Question about Brother SE-270D Computerized Sewing Machine
Can't shirr on new brother sewing machines!
Hey there,
I have exactly the same problem with shirring on the brother anniversary edition and the more advanced version , the wonderful one with the automatic thread cutter...
it seems to me these machines are built with a different tension system for the bobbin... and its impossible to get the elastic thread to have tension and shirr... so frustrating!
I would love to figure out if there was a way to regulate this,
let us know brother!
Anu
  • 46 Answers
The bobbin case tensions are "preset" from the factory. I would not recommend turning the tension screw that is locked with paint. You can however get a replacement case and break the seal and use that one for specialty thread and such.
Posted on Jul 25, 2009
How do i thread the bobbin on a singer electronic anniversary edition
wind bobbin, drop into position ensuring that when thread is pulled bobbin rotates counter clockwise, pull thread towards you into slot, pull it to left under tension spring, then follow thread groove in bed to thread lock back left corner. close cover and start to sew ifr you need Singer 160 instruction email
Feb 04, 2014 | Sewing Machines
Any advice on shirring with an old elna lotus sp. Brought out of retirement as my Brother refuses to shirr! bobbin threading etc can't find the manuals.
Suggest you watch in utube 'sewing with shirring elastic' not necessary be your model as the basic application is similar in other models.
Nov 11, 2013 | White Sewing 1521
CANNOT Figure Out Shirring on... Brother LS-500
I was just reading in the manual for my antique Montgomery Ward Model 30. It described shirring using a ruffle foot. If we can extrapolate from this info you may be able to do shirring with yours. You'll need similar material scraps to practice.
It describes a "shirring plate" that essentially goes over the feed dog area and eliminates their pulling the fabric through. So to emulate this you'll need to lower the feed dogs. Look for a slide type switch either on the front or back of the machine near the needle area.
Attach your ruffler foot. The instructions say to remove the separator blade... that's the very bottom part of the attachment. On mine there's a screw that allows you to take that part off which only leaves the blade that tucks the fabric to make the ruffle. (hopefully modern machines have this ability) Make sure you place your screw and blade in a safe place. (I like to use masking tape... and tape it to a safe place)
Place the material between the feed dog area and the ruffler blade. Longer stitches mean bigger and more loose ruffles. So lets start with big ruffles.... set your stitch really long. Set your ruffler setting for the desired type of ruffle or Plait. Shirring is done with a single stitch plait or "gathering"
Ok here is where it gets a bit confusing because modern seamstresses don't have the variety of threads we used to (or can afford anyway) It says. "Thread bobbin with mercerized DMC floss No.3 keeping the bobbin tension loose, long stitches and thread top with stitching silk that contrasts strongly with the color of the DMC sot that the stitch of the bobbin thread will stand out clearly as a trim" It also suggests the use of the quilting guide to make your stitch rows evenly spaced.
So practice this technique on some scrap or similar materials. Good luck. ;)
Sep 06, 2012 | Brother Sewing Machines
I have a Brother 70 stitch computerised sewing machine. I have managed to fill a plastic bobbin with shirring elastic by not using the little tension knob, only the hook section of it on top of the...
You should not have both, bobbin and top thread filled with elastic, it may screw up your timing. And you are talking major expense to fix. Use regular thread in your bobbin.
Jan 02, 2011 | Brother Sewing Machines
My machine is not shirring. I hand wind the elastic on the bobbin properly(in fact 4 different ways from no tension to medium tension on the elastic). I have it on a straight stitch and selected 4 as the...
you are doing it wrong, thread the machine top and bottom as normal, shirring elastic on your lap, select a small zig zag or pattern, sew and as you sew pull the shirring elastic taught, mif you wind the shirring elastic on the bobbin you will mess the tensions up.
Apr 22, 2010 | Brother CS-100-T Computerized Sewing...
Pfaff serger shirring foot not shirring
Differential feed setting to the tightest position?
Mar 19, 2010 | Sewing Machines
When sewing with shirring elastic on bobbin the material does not gather the machine sews great any other time model no is bm-2600
my friend and i sat at the machine to see what was happening
the 1st thing wrong the plastic bobbin was the wrong size and the bobbin was not threading through the tension spring as the elastic was to thick
Jan 05, 2010 | Brother LS2020 Sewing Machine
Shirring fabric?
Drop the bobbin with the elastic in the holder without feeding it through the holder, and enlarge the stitch length,
Mar 29, 2009 | Brother XR7700
Brother SE-270D Computerized Sewing Machine Logo
534 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
