Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
Briggs and stratton engine surges and slows, repeatedly
I have cleaned the main jet and renewed the in line petrol filter. Engine is a twin petrol engine on an MTD 906 ride on mower.
    President:
  • 1,129 Answers
There is still either water or debree contaminating the fuel system. Surging is usually debree, empty and flush the tank with gas or Iso alcohol, disassemble carb soak in solvent for 30 minutes blow out the carb passages, reassemble and if the problem persists run engine at top rpm with air cleaner off and block off carb intake with hand, this will stall the motor restart and repeat 4 - 5 times this wiil draw out any debree or other blockage in the carb.
Posted on Jul 25, 2009
Briggs and Stratton hunting and surging.
How about a leak down test?? sounds like blow bye. is it consuming large amounts of engine oil???
Apr 08, 2014 | Briggs & Stratton Garden
24 hp briggs intek starving for fuel
Always check for jet. 90 percent of the time it is clogged. Remove the bowl and float and it is the center screw.
Jun 10, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a Briggs and STatton 24 OHV intek motor on a craftsman lawn tractor. I got it on sale and when I got home it ran rough. The fuel line had collapsed or was plugged with some white powder. I took off...
It sounds like the fuel mixture is running very Lean..There are usually two adjusting screw screws on the carburettor that control the mixture. A Larger one is for the Main Jet and a smaller one for the Idle Jet. There is also an adjusting screw on the throttle butterfly to control the idle speed.
To adjust setup, start with at least a half tank of fuel, and have engine at operating tempurature (That is warm but not overly Hot). As a starting point, loosen (anticlockwise) Main Jet screw about half a turn, to richen mixture,so that engine will run without choke. Run engine at full speed and adjust main jet for highest smooth speed without engine missing due to mixture being too lean or rich.
Allow engine to idle and the adjust Idle Jet Screw for smoothest idle. Idle Speed screw may have to be adjusted if idle speed is too high/low.
Sequence above may have to be repeated to get best running. If engine hesitates sometime when sudden load is applied but then picks up, try adjusting Main Jet by 1/8 to 1/4 turn richer until it handles the load without faltering.
Aug 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My engine is pulsing I removed the jet and cleaned with compressed air and cant figure out why it still surges at low rpm
it is a govenor problem i would just lift the revs slightly and try adjusting it out with air mixture screw
May 04, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine is surging when in idle
clean out the carburetor jets re-assemble then adjust fuel mixture screw until it runs correctly
Apr 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine only runs with full choke
only tow things this could be,,,
no fuel getting to card or timeing sliped,
most likley to be blocked jet in card or blocked fuel pipes ie filter in tank
clean out carb jets well and check fuel feed pipes
Oct 30, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Honda IZY engine hunts. I mean the speed pulses rhythmically!
sounds like air leaking into the intake.replace the gasket that is in between the carb and the block
May 23, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
1,581 people viewed this question
Top Parks Optical Garden Experts
colesmowers
Renee Knafel-Bullock
Adam Jasar
Level 1 Expert
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
