedal can be ordered from an online site that sells parts and accessories for sewing machines.
The other function I mentioned has to be fixed by a sewing machine repair person.
Feb 20, 2010 | Sewing Machines
My very old Elna Super foot pedal does not always start the machine. When I help it along with the wheel it might start going and then maybe not. Is it the motor or the foot peddle that is bad? Can it...
this sounds like the internal clutch drive is worn, it probably is not the foot pedal at all. It may be possible to repair it if you can track down an Elna serviceman. My Air Electronic SU got worn internally and my serviceman was able to repair it once for me.
Oct 28, 2009 | Elna 2007 Mechanical Sewing Machine
Elna 7000 computerized sewing machine
Oct 20, 2007 | Sewing Machines
Sewing Machines Logo
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
