Led46c4srq flash on then goes off .sometimes stays on could turn off and on for days then samething
Break petal jumps sometimes goes to floor
then take it to a brake shop and have it repaired before you kill someone with it .
Apr 14, 2016 | Hayden-Harnett 2001-2006 Ford Escape...
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Hold light stays on, 2002 kia sportage
are u sure the button isn't pushed on the side of shifter...If its flashing i am not sure. when i go out 4x4ing mine flashes then a few days later it goes out....
May 25, 2010 | 2000 Kia Sportage
Computer will not start up
Acer Aspire One netbook stays loading windows xp and goes nowhere went to last known config..... nothing.......went on safe mode with networking ......nothing...samething....starts up loading windows xp and stays there.
Jan 02, 2010 | Acer Aspire One Netbook 8.9" Notebook
Door opener looses power
Motor has a thermal sensor if it gets too hot it trips the sensor till it cools down. Motor may be going bad, or door may have gottin to heavy ( spring loose tension over time) disconnect door from operator. You should be able to raise it easily manually.
Oct 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
36" sony trinitron
Hi
you have defective starting capacitor! that is located in power section! or in the H.O.T. Area.
Thanks!
Sep 04, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
