Question about HP Measuring Tools & Sensors
What should the stator ac voltage be for a briggs and Stratton 26 hp v-twin model 44P777
SOURCE: need pictures of governor springs and governor
model # 12f702-1824e1 mower( that uses weedeater string) had a spring come off the carberator and I don't know where to put it back on.
Posted on Apr 19, 2009
  • 138 Answers
SOURCE: Craftsman LT 1000 with Briggs and Stratton 20 OHV
lift your seat and look at the label that you got your model number from. to the right of the model number is the serial number. the first six digits of the serial number is the date your tractor was made - for example: serial no. 060802D002756 would make the unit made June 8, 2002
Posted on Aug 18, 2009
mowerman1857
  • 389 Answers
SOURCE: Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Posted on Sep 14, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
  • 395 Answers
SOURCE: Briggs and Stratton Intek V
Misfiring could be caused by simple things like fouled or worn out sparkplugs or an ignition system that is slightly faulty or Fuel problems such as dirty or stale fuel or clogged filter causing a leam mixture. Some B & S motors have an switch that cuts the Ignition if the oil pressure or oil level is low.
Another cause could be the Valve clearances are out of adjustment.
Armed with your Engine Number, visit the B & S Website for comprehensive information and specifications as well as a good FAQ listing.
Posted on Sep 17, 2010
Engine rpms is constantly going up and down.
Is the air filter clean?
Governor Ajustment Briggs V-twin - YouTube
? 3:12
www.youtube.com/watch?v=tOoArROpM_oJun 26, 2010 - Uploaded by IFIXIT4U The Briggs manual does not do a very good job. You have to adjust the tension on the two springs to set the RPMs that the engine runs at the low and high position. ... I really really need help guys my race motor has a 21hp vtwin brigs, .... Briggs & Stratton opposed twin carburetor series 1 of 3 disassemble ...
Sep 17, 2015 | Briggs & Stratton Briggs Stratton Intek V...
I have a charging problem with JD L155c lawn tractor. The battery is new and the voltage to the battery is 12 volts. Not enough to charge the battery. How do I check the ac voltage & what should the...
There are several possible Mowers of the "L" 155 versions.
John Deere LA155 garden tractor lawn mower. These stopped being made in 2010 (they started production in 2009, and so enjoyed a run of 2 years on the assembly lines). The JD LA155 is powered by a Briggs and Stratton 2 cylinder, V twin engine. This engine is 0.656 liters (40 cubic inches) in size and produces 22 hp.
1998 - 2001 LT Series
John Deere LT155 Engine: Kohler 1-cyl gasoline
2006-2006 L155c, This series was produced only in 2006.
Briggs & Stratton gasoline, 2-cylinder air-cooled, 724 cc [44.2ci ], 25 hp
Model 445777-0168E Code 021125YC, these are the engine numbers from a 25 hp twin cylinder, B&S.
Notes on these engines from parts supplier ereplacementparts.com:
Briggs and Stratton 445777-0231-E1 Engine: The proper flywheel part number and/or the alternator magnet size will determine the alternator type or output.
This 25 hp engine has 3 different possible alternators, standard circuit, dual circuit, tri-circuit. I would need the exact engine model numbers in order to precisely answer your question. Often mower models have choices for the engine they come with. In this situation the engine model is more important than the model of the mower.
Testing an alternator is fairly simple; all you need is a multimeter for testing.
  1. Disconnect connector from stator.
  2. Set multimeter for AC volts.
  3. Attach RED test lead to either pin on stator side of stator connector. (On single wire leads, attach RED test lead to the single pin.)
  4. On two wire lead models, attach Black test lead to the other pin. On single wire stator connectors attach the Black test lead to the engine ground.
  5. Prepare the lawn tractor for engine start (set parking brake, blade off, etc). Start engine and run at full throttle.
  6. Check output. Output for engines of this general size run in the 30 to 50 volt range. For instance the B&S V twin 22 hp AC output at full throttle is 30 Volts minimum. Other B&S on these machines spec 40 Volt minimum.
If your voltages are not in the manufacturers range, or non-existent, your stator is partly shorted or completely burnt out (open circuit). Either way you have to replace it.
A. In the picture is a single lead stator connector.
B. In the picture is a two wire stator connector.
Mar 15, 2015 | Garden
Briggs & Stratton engine model # 4455770435E1, need to find out what part number to order to fix alternator? Told our "stater" was bad?
The alternator (P/N 592831) should put out around13-14 volts DC with no load (other than charging the battery. If the voltage drops only when the deck is engaged but not when the lights are on it could be a connection to the mower clutch causing excessive current draw. I suggest covering the fundamentals such as ensure the battery is healthy, ensure all connections are clean and tight before condemning the stator. then and only then would I remove the flywheel to inspect the stator.
Aug 16, 2014 | Briggs & Stratton Briggs Stratton Intek V...
How does one increase the engine rpm on a briggs and stratton v-tek 26 hp motor?
should be a metering screw for the carb that goes in and out for idle adjust.
Jul 28, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Red end cap on new motor!
pull the cap off and look there,it is probably covering an adjustment screw for carb.
Mar 27, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
90 people viewed this question
Top HP Measuring Tools & Sensors Experts
obsteiner
Richard Lindsey ...
Are you a HP Measuring Tool and Sensor Expert? Answer questions, earn points and help others
