Question about The Health & Beauty
How to find out which battery to buy for a 48volt mobility scooter.. I have the number off the top of the battery the last of the # is in Japanese..
3 Suggested Answers
gewiz
  • 1271 Answers
SOURCE: Mobility Scooter - Golden Companion 1
Please make sure you FREEWHELL lever located at the rear is in drive mode, if you can push it, move the level.
Posted on Jun 13, 2009
  • 177 Answers
SOURCE: batteries die fast on my mobility scooter.
Hi. What size batteries you buy will be limited to the amount of room you have in the machine.
17 amp hour batteries are really a bit small for any mobility equipement. A lot of power chairs have 35 or 40 amp/hour batteries.
Buy the biggest that will fit into the available space.
Batteries are designed to perform a certain number of "charge cycles". If you run your batteries down by 75%, you will only get a small number of "charge cycles". If you only use 25% of the batteries capacity, you will get 100's of "charge cycles".
The best I have seen is 7 years out of a set of batteries. Short trips and recharging after each trip is the reason.
Good luck. Neil.
Posted on Jun 04, 2010
Testimonial: "thanks again"
CHARGER GREEN LIGHT FLASHES ALWAYS EVEN WHEN NOT PLUGGED INTO BATTERIE ALSO ONLY LASTS ABOUT 1 HR ON SCOOTER GOES FROM GREEN TO RED IN NO TIME
Battery Not Holding a Charge
Mobility scooter batteries can encounter problems, as over time, these batteries age and lose some of their effectiveness, until eventually they stop working completely. In this case, battery replacement represents the only thing that owners can do to fix the problem. Before doing so, however, they should perform some other troubleshooting measures to make sure. For collapsible scooters, seat the battery properly when unfolding the scooter for use. Owners should also make sure to properly connect the battery, while also looking for any error messages or flashing lights displayed on the scooter's dashboard.
5 Troubleshooting Tips for Mobility Scooters
http://www.travelscoot.com/battery-information.html
http://www.travelscoot.com/contact-us.html
Dec 01, 2015 | Travel Scoot Travel Mobility Scooter -...
What type of batteries does this model take?.jb.
you need 12v 33ah sealed deep cycle battery most likely it may need two batteries any thing above 33 amp hours would also be ok. A higher Ah the longer the batteries last. This information on the type of battery is from the user manual.
http://www.hardwarexpress.co.uk/rascal-388-mobility-scooter-battery-1949-p.asp
Any battery type store should be able to supply this to you .
Feb 10, 2015 | Electric Mobility Rascal Scooter...
Find vin number on rascal scooter
Depending on with Rascal scooter you have, The 600's number can be under the foot plate which means turning the scooter onto its back supports to have a look. The numbers can be stamped into the metal support for the seat post or even a sticker stuck on the rear frame work of the scooter. But about the batteries the other answer you got is correct.
Feb 07, 2015 | Electric Mobility Rascal Scooter...
48volt daymak ebike wiring diagram
hi, if you can show me a picture of the controller used, i can advise to what connects to what ..
Regards
Rob
www.facebook.com/gewizrepairs
May 16, 2014 | Health & Beauty
I need a new battery for my Shoprider mobilty Scooter TE 888NR Can you please tell me which one I need, where I can buy it, and the price. Many thanks.
alison If you have a 4 wheel scooter midsize then you require 2 U1 batteries. If you have battery warehouse type store or an interstate battery dealer in your area you should be able to get them through them. At last resort you can go to the provider that sold you the scooter. Cost can be $175.00 to $225.00 for the pair. If you can or have help take the seat off the scooter remove the rear shroud or cover and you will see the batteries there look on the batteries and they should have a number on them like Universal UIB etc Hope this helps
Nov 18, 2010 | Health & Beauty
Batteries die fast on my mobility scooter.
Good luck. Neil.
Jun 03, 2010 | Electric Mobility Pacesaver Electric...
WHAT ARE THE NEWEST AND LONG LASTING BATTERIES I CAN BUY FOR MY MOBILITY SCOOTER. I WANT TO TRAVEL FARTHER THAN THE 20 MILES WITHOUT RECHARGING THE BATTERIES. ALSO I WOULD LIKE THEM TO BE SMALL AND LIGHT...
Hi. When you are looking for good quality batteries, they will have a 1 year warranty on them. If you get offered only a six month warranty, don't buy them. Good batteries weigh more than cheaper batteries, because they have more lead in them.
To get a good distance, you need to fit the biggest batteries that will physically fit in your machine.
Batteries are designed to handle a certain number of "charging cycles". If you run a battery down by approx 75%, you will only get a small number of "charging cycles". If you only use 25% of the batteries capacity, you will get 100's of charging cycles.
Gel batteries seem to be the better choice. Most AGM sealed batteries are designed to be stand-by batteries. They will work fine in your machine but only for light use. I have seen these batteries last for 7 years, but only for light use.
Good luck. Neil.
Jun 02, 2010 | Electric Mobility Pacesaver Electric...
Details of batteries ie type of batterie and batterie rating and number of batteries reqired
All scooters (or at least 99% of scooters) will run on 24 volts, therefore there is usually two 12 volt batteries needed to run the scooter. Unless the scooter is very old, these will be in the form of dry batteries (sealed top with no water top up required) usually GEL, SLA or AGM. It Doesn't matter which type you use but GEL tend to last a bit longer and are more expensive. As to which size of battery you require, it should be marked on the battery somewhere in an Ah rating, for example 12v/31Ah. I would need to know which model of scooter you have to be able to help you with the size you require. You should also replace batteries in pairs, not as a single and should use the same rating and type, so dont put 31Ah batteries with 36Ah batteries and not an AGM with an SLA, GEL etc. Hope this helps...
Mar 11, 2010 | Health & Beauty
Health & Beauty Logo
