Question about Honeywell Heating & Cooling
Looking for replacement time clock for Honeywell ST1505
I can't set my time zone on my Honeywell Automatic Clock
Please see this answer:
Mar 06, 2012 | Honeywell RC182WR Atomic Alarm Clock - Red
How do you fix the time zone on a Honeywell Projection atomic clock?
Please check out this answer:
Jan 05, 2012 | Honeywell RC182WR Atomic Alarm Clock - Red
How do you set the time zone on the honeywell red atomic clock?
Take off the battery cover, and take the battery out, After two minutes insert the battery.You will have to reset everything but it automatically detects your time zone
Oct 28, 2011 | Honeywell RC182WR Atomic Alarm Clock - Red
Clock Manuals How do you set time zone on Honeywell Atomic clock?
Get into this link. You can download the user manual for your Hoenywell Atomic clock. If you feel any difficulty in downloading the same, send your email address to me by FixYa. I've the downloaded manual with me, and I'll send a copy of it to you by return mail. OK.
Oct 24, 2011 | Honeywell RC182WR Atomic Alarm Clock - Red
My clock jumps an hour ahead, how do I fix it?
Make sure that you have the clock set for the correct time zone, and that the DST feature is switched ON. If those settings are correct, try replacing the batteries. Weak batteries frequently cause an atomic clock to "jump" one hour in either direction.
I hope this helps.
Bill B
Aug 04, 2010 | Honeywell RC182WR Atomic Alarm Clock - Red
I have a very old manual Chronotherm thermostat.
No. The clock is just the set back timer. Pull the battery and use the stat manually.
Jan 26, 2010 | Honeywell Electronic Programmable...
Can't figure out how to set the time zone
I just pressed and held for about 3 to 5 seconds the button with the +/- on the bottom of the clock and until it showed the part of the US that I was in.
May 18, 2009 | Honeywell RC182WR Atomic Alarm Clock - Red
Honeywell T882 Chronotherm Clock Thermostat needs replacement
The two wires from the transformer are to run the clock in the old thermostat. If you connect the two other wires to any heating thermostat, it will work. Don't forget to disconnect the transformer wires. Hope this helps
Nov 10, 2008 | Honeywell Electronic Programmable...
Honeywell programmer gone dead
lift the face plate off and change the batteries
Jul 07, 2017 | Honeywell 2-way Oscillating Ceramic Heater
Heating & Cooling Logo
32 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
