Question about John Deere Garden
Have John Deere 935 lawn tractor will not crank. I think it is electrical problem. At the beginning it did not start so I put new relay then it worked fine. Need help. Thanks
    New Friend:
  • 43 Answers
So it's working now? Or what's the question?
Posted on May 15, 2017
  • John Deere Master
  • 7,515 Answers
You just go to the link I attached I'm sure you will get the solution of your problem.
Best Manuals
My john Deere 110- 42" cut lawn mower ran out of gas and won't crank back. Noticed the parking brake is engaged but will still roll. What is my problem?
Hi Shannon, It's either fuel OR electrical, First check electrics, If it cranks but not starting......
How to test a solenoid....
How to test lawn mower solenoid
How small engine governors work....
How Small Engine Governors Work any governor setup
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 29, 2016 | John Deere Garden
John deere x540 with140 hours. Jump started from storage and cut 2 hours without issue. would not crank back up. Installed new battery and checked fuses. Lights and all come on but will not crank.
would not crank Chet, Relay,Solenoid or starter may be defective, give the starter a sharp bang with a hammer, to see if it is stuck.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Test lawn Mower Solenoids
How To Test Solenoid with Taryl
Electrical System Troubleshooting for Lawn Tractors Mowers
JOHN DEERE KAWASAKI RELAY
Mar 30, 2016 | John Deere Garden
John Deere L130 riding lawn tractor will not start what do I do?
I'm assuming the motor will crank over, but not start. Remove the air intake cover & filter off the carburetor air intake. Do you smell gas? Is gas dripping out of the carburetor? If not, spray a couple shots of starting fluid or carburetor cleaner into the carburetor air intake throat. Close the choke & crank the engine. If it starts, & stalls, repeat the process. If it won't stay running, your carburetor float jet is gummed up & needs to be cleaned. Check & clean the spark plug. Does the spark plug fire when the engine is cranked? If no, then you have an ignition problem.
Mar 05, 2016 | John Deere L100 Series
John deere lawn tractor 175. engine turns but No spark from spark plug
some of the safety switches will shut the spark off unplug the harness from the engine then crank it over if you have spark there is a problem with a saftey switch if you have no spark the problem is the coil
Apr 13, 2012 | John Deere Garden
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
I have a 21 year old john deere 175 hydro lawn tractor with a 38 inch deck and it needs a new motor and a new swith to engage the lawn mower deck how much is it worth with those being broke ?
Trans 150$.Mower deck 50$.Hood 50$.Fender deck and seat 75$.Front axle and spindles 75$.Electric clutch 40$.This is what you can expect to get if you part it out or you can trade it in for 250$ on a new Deere.
Mar 21, 2010 | Peg Perego John Deere Turf Tractor
Need instructions for changing a drive belt on a john deere LT155 lawn tractor. When mowing up hill the forward motion is slipping even though i am not loosing traction. if i come off the pedal and start...
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
Oct 14, 2009 | John Deere Garden
John deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
May 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
29 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
