Question about Air Tools & Compressors
Model no:0300841.the cast iron part where you plug in the air hose
  • 2651 Answers
you CAN use the skillet, but not with great results id assume, it holds too much heat, and problaby a bit too rough underneath and would probably scratch the glass top, in a family business for over 20 yrs. now and thats my recomendation, my brother also in the same feild swears his wife uses it with no issues!!!
Posted on Jan 10, 2009
  • 135 Answers
SOURCE: jenn air glasstop
As long as the pan bottom is truly flat, you sure can. Hope this helps!
Posted on Feb 17, 2009
  • 35 Answers
SOURCE: what type of grids are the best and why, either
The porcelain is easier to clean,and wont rust,but it can also be chipped off if dropped.Its really a personal choice after that.there is nothing wrong with the plain old cast iron ones.
Posted on Jun 07, 2009
  • 11 Answers
SOURCE: Inefficient high pressure cast iron propane burner
Make sure you are using an adjustible high pressure regulator. Make sure there are no obstructions insde the burner tube or burner holes.
Posted on Nov 02, 2009
  • 10865 Answers
SOURCE: how do I attach the hose to the cast iron burner
Hello. Yes, the brass fitting goes on to the burner. At the other end of the hose is the valve and the larger connector for the propane tank. Enjoy your turkey! Regards, Joe
Posted on Nov 23, 2009
I need a 4 piston A/C compressor or a 4 piston hydraulic pump for a project. do you know which models have this
Devair/DeVilbiss Piston Air Compressors 5hp piston air compressor, 7.5hp piston air compressor, 10hp piston air compressor, 15hp piston air compressor, 25hp ... PUMP: 2 x 447 (2 stage 4 cylinder)
10HP 4 Cylinder 2 Stage Air Compressor Pump Solid cast iron 2-stage V-4 piston series pump, oil lubricated design to extend pump ... This is our 10 HP, 4 Cylinder, 2-Stage, air compressor pump with 43 CFM ... Compressor Stages‎: ‎Two Stage CFM @ 100 PSI‎: ‎43 CFM Compressor Type‎: ‎Bare Piston Pump Horse Power‎: ‎43 CFM
Petstar 4 - Ingersoll Rand > ... > PET Compressed Air Solutions Ingersoll Rand PETStar® 4 reciprocating air compressors offer durability and ... pistons with heavy-duty Class 40 cast iron cylinder construction; Piston rings and ...
Jan 31, 2016 | Air Tools & Compressors
My Bar B Chef grill grates are totally rusted. Are stainless steel grates better or should I stick with cast iron?
I prefer cast iron. Cast iron heats more evenly and retains temperature better. If they are falling apart from rust, junk them. If they just have surface rust and no holes, all you have to do is brush them with a steel brush at high heat. Wipe them off with a wet rag and then rub it with an onion to provide a teflon layer. if it is really heavy rust, spray oven cleaner on them and hose off. After use or for storage, clean them and then wipe them down with a cooking oil soaked rag. The oil will reduce rust build up.
Feb 28, 2015 | Grilling
Can I use Cast Iron Pots and Skillets on my new Frigidaire Gallery Stove Top?
Hello friend, thanks for your post!
It is not recommended to use any cast iron pots or skillets on a Frigidaire smooth top. In your manual it provides the best type of cookware material and cast iron is a poor heat conductor. Due to the weight of the cast iron it can cause scratches or damage the cooktop. I hope this information has been helpful. -Matt
Oct 09, 2014 | Kitchen Ranges
What are the advantages of a cast iron wok?
when cast iron woks are seasons properly, they help create the special 'wok style' flavor. They also have good heat retention and cook the food evenly.
Feb 18, 2013 | Home
Model hl410100 the compresser works well until the pressure reaches about 75lb then the motor stops but keeps trying to turn as soon as you bleed off some air the motor starts again until it hits 75lb.It...
might be a bad check valve and do nut use an extension cord ever on a air compressor it will over time damage the motor plug it in directly and use longer hose
Jul 06, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
My burners don't put out out much of a flame. Model CGBD48RSBX. Ten years old. Can I clean them?
That depends, Are the burners stainless steel or cast iron? The cast iron burners are heavy duty and can usually be cleaned, but the stainless kind may just fall apart after a few years of usage. It just may have clogged burner holes from rust and drippings that can simply be wire brushed. I'd use an air compressor to blow out debris from inside the burner as well.
May 12, 2010 | Grilling
Spark plug blew out of motor
The spark plug blew out because it was not installed correctly and was loose. Install a new plug and do it very carefully as there may be carbon in the treads the plug screws into. Screw it in until you feel it getting tight and then turn it back. Keep turning in and out until it fully seats. Always follow the vehicle manufacturer torque recommendations, but as a general rule 14 mm plugs with a gasket style seat should be tightened to 26 to 30 ft.lbs. in cast iron heads, but only 18 to 22 ft.lbs. in aluminum heads. Likewise, 18 mm plugs with gasket style seats should be tightened to 32 to 38 ft.lbs. in cast iron heads but only 28 to 34 ft.lbs. in aluminum heads. For taper seat spark plugs, 14 mm plugs should be tightened to 7 to 15 ft.lbs. in both cast iron and aluminum, while 18 mm taper seat plugs should be tightened to 15 to 20 ft.lbs. in both types of heads.
Jan 14, 2010 | 1998 Ford Explorer
How do I attach the hose to the cast iron burner,do I just thread the brass fitting to the cast iron burner or is there something missing
Nov 23, 2009 | Bayou Turkey Fryer Kit - 9195 Turkey Fryer
How to remove a cast iron kitchen sink installed
Turn the water supplies off unscrew the hoses,get a flashlight and look under the sink you should see clamps around the top holding it in, unscrew these and pull the sink out.
Feb 22, 2009 | Eljer 212-1088-00 White Dumount Double...
Air Tools & Compressors Logo
44 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
