Question about The Office Equipment & Supplies
What is the ratio of 4 4/9 to 16 is equivalent to in simplest form?
  • 807 Answers
I have never seen a ratio reference like this. Rounding up it should be 4.5 to 16. What is the application?
Posted on May 09, 2017
11/8 two equivalent ratios
5.5:4, 11:8, 22:16, & 44:32 *all* have the same ratio. Additional equal ratios can be determined by multiplying *both* the 11 and the 8 by any number. Example (1): "5" 5 x 11 and 5 x 8 for a 55:40 ratio. It is much more desirable to reduce the numbers to lowest whole form - hence expressed as 11:8 ("8 to 11"). A second example using "3/4" (or the decimal equal .75) .75 x 11 and .75 x 8 for an 8.25:6 ratio. Again, whole numbers are preferable unless they get very large.
Jan 05, 2015 | Mathematical Technologies Inc. MTI Tristan...
How do i do eqivalent ratios
Ratios are like fractions: to make an equivalent ratio you simply multiply both sides of the ratio by the same non-zero number. 1:2 is equivalent to 2:4 (both sides multiplied by 2). 10:12 is equivalent to 5:6 (both sides multiplied by 1/2).
Nov 09, 2014 | Computers & Internet
Is 16/100 equivalent to 8/50
Yes. It is also equivalent 4/25
16/100=8/50=4/25
The last fraction is the simplest form of all those fractions.
Jan 12, 2014 | Office Equipment & Supplies
14=1*14
28=2*14
13/28=(1*14)/(2*14)=(1/2)*(14/14)=(1/2)*1=1/2
14 is half of 28
Why can't i see this integer as a fraction
By hand you can write every integer you wish as a fraction with denominator 1. 4=4/1, 13=13/1. You can even generate all the equivalent fractions of any integer, for example -4=(-8/2)=8/(-2)=-8/2=-12/3=...
However, simple calculators are designed with a feature called automatic simplification. That is why ever result that is a fraction that is equivalent to an integer is written as that integer. Fractions are reduced to their simplest form. Call it a design flaw if you want but that is how it is.
Oct 12, 2013 | Office Equipment & Supplies
Convert -525 degrees into radain pi form
Here is some help
180deg is equivalent to Pi radians
Take some angle. Its measure in degrees is say x_deg, Its measure expressed in radians is x_rad.
The fraction of 180 deg that the angle represents is equal to the fraction of PI that this angle represents.
Conclusion: the ratio x_deg/ 180 deg must be equal to the ratio of x_rad/PI
x_deg/180 deg=x_rad/PI
Isolate X-rad in the above equation. Some will tell you to cross multiply.
x_rad=(Pi/180)*x_deg
Application: x_deg=-525 in radians?
x_rad= (PI/180)*(-525)=-(525/180)*PI
Keep the value (525/180) as a fraction reduced to its simplest form. The result is 35/12
Sep 26, 2011 | Casio FX-115ES Scientific Calculator
Write a ratio equivalent to 7:17
Read the definition of equivalent ratios. Choose the numbers a and b such that a/b=7/17. (Here is a HINT: The operation to perform to obtain a from 7 and b from 17 is the inverse operation that you use to reduce a fraction to its simplest form.)
Once you dtermine how you are going to construct a and b, the calculator can then help you express each one as a single number.
Sorry I cannot be more specific: You have to make a little effort to understand what you are supposed to be doing.
Sep 22, 2009 | Office Equipment & Supplies
Top The Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
old marine
old marine
Mitch Vass
Mitch Vass
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
