Question about Vizio Televison & Video
My 65 in Vizio from COSTCO will not stop giving me audio descriptions of every key stroke on the remote..help!
5 Suggested Answers
SOURCE: vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Posted on May 25, 2009
antn
  • 15 Answers
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Posted on Jun 11, 2009
  • 5 Answers
SOURCE: every key stroke gives me double characters
Possibly your keyboard settings are too sensitive. Go to your Control Panel and click on Keyboard. There you can adjust your settings to decrease the sensitivity of the keys.
Posted on Feb 10, 2010
  • 1779 Answers
SOURCE: Cannot remove the 'store' settings
Unplug the set for 20 minutes then plug it back in and turn it on. You should see a setting that says HOME____STORE on the screen. Make sure you high-lite HOME. Then continue on.
Posted on Dec 27, 2010
I have a 47 in Vizio and I'm having a hard time getting any remote to work and when it does it continues in last pressed direction without pressing any buttons. Any suggestions?
If the remote is at fault then covering the IR port after pressing a button should cause the tv to stop responding. That is what I understand from your description? I. hope that is what you mean.
In that case the easy option is to replace the remote control.
If it is not a remote fault it might be an error with the remote sensor giving chimerical commands to the tuner. Try obtaining a replacement original remote handset. If that does not cure the issue you should have a good idea of the cause
Jun 14, 2015 | Vizio Televison & Video
Cannot remove the 'store' settings from 55 inch vizio bought at costco today When i push the "OK" button on the remote it 'thinks' that I'm pushing the 'menu' button and gives me the 'menu'...
Dec 27, 2010 | Vizio XVT553SV 55 in. LCD TV
I have just bought the 42 Inch Vizio from costco and it worked fine for two weeks and then the remote stopped working. Also the DishNetwork remote which I used to control the TV and the DN 622 can not...
We're sorry to hear about Vizio TV remote, but we would be happy to help you with getting your DISH Networkremote to control your TV. We're going to start by pressing and holding the TVbutton located on the top of your remote until all mode button back lights comeon, and then release. Use the number buttons to enter the codes for your Vizio TV; here some of the codes we currently have: 505, 598, 627, 520, and 766. Press the pound (#) button. To check that the code works try severaldifferent functions on the remote to make sure it will properly operate the TV.Remember that some codes may not be compatible with your equipment. If this isthe case, try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Oct 07, 2010 | Vizio VO47L 47 in. LCD TV
TV shows orange light but doesn't work
Have you tried taking it to Costco for an exchange? Other than their strict return policy on many electronic items, they are very good about customer service. They may make an exception if you take it in and talk with a manager in person.
Jul 09, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio remote control not working
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio VW32L HDTV10A stopped responding with Vizio
Change the batteries in your remote. If your cat was laying on a button it could have drained them.
Here's tip - you can use your camera on your cell phone to see the IR signal coming out of your remote. Point the remote at your cam and press "On" or any button. You should see a bright flash with every key stroke.
Mar 06, 2009 | Vizio VW32L 32 in. LCD HDTV
My vizio vx32l will not turn on. vizio logo will
The main board has failed. Replace the main board will fix the problem.
By the way, where did you buy the TV? If you have bought it from Costco then try to give them a call to see if it still under warranty.
Hope this will help.
Feb 18, 2009 | Vizio L32 32 in. LCD HDTV
Vizio LCD
Pretty good chance the logic board is defective. all remote and manual command go trough the logic board via a micro prosseor. If that is bad the set gets false commands. If the run number is the same on that model they probably all have the same problem.. Get another brand not made in China.
Jun 20, 2008 | Vizio GV42L 42 in. LCD Television
Pop of Death
Having the same problem except on a 32 inch LCD
Jun 16, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
