Question about Dell Computers & Internet
Dell Latitude c840 power supply How to I open the P.S. case? Model: PA-1900-05D. I have to separate the halves to change a wire.
  • 18 Answers
SOURCE: ITT Mariner 160 - How to open the case...
this unit is siliconed together to make it waterproof and outer ring on eye piece is glued on after assembley you have to pry casings apart with knife ect not easy but they do come apart without damaging internal parts make sure you also remove casing screw under label as well i have dissasembeled about four of this model succesfully
Wayne
Posted on May 31, 2008
  • 3 Answers
SOURCE: wireless driver compatible for dell latitude c840
what is your os?
Posted on Jun 03, 2008
  • 26 Answers
SOURCE: replacing dell latitude keyboard
use the following to complete the job
http://support.dell.com/support/edocs/systems/latd505/sm/keyboard.htm
Posted on Aug 22, 2008
  • 35 Answers
SOURCE: admin password dell c840 latitude
you can search for a password boot disk which will disable the administrator password. There are dozens of these types of programs but one program I recommend is windows password reset 6.0
Follow the instructions:
1.Free download the iso file : http://www.resetwindowspassword.com
2.Burn it to a disk to create the boot disk, that simple.
3.Configure your pc or laptop to boot in the cd drive,
4.Insert the CD, reboot from CD drive, and then just follow the process of instruction. A few steps later, admin password would be cleared
Took about 5 minutes for the whole process.
Posted on Jun 12, 2009
  • 4 Answers
SOURCE: how to turn my wifi on on my dell latitude c840?
most dell laptops you hold the FN and F1 button down the outher way is go into Network Connections right click on the wireless and then enable hope this works.
Posted on Dec 29, 2009
What do I do when the used dell latitude c840 i received has just a white screen when I power it on?
might be a bad lcd or try to reseat the lcd cable on both ends on the motherboard and behind the lcd
May 14, 2014 | Dell Latitude C840 Notebook
Adapter does not chanrge
make sure its plugged in correctly and the wall plug is plugged tightly. I had a Dell C840 when the
charger got power it had a green diode that lit up. You could test your power supply with a volt ohm
meter. if the VOM is not showing any power coming from the power supply (assuming you have the
VOM setup to match the power output of the power supply) then the power supply is probably bad.
If it works then it could be the computers connection or battery.
May 14, 2011 | Dell l 1X917 310-2860 DA65NS0-00 DF261...
How to reset bios of my dell latitude c840????
I've had to do this before. Call up Dell tech support and assuming you can provide proof of ownership then they'll give you the reset code based on what's on the screen when you try to log in to the BIOS.This is the best way to solve that issue.
Even if you cannot prove purchase proof they will give you a reset code. Just contact them removing battery and other suggestions will not work it is a dedicated BIOS on a separate chip. I hope that this gets you pointed in the right direction. Just go to Dell.com Thanks for using FixYa! John
Apr 07, 2011 | Dell Latitude C840 Notebook
Need to reset cmos for booting to DVD drive dell latitude c840
Hi try pressing the ESC button during boot up, sometimes its the delete button, then select this drive by scrolling down, select CD drive for primary boot device, save changes and reboot. Hope this helps, come back to me if you need more help?
Jul 07, 2010 | Dell Latitude C840 Notebook
Cursor jumps while using touchpad.
> try to go to touchpad properties,you will be able to see there an option for tapping,you will be able to see there an option where you can turn off tapping while typing
Jun 21, 2010 | Dell Latitude C840 24X CD-R W/ DVD Combo...
Dell C840 no power is there is a fuse?
Hi
Thank you for your query
Please try the following
1) Ensure the fuse in the socket has not blown,
2) Try to obtain a replacement power lead to ensure the lead is not faulty
I would not recommend that you open the Laptop as only qualified engineer's should carry out this work
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 17, 2010 | Dell Latitude C840 Notebook
No sound on my dell latitude c840
Are you using Dell's driver?
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&osl=EN&catid=3&impid=-1&servicetag=&SystemID=LAT_PNT_P4_C840&hidos=WW1&hidlang=en&TabIndex=
Make sure any audio drivers are uninstalled before you try to install a fresh copy, check both add remove programs and the device manager.
May 31, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Replacing dell latitude keyboard
Aug 20, 2008 | Computers & Internet
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
