Question about Fishing
I have a quantum kvdsignature series baitcaster 601cx and the you put the drag on full and the line once its tight the handles still spin also now the spindle star lock is frozen can not loosen.
  • Fishing Master
  • 2,503 Answers
Editor925
  • 285 Answers
SOURCE: On the Bench Oscillating Spindle Sander how do you
Remove the spindle from the machine itself before you change the sanding sleeve. There should be a flat section on the bottom of each spindle that you can hook a wrench on to hold it while you undo the top bolt.
Posted on Mar 10, 2009
SOURCE: Quantum Tour Edition 1170PT baitcasting fishing reel
Tighten the drag star to expose the black ratch ring. Press the ratchet ring down towards the star drag as you turn the handle backwards to unscrew it from the crank shaft.
Posted on Apr 16, 2009
  • 4 Answers
SOURCE: Hi Folks. I am working with a Quantum TE1171PT
Check the release gear you will have to disassemble the reel,found others that the grease from the factory got old and hard,clean and replace it.Good luck
Posted on Sep 20, 2009
  • 436 Answers
SOURCE: 3"-4" Starrett 436 micrometer: When spindle
do you still have the locknut wrench? you need to loosen the spindle. if not try an industrial supply store to get wrench.
hope this helps
thanks
Posted on Mar 25, 2011
  • 118 Answers
SOURCE: I've borrowed a circular saw
you just have to look for little button close to blade, smash it, hold it while you move the blabe till gets stuck then you're ready to loose the blade! hope this help
Posted on Jul 26, 2011
Where do get users manual for Quantum BSP100PTSE spinning reel and set the drag
The drag is set using the knob in front of the spool... just tighten it until you can barely pull line out..(the bigger the line.. the harder you pull..and vice versa...)
Apr 22, 2016 | Fishing
Get a fishing reel schematic
CUSTOMER SERVICE
This is a link to Quantum and the "Code Red" baitcaster.
You can also try the following warranty service center.
Home
Feb 21, 2015 | Quantum Code Baitcast Reel 8 ball bearings...
KVD Quantum kinetic PT baitcaster reel, problem is I took it apart to clean it and couldn't figure out the right way to put it back together with all the spacers please help
I know how much everyone loves those reels They are great when they are new. But the truth is They are made to sell and they do sell. But I will bet a dollar to a donut that You would have 300% less trouble out of a Shakespeare Reel with less trouble and 70% less on cost and you cant wear them out.
Mar 31, 2013 | Fishing
Cant cast the pinnacle platinum plus lp 100 fishing reel more than 15 feet because the line tangles. Any suggestions?
Sounds like your drag is too loose. Best way to get used to setting a baitcaster, in my opinion, is to put a 1/2 ounce weight on the end of the line and engage the spool. The line should drop to the ground freely, but not full speed - if too fast, the spool will continue to spin and you'll get that dreaded birdsnest. If it doesn't reach the ground, you need to loosen it more. Once you have it set, keep that weight on and go practice, using the thumbing process Parorae noted in the previous answer.
They take some getting used to for sure!
Aug 04, 2010 | Pinnacle Solene SLP10 Baitcast Reel
Aug 31, 2009 | Sport & Outdoor - Others
Apr 15, 2009 | Penn Gt Series Levelwind Reels 330GTi
Fishing Logo
77 people viewed this question
Top Fishing Experts
ray gallant
Steve P
Steve P
Andrew Taylor
Andrew Taylor
Are you a Fishing Expert? Answer questions, earn points and help others
