Question about Coffee Makers & Espresso Machines
The light used to be green but now has changed to a steady red light. This is an office coffee pot and gets a lot of use. What does the solid red light mean?
SOURCE: Saeco Italia SUP021 YR - Red light #29 on solid
Comment on oily beans - try not to use them. If you are looking for a stronger flavor coffee, an an extra shot to your drink. Oily beans cake inside the grinder, brew group + components and strains them potentiallu causing malfunctions.
Also dark beans are usually over roasted which makes the makes real coffee flavor lose. Espresso coffee beans should have very little to no oil and be unifrom in color.
Another approach if you are looking for stronger coffee flavor. use less water instead of more coffee. Two shots of 2 oz. espresso (made with 7 grams of coffee) are more flavorful & sweeter than one shot of 4-oz. espresso made with 14 grams of coffee. Visit http://www.coffeetico.com/did_you_know.htm for some more interesting information.
Posted on Jun 20, 2008
  • 2318 Answers
SOURCE: Blinking red light
It appears in all cases that the power supply needs to be service. The blinking light might indicate that there are shorted parts or the voltage is low or a combination of both.
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Nov 27, 2008
  • 18 Answers
SOURCE: Epson Stylus CX3600 error
remove the cartridges then, the press and hold all the available buttons on your printer where it could cause a machine resetting...
you could also remove the cartridges then wipe the circuitry of the cartridge... (the gold-like connector)
then turn off your printer without putting back the cartridges... (leave it turned off for 5 minuets)
turn your printer on then it should be ok
(post back if it doesn't work)
Posted on Jul 07, 2009
  • 145 Answers
SOURCE: kitchenaid coffee pot won't brew coffee reads err2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If it does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Posted on Jul 08, 2009
  • 14 Answers
SOURCE: Makita BR1815 li-ion batteries won't charge
your batteries are toast;must replace
Posted on Aug 02, 2009
Coffee maker works fine but no green light telling me its ready. why the green light does not work ?
Probably just a LED burned out!. You can live with it but if possible, go to nearest authorized repair site to get it changed
Coffee maker works fine but no green light telling me its ready why the... Fixya com Customer Support Products Repair Manuals Troubleshooting on Any... Superstar Expert Achievement Badge Fixya Mister Danger Tablets eReaders PC Laptops Expert Fixya
Oct 05, 2015 | Bunn O-Matic 23001.0000 CW15-APS Airpot...
Mr coffee problems
You didn't indicate a specific model. So, I'm going to assume yours is relatively the same as my JWX27.
Let me start by clarifying what the red light indicates.
A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but due to be cleaned. When the coffeemaker is due to be cleaned, the red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The entire cleaning process takes about an hour and a half. And, it is not intuitive. So, here are my instructions.
With the coffeemaker off (with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
Jul 20, 2014 | Mr. Coffee Coffee Makers & Espresso...
Saeco vienna plus red solid light cannot prime water line
Make certain the line from the water resource is cleaned and not obstructed. If the pump fails to move the water from the reservoir to the heating tank, then the pump needs to be replaced.
Mar 25, 2014 | Saeco Vienna Espresso Machine
Clean instructions
First, let me clarify what the red light indicates.
Feb 04, 2014 | Mr. Coffee JWX27 12-Cup Coffee Maker
Saeco Eclipse stopped functioning
Have you solve your problem with Odea. Mine is new out of the box and not working at all. Red light blinking, manually prime it and so far only tree cups of coffee. After priming it the green light was solid and could make 3 cups then stopped. Any advise greatly appreciated.
Dec 12, 2011 | Saeco Odea Go
We ran the clean cycle on the coffee maker and the clean cycle will not turn off.
First, let me clarify what the red light indicates. A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but is due to be cleaned.
The red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The process takes about an hour and a half and is not intuitive. So, here are my instructions.
May 15, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
I have had problems connecting to internet all weekend (internet - red light), am on now but internet and ethernet green light keep blinking, is this ok.
No because dsl light should be solid green light. You need to contact your ISP to check if there is a problem on the network.
Jul 11, 2010 | Computers & Internet
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
