Question about HTC Touch Pro Smartphone
Installation failed errornr=256 internal error
After installing a couple of programs in JBlend I now always get Installation failed errornr=256 internal error when trying to install more programs.
Error "Driver installation failed: couldn't
Have you tried the program 'Everest" which tells you which drivers you need. Seems like you have motherboard drivers.
kc
Feb 28, 2011 | Computers & Internet
Problem with jBlend on my htc p3400
how to set memory card as default memory in HTC p3400
Jul 06, 2009 | HTC P4300
Error 1335
Method 2: Change the memory settings for installation To change the memory settings for installation, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig, and then click OK.
  3. On the BOOT.INI tab, click Advanced Options.
  4. In the BOOT.INI Advanced Options dialog box, select the /MAXMEM= check box, and then change the setting to 256 (or lower if your computer has less RAM).
  5. Click OK to close the BOOT.INI Advanced Options dialog box.
  6. In the System Configuration Utility dialog box, click Apply.
  7. Click OK to close the System Configuration Utility dialog box.
  8. Click Restart to the following message: You must restart your computer for some of the changes made by System Configuration to take effect.
  9. After you restart your computer, install Office as a Complete Install.
  10. After you install Microsoft Office, follow steps 1 through 8 to clear the /MAXMEM= check box.
By xIN3N
May 21, 2009 | Sun Java Studio Standard 5 (SSJI9501TL9M)...
Installation was failed in Jblend
Delete the unwanted applications present in the JBLEND.I got the same error in my HTC T5353,after deleting the java games i am able to download properly.
May 07, 2009 | HTC Touch Pro Smartphone
Cannot install 6940 driver
this is straight from hp
64 MB RAM for basic software installation (256 MB RAM for full software installation), 200 MB available hard disk space for basic software installation (450 MB for full software installation)
unless you get another 256mb memory it would be best for you to do basic installation.
Mark
Apr 21, 2009 | HP Deskjet 6940 InkJet Printer
Local machine: installation failed Installation: Error: Action failed for file avgmfx86.sys: starting service.... Error 0x80070002
Could be bad media.
Try another install cd. If the same problem occurs, then the hard drive probably has bad sectors.
Feb 24, 2009 | Computers & Internet
Action Replay DS - "Load Failed" Error
Have you tried re-installing the Action Replay Code Manager through the disc? I find that re-installation works for most computer programs when the first-time-installation fails. Just choose the most recommended settings (don't do manual stuff) and try again. If it still does not work:
-Check to see if your internet is connected properly
-Check the disc for any scratches; Scratches on the top of the disc are LETHAL to memory!
Jul 21, 2008 | Nintendo DS Lite Console
P5V VM-DH + EAX1600XT SILENT (256) = problem.. nahh
Did you turn your current graphics card down to 256 colors(more then likely your old video card is built into the motherboard). You have to do that before you install the card or that may be causing your error.
Keep me posted,
Lee
Jun 17, 2008 | ASUS EAX1600XT SILENT/TVD RADEONĀ® X1600XT,...
Can't install lexmark x4530...get spooler subsystem app has encountered a problem,etc.
Print Cartridge(s) Missing
The following print cartridges appear to be missing, not detected, or incorrectly installed:
Cartridge on Right
Cartridge on Left
May 21, 2008 | Office Equipment & Supplies
HTC Touch Pro Smartphone Logo
177 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
